Question about Microwave Ovens
Breville halo 2 infrared light flashes then goes out and food not cooking normally. Every time you stop and start it it flashes again and goes out any ideas please
  • 38 Answers
SOURCE: Microwave works for a few seconds and then the lights and turn table inside shuts off.
hi the light and turntable work of a common relay located on main pc board.relay probably dry jointed or sticky or check switches behind door catches
Posted on Feb 27, 2007
  • 579 Answers
SOURCE: Kenmore 721.63662300, 1200W
The magnatron is shorting and overloading the high voltage transformer which is complaining with a load noise. Worth fixing if you do it your self. Magnatrons cast about $40 wholesale. There are just a few varieties of them that fit almos all brands. Try www.partstap.com
Posted on Dec 31, 2007
SOURCE: the microwave starts, then stops 2 seconds later
I tried a solution posted on another posting http://www.fixya.com/support/t242480-stops_cooking by placing the conductive plastic behind the control panel and it worked.
Posted on Jan 06, 2008
MicrowaveSvc
  • 9085 Answers
SOURCE: Dacor DMD2420S
This is usually caused by either a bad door switch, a loose door switch mount, or a problem on the control panel.
Even though a door switch clicks, it may still be bad inside.
This can be caused by slamming the door or by habitually opening the door while it's cooking without hitting the Stop pad first.
If you or a friend decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa: http://tinyurl.com/yzjozk
We're happy to help and we appreciate your thoughtful rating of our answer.
Posted on Feb 09, 2008
  • 3 Answers
SOURCE: Emerson microwave, #MW8119SB, push start button to start cooking
Replace the fuse with a ceramic fuse from Home depot! costs less than $3 and it will fix the problem. I had all the same problems as everyone else, you name it my microwave had it! you must remember replace it with a ceramic fuse! not a glass one. I know people say its the switchboard and all that nonsence but I promise you, the fuse plays a majoe roll in the microwave not working properly. Even though it doesnt look broken, a junky fuse can cause your appliance to do very strange things. I replaced mine 6 months ago and it works like its fresh out of the box.
Posted on Apr 29, 2009
Sears kenmore elite has a message display to enter tcp code. kenmore microwave oven
TCP is "True Cook Plus" in Kenmore speak.
Here is a cut/paste of a section of the manual.
*CUSTOMIZING TrueCookPlus' You may find that you prefer TrueCookPlus® to cook your food more or less. TrueCookPlus " can adjust to your tastes - to cook your food hotter or cooler - automatically: Example Clear 1. Press the Clear button. (§H§ 1 2. Press the TrueCookPlus® button twice. 3. If you want less cooking time when you enter a TrueCookPlus code, press 1. This will decrease the time by 6%. 345 4. If you want more cooking time when you enter a TrueCookPlus® code: Press 3 for 3% more cooking time. Press 4 for 6% more cooking time. Press 5 for 9% more cooking time. 2 5. Press 2 to reset TrueCookPlus* to factory setting default time. 6. Press the Start button.
I didn't try to clean up the copy
Hope this makes sense and helps.
Sep 14, 2017 | Kenmore Microwave Ovens
How do I change temp and time while food is cooking?
all is explained in the user manual
if you have just put food in the even and pressed the start several times to get a number of minutes to cook but want to increase that time just press start again the number of times that you want the cook time to increase
for example :-
you put a frozen pie in the oven and your start operates in 30 second increments and you have pushed it 3 times and it starts cooking-BUT - you read the cooking instructions and it says cook for 4 minutes, just press the start another 3 times while it is cooking
the new cook time will show on the display
Dec 30, 2016 | Microwave Ovens
Kenmore elite microwave 79203 buzzes when off
It sounds like you have a shorted cook relay on your control circuit board.
That can usually be repaired more economically than replacing the circuit board.
Jan 09, 2013 | Kenmore 79203 Elite Stainless Steel 2.0...
Kitchenaid KCMS185JSS
The problem is one of the door switches has failed, usually caused by food partical buildup, switch must be replaced for normal operation.
Mar 12, 2012 | KitchenAid Microwave Ovens
Let me know the functions of microwave?
Sorry to read about your problem, I hope this helps you out.
Display: This is used to show the time, cook time and options you chose during you use.
Cook: Use this feature to cook fresh vegetable, frozen vegetables, rice and cassroles.
Enter/Start: This is used to start and enter any option you choice while operating the unit.
Stop/Clear: Use this function to clear or stop the unit during cooking or choosing a feature.
Reheat: This is use to reheat dinner plates and left overs. Be sure that you do not use any plastic foam or metal plates/utensils this can cause damage to the unit and may cause injury.
Auto Defrost: This is used to defrost food by weight and type. EX: If you have 1 pound of chicken, meat or fish press in the food code by using 1,2,3 and then the weight in pounds (1 pound would be 1.0 enter.)
