Question about Kitchen Ranges
Front burners on gas range won't light.
I have a magic chef 4 burner gas range. The two burners in the back will light properly, but we can't get the front ones to light at all. We smell gas but they won't ignite. Any suggestions?
  • 61 Answers
My GE gas range is really sensitive about the gap between the igniter electrode and the metal disc that covers the burner. If the metal disc is slightly off-center, no spark will occur. Check to make sure that the gap between the igniter and the nearest metal is about the same as the back burner.
Posted on Jul 25, 2009
3 Suggested Answers
  • 119 Answers
SOURCE: Magic Chef oven stops working
the ovan could be a thermostat 3" 2 6'' long probe my first gess or the ignitor top you need more help with could be a lot of things hope this helps a lititel
Posted on Feb 14, 2010
meztang
  • 112 Answers
SOURCE: i have a magic chef oven model # 61S04PAW. the
Electric gas igniters sometimes get stuck in one position causing a clicking sound. The clicking sound that you hear is the electric arc that is pulsing from the igniter conductor (wire) to ground (the gas burner). It receives power from the electrical outlet that the stove is plugged into.
Residue from food and sometimes cleaning products may be preventing the igniter from producing a spark (Arc) to the base of the burner. This is a common problem that occurs when the stove has been cleaned or food is allowed to build up. Make sure that the igniter and the burner base are clean and dry. This will help with proper operation. Oven cleaner and a small tooth brush may be used to accomplish this. Another problem with ignition may occur if you have too little (touching) or too much space between the igniter and the base of the burner; it will prevent the burner from igniting. You should only have a little more space than the thickness of a nickel between the burner base and the igniter. A good “blue” arc from the igniter to the burner base is optimal. If this doesn’t work, you may need to replace the electric igniter module. Good luck.
Posted on Jul 18, 2010
Back burners wont light
Remove the back burners top lids and using a good blower jet and a good brush clean up the areas around it. this must allow the mixing of the gas properly. try to light. if this wont solve you will need to open the front flow controller, remove the knob, check from within after opening the top lid for the jet screw, open and clean and use a pin for cleaning. reset the flow controller after checking for gas flow into the flow controller. now set back and the burner should light up. Hope this helps you out. Good day
Jul 14, 2010 | Magic Chef 31000 Gas Kitchen Range
I have a magic chef oven model # 61S04PAW. the
Jul 07, 2010 | Magic Chef 31000 Gas Kitchen Range
Magic Chef gas range ignitor continually clicking
One of the burner control switches is shorted. If they are not overly expensive I replace all 4 while it is apart.
Eric
Feb 23, 2010 | Kitchen Ranges
Feb 13, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Gas smell oven does not light
you may need new coupler on pilot system
Jun 23, 2009 | Magic Chef 9122 Gas Single Oven
Slow heating- low gas to burner
The main solution of it is to clean the gas tube.
May 18, 2009 | Magic Chef CGR3730 Gas Kitchen Range
REAR RIGHT AND LEFT FRONTBURNER WON'T IGNITE
The most common problem for gas surface burners is that they get gas but don't light. This is generally caused by dirt or grease splatters on the burner itself. Residential-grade range/stove burners are round and have small holes around their perimeter to allow gas to flow out and create a round flame. The gas coming from these holes is often ignited by a small vertical row of holes on the side of the burner. If these vertical holes are clogged or obstructed, the gas can't ignite.
The solution is to clean the burners thoroughly. Use a toothpick to clear the small vertical holes, then allow the burner to dry completely and try lighting it again. If it doesn't light immediately, repeat the procedure
May 12, 2009 | Magic Chef CGR3742 Gas Kitchen Range
Magic chef gas stove has flames coming from the bottom
Replace the burner. Quickly. Do not use that burner until it is replaced.
Apr 23, 2009 | Magic Chef 31000 Gas Kitchen Range
Oven not lighting
Sounds like the ignitor in the oven is weak and not building up enough resistance to the gas valve to allow gas to the burner. I would replace the ignitor if it is more than 3 or 4 yrs. old.
Oct 05, 2007 | Magic Chef 31000 Gas Kitchen Range
Kitchen Ranges Logo
189 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
