Question about Inverter Welding Tools
My thermadine inverter tig welder won't start up when I touch earth clamp with tortch seems know power coming from machine can you please advise me
    Top Expert:
  • Inverter Master
  • 79,186 Answers
Check the machine fuse first.
Posted on May 19, 2017
  • 2712 Answers
SOURCE: TIG welder help
Choose the electrode to use for the project you are starting as well as the variety of alloys you'll use such as the 6061 Aluminum alloy electrode. Grind the electrode to a point. Try to create a tip and sharpen it to help it become more rounded as you weld. Place the electrode into an electrode holder with the tip about 1/4-inch away from the sheath. Choose the settings on your tig welder. The three main ones are AC, DCEP and DCEN. Choose AC for aluminum. Slide the "cleaning/penetrating" slider more to the penetrating side. Set the "air on" to five seconds and the "max amps" to 250. Turn on the gas. For aluminum, use pure argon. For steel, an argon and carbon dioxide mix. Scrub your welding table or flat piece of sheet metal with a wire brush to make it clean and flat. Gear up in full welding safety gear including hood, goggles, apron and gloves. Hold the electrode in your dominant hand and start your welding project. Check your settings every so often to make sure they haven't changed and adjust as needed.
Posted on Aug 27, 2008
  • 7 Answers
SOURCE: Miller TIG Welder Syncrowave 350XL has no digital read out...
it's free for you to download.
http://www.millerwelds.com/products/tig/syncrowave_350_lx/
Posted on Mar 21, 2009
jyackle5
  • 8197 Answers
SOURCE: Need operating instructions for Thermal Arc 190 GTS tig welder
Try this one if not it go to the next link for manuals.
http://www.thermadyne.com/IM_Uploads/DocLib_2143_300X4838.pdf
http://www.thermadyne.com/thermalarc/component/option,com_doclib/task,/id,/Itemid,237/categoryID,4/
Posted on Apr 06, 2009
  • 226 Answers
SOURCE: What kind of problems are associated with cheap inverter welders?
Welllll, they are not on par with like a $1800 hobart... They will work for light stuff, but remember, when one part in the machine fails, you have lost all 3 machines at once. Myself, I buy good used expensive welding equipment for about the same price as new cheap stuff. I can get parts & work quality is great.
Posted on Apr 12, 2009
GiantTechGuy
  • 25 Answers
SOURCE: my giant wse 200 tig inverter single phase AC/DC
Hi, remove the machines cover with the machine unplugged then look for disconencted plugs etc within the machine. careful where you place your bare hands.
Posted on Oct 18, 2009
What mig gun is on a Nevada 220BZ Mig Welder
Nevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder ...
www.ebay.com.au > Industrial > Welding > Welders
eBayNevada MIG-220BZ MIG TIG MMA ARC DC Inverter Welder Welding ... Nevada Welding machine; MIG Torch; Earth Clamp; Electrode Holder; Safety Mask ..
Dec 20, 2015 | Welding Tools
Need a hook up maual
According to the specs for this welder
You need a 50 amp breaker and #6 wire
Century/Lincoln Inverter Arc 230 DC stick welder.
  • 230 Volt stick welder compatible with optional TIG equipment. Welds 18ga to 5/16. Includes:
  • 10 ft Work cable with small dins connector and clamp,
  • 10 ft Electrode holder with small dins connector,
  • shoulder strap for portability,
  • 6-1/2 ft input cable with attached 50 Amp (NEMA 6-50P) plug
Oct 12, 2012 | Century lincoln K27901 Inverter Arc 230...
Tusten tip keeps sticking what am i doing wrong i have rockworth inverter
Make sure the tungsten tip is sharp, not too far from the nozzle and try not to let it touch the metal or molten pool. Also make sure you have an adequate gas feed
Feb 23, 2011 | Inverter 220 Volt Tig Arc Welder
Giant inverter tig mma111 230 volt
check if the load on it is not more than its capacity and check the batteries if they are still in good condition
Nov 16, 2009 | Inverter 220 Volt Tig Arc Welder
My giant wse 200 tig inverter single phase AC/DC welder wont power up when plugged in have anyone got a wiring diagram.
Sep 26, 2009 | Hobart Welders Champion 500433A Factory...
Welder not welding
The contact tip is the main source of power, if the tip is bigger than the wire then you will not get a proper conection, the earth clamp is a essential part of the system make sure you have a good earth and all the conections are tight
Jan 14, 2009 | Clarke Power Products Clarke 130EN Mig 110...
GIANT 200AMP INVERTER ARC WELDER NO POWER TO THE LEADS
remove the fan from the circuit and try it then, does it weld ok with the fan removed?
Dec 13, 2008 | Inverter 220 Volt Tig Arc Welder
I have a miller dynasty inverter tig welder   It has a help code that comes on when I turn it on the code is p-2
From the user manual for a generic dynasty model welder:
2 Help 2 Display
Indicates an open in the thermal protection
circuitry located on the left side of the unit.
Contact a Factory Authorized Service
Agent if this display is shown.
So you could have anything from a broken or disconnected wire to a bad thermal switch.
You can get user manuals specific to your welder at www.millerwelds.com
Rank this answer please,
Carl
Nov 26, 2008 | Miller DYNASTY 350 TIG WELDER w/TIG TORCH...
Welding Tools Logo
700 people viewed this question
Top Inverter Welding Tools Experts
Robert Lee
Level 1 Expert
Tom Chichester
Bud H
Are you an Inverter Welding Tool Expert? Answer questions, earn points and help others