Quick Frost: This is use with the Rapid defrosting method for 1.0 pound frozen food. If you have a pound of meat, chicken or fish press Quick Frost and it will defrost for that weight only.
Cook Time: This is to set the cook time for the food you are trying to heat or cook. Enter the time you wish to cook and press enter/start (EX: 7mins and 30 secs = 730/start.)
Clock: This is used to set the time of day. Press Clock the the time of day it is and clock again (EX: 11:00 would be 1100 then clock.)
Number: This is the key pad used to enter the cook time, clock or power level.
More: This feature is to add time to the cooking time only in ten second intervals. If you want to add time without restarting press this button to add ten seconds each time it is pressed.
Less: This is used to decrease the cooking time by ten second intervals. If you want to decrease time without restarting the time press this to decrease cooking time in ten second intervals.
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question's. take the time to rate us.Thanks and good luck
4 Thumbs - Very Helpful
3 Thumbs - Helpful
Power Level: This is use to choose the power level in which to cook or heat food or beverages. To change the default setting of 100%, press the power level button and press the level you desire, if you desire only 50% then press power level the 5 and enter/start. Hint: Change the Power level before entering the time your setting to cook
EZ-ON: This is to quickly start the power level to 100%.
Vent High/Low/Off: This is to turn the vent located on the outside of the unit during use. You have the option of turning it off, on, high or low.
Light High/Low/Off: This controls the light on the bottom of the unit if you have a mounted range above your stove or under your top counter cabinets.
Hot Water: This is used to heat water for beverages such as coffee and hot chocolate. Use Extreme caution when removing baverages from your unit, they will be hot and could cause injury.
Popcorn: This is used to pop popping corn, when placing the popcorn in the microwave press the this feature and enter/start and it will automatically start the correct time for cooking. This feature is designed for the individual packaged popcorn use. Do not place any foil or loose popcorn in the unit this could cause damage or injury.
Kids Meals: This is used to REHEAT meals for children it works at a lower power level. This can be used to reheat hot dogs, oatmeal, baby food and soup. Do Not place any metal objects or objects than can melt this can cause damage or injury.
Warm Hold: This is to keep foods or drinks warm for any length of time up to 99 minutes and 99 seconds. Although it is not a recommended to run a unit at the maxium time limit.
Melt: This is used to melt butter, margarine, chocolate, cheese and marshmallows. Do not leave these items unattended during the duration of melting time to prevent any unwanted over heating.
Soften: This is used to soften ice cream, butter, cream cheese, and frozen drinks. Do not place anything in a container that is made of foam or metal this can cause damge or injury.
*Child Lock: If your model has this feature it is used to lock the unit to keep a child from pressing buttons or causing injury.
Open: This is the handle or button on the front of the unit to open the unit after the unit is done cooking or in use. Do not open the door during the use, always press the Stop/Clear button first. Also do not remove hot items without oven mits or waiting time food is at a safe handling temperature.
Jan 03, 2011 | LG LMVM2277ST Microwave Oven
We own a Panasonic 1100 watt Inverter microwave. It has worked fine until recently - it has now started to "turn on" whenever the door is opened. Now, when you open the door the light...
HI:
You have a faulty door switch, the unit is not supposed to come on when the door is opened only the light.This unit may require servicing as the control board may also be at fault.
Dec 24, 2010 | Panasonic NN-S753 Microwave Oven
Power to microwave but does not cook food
You didn't mention your brand or model number, but I'll assume it's a Panasonic since you posted this under a Panasonic category.
See if this describes what's happening:
  • Put in time, push start and unit runs for 2 seconds, relay clicks, unit goes off. Cook time on display goes off and clock time comes back. Bad upper interlock switch and charred connector
If so, see http://207.234.249.73/mwd/safety.txt , http://207.234.249.73/mwd/disassembly.txt and http://207.234.249.73/mwd/doorsw.txt
Otherwise, if the digital programmer circuit / controller does not get a feedback signal from the inverter for a period of 3 seconds, the controller will stop the cook cycle.
If it stops after 7 seconds, it has a problem with the inverter.
If it stops at 16 seconds and is a sensor model, it probably has a defective humidity sensor.
If it stops after 22 seconds, that means the controller has detected a problem, usually a problem with the inverter, controller, magnetron, or a bad connection from one or the other.
Display codes H95, H97, H98 or H99 mean that there's a problem with your inverter, magnetron, or digital programming circuit.
That may be a loose connection in the wiring between the inverter, magnetron, and/or control board, or maybe one of those components has failed.
Due to the lethal voltages used and produced in inverters, I do not recommend that an inexperienced person work on these.
You can find an authorized Panasonic servicer here.
In Canada, you can find an authorized Panasonic servicer here.
May 26, 2010 | Panasonic NN-H264 Microwave Oven
Feb 27, 2007 | Maytag MMV5000 Microwave Oven
Microwave Ovens Logo
13 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
