How does a butterfly adapt to its environment
I need to know how to check a automatic choke if it is working or not
Remove air filter, look down carb. Choke butterfly is on top. When choked, butterfly closes opening. When choke off, butterfly up, you can see the throttle butterfly.
Dec 01, 2013 | Cars & Trucks
How can i get a mic stand mount for my mic? The Piece That holds the mic is broke and i want to know where i could get another one at...any help
If you can't locate one via a Samson dealer (try Amazon) the next best thing would be to go to a musical instrument store and buy a universal (butterfly) mic clip. These have one of 2 standard screw threads on the bottom (you can get an adapter for the other size if it doesn't come with both) and will fit most mic stands. Because of the butterfly design they will take almost all microphones except the fattest ones - which need a soft rubber clip designed for 'radio mics'
Jan 28, 2011 | Samson C01U Consumer Microphone
Im using packard bell butterfly s-fc-002ac problem is the battery is not charging even if it is connected to an adapter. the battery status always indicate: 7% available (plugged in, not...
Hi, There is a possibility of problems in:
  1. the adapter that you are using might be defective
  2. or the port for the power is not working
  3. or the battery fault issue
What you can do is to try another outlet to see if the outlet itself is the cause. Cheers!!
Sep 01, 2010 | Packard Bell Computers & Internet
How can a butterfly help a plant and how does the plant help the butterfly.
If this is a serious question, then i shall attempt to answer it. Butterflies help plants by gathering pollen on their bodies and antennae while consuming nectar form a flower (which, incidentally, is how the plant helps the butterfly - by feeding it). The butterfly then flies off to another flower for more food and tranfers the pollen to this plant, enabling pollenization (fertilization) which is how plants produce fruit (which benefits animals like us humans) and create seeds to reproduce. It is win-win-win.
i wish you all the best on your quest for information and philosophising.
Oct 20, 2009 | 3d Rose Butterflies - Monarch Butterfly -...
Butterflys are eating everything in my garden, what can i do about it
butterflies don't eat anything. Their caterpillars do though. You will have to either spray your plants or find the caterpillars and remove them
Aug 16, 2009 | Park Seed Butterfly Bush Butterfly Plant...
Condensation error
Only thing you can do is let the camera set indoors and acclimate to the environment. The same if you are going from cold to hot or hot to cold places. A humid place like a botanical garden or such as a zoo reptile area or a butterfly pavilion or an aquarium will cause this as well. If you are in your home and it doesn't go away (give it up to 12 hours) try a dry head cleaner cassette.
Aug 15, 2009 | JVC GR-D870 Mini DV Camcorder
How to install Fuji Finepix 2650 in Windows VISTA environment?
All Fujifilm digital cameras will work on Windows Vista using drivers already installed on the operating system.
The finepix viewer software supplied with our cameras will require a update which can be downloaded from the following link
The following products are not compatible with Windows Vista:
FD-A1/FD-A2 (Floppy Disc Adapter)
DM-R1 (Image Memory Card Reader)
DPC-R1 (Image Memory Card Reader)
The following products are compatible with Windows Vista:
SM-R1/SM-R2 (Image Memory Card Reader)
PC-AD3 (PC Card Adapter)
DPC-AD (PC Card Adapter)
DPC-CF (CF Card Adapter)
DPC-UD (USB Pen Drive)
Nov 11, 2008 | Cameras
AC adapter-turn OFF or go into stand-by mode???
When the power is provided through AC adapter, the camera will NOT automatically turn OFF or go into stand-by mode. This is useful when using the camera in a studio environment.
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
AC adapter
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
