Question about The Audio Players & Recorders
What's the problem with Main Unit of a Digital Home Cinema System-HTTXQ120 when HD signal to TV causes a blank/noisy sound? If signal from the decoder by-passes M/unit direct to TV, problem disappears
  • 81 Answers
OK try to connect all to tv and from tv connect the sound in digital to H/K receiver and you will have sound at the receiver no matter what.
Posted on Apr 08, 2008
  • 4 Answers
SOURCE: no signal on digital TV
If you are talking about over the air digital channels I would lean toward ant problems
Posted on Apr 26, 2008
SOURCE: No sound through the Panasonic cinema surround sound on TV
Had a similar problem mate. I solved it by connecting the tv to the PT460 system with a scart lead. You then have to have the AV channel selected on the PT460 system to listen to the tv. You will always have to have the AV channel on the PT460 selected to listen to any sound transmitted through the tv - be it playstation/xbox or any other device that you may connect in the future with HDMI leads or otherwise. Hope this helps
Posted on Jan 04, 2009
  • 3 Answers
SOURCE: how can i listen to my tv through my cinema system
Use a fiber optic cable
Posted on Dec 27, 2009
SOURCE: getting audio from LG TV to play through Samsung Home Cinema System
Getting audio from LG TV to play through Samsung Home Cinema System
Posted on Aug 16, 2010
I carn't mate my rear speakers with my audio system
press stop on the unit and mute on the remote at the same time
Jul 31, 2014 | LG LHB326 Home theater system with iPhone...
Will my home cinema also improve sound on my tv programs ? hts2500/5
Yes, but only if the tv has an digital audio output. If that is the case connect that to the home theater and mute the speakers from the tv - the sound will be decoded and delivered by the HTS, at a much greater quality.
Aug 15, 2011 | Philips Audio Players & Recorders
Connecting TV, cable decoder and xr29m80
you have two choices. a newer connection you must have on both devices is a optical connection. if you have this buy a digital optic cable.
if you dont have this connection. look for a red and white connection on both devices this is just a simple audio lead .
To recieve the sound through the speakers after you have installed the leads make sure the home cinema function is set to "tv"
Aug 07, 2009 | Sony FD Trinitron WEGA KV-XR29M80 TV
How do i connect my non hdmi xbox 360 to my panasonic scbt205ebk home cinema and panasonic 42v10 plasma so that the sound comes from the home cinema system. i also have sky hd
If you use a component system (1 yellow video wire, 1 red audio wire and 1 white audio wire)
You will have to connect the audio wires to your cinema system and the video directly to your set.
The unfortunate part of this is that when you want to use your system, you will have to change the input of the TV AND the Cinema system.
The same would be true if you wanted to use the DVD connectors (YBPBR). You would connect the video to the TV and the audio to the Panasonic unit.
The system you have is meant more for just playing DVD's and not a total cinema system. This is why there are limited (extremely limited) video inputs. The system is mostly for output of sound and of a the built in DVD video.
Aug 05, 2009 | Panasonic Televison & Video
No picture on TV through Sky, Home Cinema is on but have sound.
do have sound and picture at same time you will need a fibre optical cable, you connect that from your cinema system to your tv. then you need to set your cinema system to digital input or fibre optic or check by pressing aux on your remote and see which is the right one. i am not familier with panasonic as i have samasung.
Dec 10, 2008 | Panasonic SC-HT75 System
Friend gave me a jbl surround system to go with my 52" sony hd tv. It has four speakers. three sat 20 and one bass 20. going to a rca stva 3970 receiver. didn't have instructions to go with it.
You need two more speakers to get surround sound,ie> two front one center and two for surround,then you need a home cinema amp to run the speakers and decode the sound from your tv,sky,dvd etc,and the sub gives you your bass.
Hope this helps.
Nov 16, 2008 | JBL 5.1-Channel Home Theater Speaker...
I have a panasonic SC-PT850 DVD home cinema system, and although it says it is DTS and Dolby 5.1 compatable but it does not give out any sound at all when i play Blueray films or Playstation 3 games which...
Not so much an answer more a shared problem with a slight insight. On the Panasonic manual page 40
It states the following: This unit can decode the surround signals received through cable TV box, digital broadcasting or satellite broadcasts. Refer to your equipment’s operating instructions for details. Only Dolby Digital and PCM can be played with this connection.
So it sounds like the SA-PT850 unit will decode DTS from an internal source ie DVD but not from an external source ie ps3 or WDTV which is a shame because I own a WDTV. The solution for me is to convert the dts to ac3 (Dolby digital) which works great. But not sure if this is an option for you.
May 08, 2008 | Panasonic Audio Players & Recorders
23 people viewed this question
Top The Audio Players & Recorders Experts
Jose Ma DM.
Jose Ma DM.
Level 1 Expert
Are you a The Audio Player and Recorder Expert? Answer questions, earn points and help others
