Question about Sony Televison & Video
My Sony KF50 WE620 TV has no picture only horizontal lines what module will cure this problem.
There is audio, but no picture on any channel.raster is there can channel through video 1 to 6.
    Top Expert:
  • Sony Master
  • 77,499 Answers
Open up the TV and unplug all the connectors between the circuit boards and then plug them back in, this can restore functions sometimes.
Posted on May 19, 2017
premtech
  • 934 Answers
SOURCE: sony trinitron 32 in. pip no video, (raster, with audio)
What you have described there is a classic example of the jungle IC failure. Ic301 Sony p/n 8-752-101-04. A pic with no color, and lines or grainy texture in the picture. Not a project you want to tackle if you don't have the proper soldering equipment or skills. And not a costly one at a good repair shop.. Only real hurdle is getting that heavy monster into the shop. To answer your question, yes what you described there is raster. Even the salt & pepper looking screen with no real decernable image is described as raster. In fact any image generated on the CRT is raster. And yes, these sets are prone to solder joint problems, usually ring cracking in circuits that generate the most heat.
Posted on May 25, 2007
  • 1153 Answers
SOURCE: Horizontal Lines in picture
CHECK C2P08 100 UFD 16 V OFF PIN 3 OF IC2P03 (3.2 VOLT REGULATOR) ON THE SIGNAL PCB. HOPE THIS HELPS!
Posted on Sep 14, 2007
skotkolr
  • 558 Answers
SOURCE: Video & audio interruption
damaged power supply board or damed vga board could be capacitors or other issues need a service tech to look inside and see what gong on.
Posted on Apr 30, 2008
  • 4234 Answers
SOURCE: I have a horizontal color line across the screen...have sound .This is on Video 1
If you are comfortable working inside the set and can solder, try resoldering both the vertical IC and the input jack connections. The vertical IC will be a small flat IC attached to a heatsink with about 9-11 pins. It will be marked LA7837 or something similar.
Let me know the results.
Dan
Posted on Apr 15, 2009
johnnydiode
  • 647 Answers
SOURCE: 10 yr old Quasar 25in color tv. Audio is ok. No
Don't have specific knowledge about this model but the problem is in your vetical o/p section an is fixable.
In general read below.
This is an easy repair if you've ever soldered and would not be too costly for a repair shop to do it for you. The problem is a bad Vertical Output IC (usually mounted on an aluminum heat sink with the part on it labeled LA78?? ) and 1 or 2 bad capacitors. Some times you can even fix the problem by re-soldering the contacts of the IC- To find the IC follow the 4 wires that come from the Yoke (which is a contained coil of wires slipped over the neck of the picture tube(s)) back to the board. 2 of the wires go to the horizontal o/p and 2 to the Vertical o/p the thinner gauge wires are for the vertical.
Posted on Sep 22, 2009
When tv is powered on tv only displaying channel number and sound -no raster. using video mode displays are ok. sound is also ok
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Dec 06, 2014 | Sharp Televison & Video
Toshiba CZ32V61 no picture
1) you have problem with the Raster
2) the main causes are a) raster b) picture c) sound d) synch
3) since this are not video, the problem is raster. your must
test the voltage from section horizontal out +125vdc+vertical output +80v+all other circuit +12vdc
4) test the power supply for defective. see the diagram attached
Jul 12, 2012 | Toshiba CZ32V61 32" TV
Sony kp65wv700 tv blinks 7 times - Horizontal deflection issue is what manual is telling me. My question is what transistor/chips I need to replace and if anyone has done that to fix this problem...
Here are the fault codes for your tv and what components are affected:
  • 0 times, Diagnosis: Power does not turn on. Possible causes include: Power cord is not plugged in, Fuse is burned out (F6001) (G board). Symptoms of the problem: Power does not come on, No power is supplied to the unit, AC power supply is faulty.
  • 2 times, Diagnosis: B overcurrent (OCP). Possible causes: H. OUT (Q8024) is shorted. (D board), +B PWM (Q8035, 8038) is shorted. (D board) Symptoms of the problem: Power does not come on, Load on power line is shorted.
  • 3 times, Diagnosis: +B overvoltage (OVP). Possible causes: IC501 is faulty (G board), IC5002 is faulty (G board). Symptoms of the problem: TV has entered standby mode.
  • 4 times, Diagnosis: Vertical deflection stopped. Possible causes: +- 15V is not supplied. (D board), IC8003 is faulty. (A board) Symptoms of the problem: TV has entered standby state after horizontal raster, Vertical deflection pulse is stopped, Power line is shorted or power supply is stopped.
