Question about Vacuums
MyBissel is not sucking up the water. Where is the dirtywater
2 Suggested Answers
SOURCE: Hoover Steam Vac Model #5899-100
there is a single screw at the top of that shield (under the dirty water tank) and then there is 2 screws on the bottom that you unscrew and the shield will slide right off and you wipe it out and put it back on.
Posted on Nov 25, 2007
My son accidentally sucked up some water with my dyson animal and now it has stopped working. Is this permanent or will it come back ?
It depends how much water and how long the motor was run after sucking up water. If it was just a little water, most of the water should have been caught in the dust compartment. If there was enough water that it was able to suck it past the filter and into the motor it could cause motor failure.
Nov 30, 2016 | Dyson Vacuums
Not sucking up the water
Look at the pickup nozzle to see if it's plugged up. There is a flapper valve that closes when the tank has too much water in it. Make sure it opens after you dump the water out.
Aug 14, 2016 | Bissell Carpet Cleaner Powerbrush Deep...
Rapide XL. Why isn't it sucking up the dirty water?
you need to set it lower for water
Aug 10, 2015 | Vax Vacuums
Can not get my steam vac to suck up water everything else works.done half floor empty water to do other half of floor and it just stopped sucking up water
  • There a twist lever on the side to change from floor to tools. If "everything else works" then you have it on tools. Twist it back to floor and it will work.
Sep 11, 2014 | Hoover Steam Vac Dual V w/ SpinScrub...
My bissell will not suck the water
Check User's Guide for filters. One under the water tank cap (looks like a small screen) and one under Flow Indicator. Bissell Consumer Care 1-800-237-7691
Jul 18, 2014 | Bissell Proheat 2X Select Pet Upright Deep...
My carpet shampooer is not sucking up water?
Hey Karen, having no suction when cleaning can be a bummer.
Here's a quick link to troubleshooting steps to assist you:
http://www.bissell.com/FAQDetail.aspx?id=1117&cid=ccsocial
Feb 04, 2013 | Bissell 1699 ProHeat Clear View Upright...
Hoover carpet cleaner blowing not sucking
While the blower has different source that the sucking of water, the passage for the sucking of water needs to be cleaned to eliminate any blockage within the passage.
Apr 12, 2010 | Hoover SteamVac F5914-900 SpinScrub...
Nov 20, 2007 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
19 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