  • 5 times, Diagnosis: White balance failure (Not balanced) Possible causes: Video out (IC7101, 7201, 7301) is faulty (CR, CG, CB board), CRT drive (IC309) is faulty (A board), G2 is improperly adjusted. Symptoms of the problem: No raster is generated, CRT cathode current detection reference pulse output is small.
  • 6 times, Diagnosis: LOW B OCP/OVP (Overcurrent/over voltage). Possible causes: +5 line is overloaded. (A, B boards), +5 line is shorted. (A, B boards). Symptoms of the problem: No picture.
  • 7 times, Diagnosis: Horizontal deflection stopped. Possible cause: Q8035, 8038 is shorted. (D board)
  • 8 times, Diagnosis: High voltage error. Possible cause: T8005 is faulty. (D board)
  • 9 times, Diagnosis: Audio error. Possible causes: +- 19V line is shorted. (A, B boards), IC708 is faulty. (A board), PS701 or PS702 is opened. (A board). Symptoms of the problem: No sound
Feb 26, 2010 | Sony KP-51WS500 51" Rear Projection...
IM A TV TECH. I HAVE A SONY LCD KP-60XBR800 I HAVE NO RASTER. POWER OK, MENU OK BUT NO RASTER ON TUNER, TUNER VOLTS OK,CAN YOU HELP ME PLEASE. THANKS my email sergioaguirre0182@hotmail.com
check the high voltage with the screen control turned up high where there is no raster. suspect problem within the video circuit where there is no high voltage or defective picture tube.some time when the screen is black and the screen control advanced,you can see if the tv has video or vertical or horizontal problems on the screen.service the high voltage circuit if there is no raster or high voltage is seen.no raster can be caused by the no heater or filament in the CRT.---- a defective picture tube can cause many problems, such as, poor brightness ,missing colors,intermittent picture,poor focus,a single-colored raster,arching in the gun assembly,retrace lines in the picture,negative picture,chassis shutdown,noheater or filament lit and no raster to name a few.an open filament or heater can cause no picture or no raster symptom.a defective CRT can have an extremely bright screen.loose particles of the cathode element can lodge between the grids and cause an intermittent black and white picture. simply tap the ends of the CRT gun assembly and notice if the picture begins to flash off and on.---- with a leaky picture tube after turn on the raster dims and get extremely bright.a dim picture with no green in the raster can result from a bad green assembly. a heater-to-cathode short can cause a raster to change colour or a result in no raster at all.replace the picture tube if there is severe arching in the neck of CRT. excessive brightness with retrace lines and a vertical collapse to a thin line can be caused by a bad coil on the neck board of the picture tube.rejuvenate the picture tube when there is very bright green screen. check for the resistance change on the resistors of the CRT neck board for an excessively bright picture with retrace lines.excessive dust inside the CRT spark gaps within the picture tube socket can cause the very bright raster and the chassis shutdown.a defective video amp,luminance buffer,or reference transistor can cause a bright picture with retrace lines. -------- for getting any required parts to replace you can get it from www.radioshack.com or from www.partstore.com or from www.shopjimmy.com --------- thanks.please do rate the solution.thank you for using fixya.keep updated.
Sep 06, 2009 | Televison & Video
Sony Trinitron KV-32XBR15
You should check Pin-Amp stage for subject problem. Pin Amp is located at Horizontal area. Pin Out Transistor is suspected.
Jun 08, 2008 | Sony FD Trinitron WEGA KD-34XBR2 34" TV
Green lines
Due to vertical section failure horizontal line apprears. You did not mention about picture. Green horizontal line means with picture or without picture. With picture means there is some leakage. Without picture only singe horizontal line means vertical section totally not working. Particularly green horizontal line means maybe leads to jungle ic failure. Please mention your simptom clearly what you get and what you will not get both video and audio. It will be helpful to answer. Based on your question this is my small information.
May 24, 2008 | Sony KV-35S42 35" TV
TV has Sound but no picture
your tv set have a problem in the horizontal section of the board.have sound but no picture or no raster.contact your service tv technician to check your tv set.......anime'
Apr 05, 2008 | RCA 27R410T 27" TV
Sony trinitron 32 in. pip no video, (raster, with audio)
May 20, 2007 | Sony FD Trinitron WEGA KV-32FS100 32" TV
Televison & Video Logo
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
