Question about Delta Tools & Hardware - Others
What size of belt for delta 1 inch belt sander?
    New Friend:
  • 26 Answers
You would have to list the specific model number listed on the side of the factory sticker for me to pull it up on their site..or measure from outside of the front wheel to outside of the other wheel on the rear. should give you an accurate belt length.good luck
Posted on May 19, 2017
Need the size and thread pitch for my Delta disc/belt sander wheel set screw
Probably an 8-32 or 10-32 (possibly a 10-24) or even a 1/4-20. You can get small packs of these size screws at most hardware stores so would be cheap to busy one of each and try and once you know the size you can get a set screw of that size. Another crude way is to see what size drill bit will fit into the threaded hole. If a 3/32" goes but a 7/64" doesn't or fits tight, it is a size 6 (likely 32 threads per inch (TPI). If a 1/8" bit goes but a 9/64 doesn't or is really tight then it is a # 8 size. (8-32 is most common). If the 9/64 goes freely but a 5/32 doesn't it would likely be a 10-24 whereas if the 5/32 does go but an 11/64 doesn't then figure it to be a 10-32. Finally, it could be a 1/4-20 if a 3/16" bit goes but a 13/64 doesn't or is fairly tight. If it is really big and a 1/4" bit fits the hole then it is likely a 5/16-18.
Apr 18, 2015 | Delta 4" Belt 6" Disc Sander 31-460
What is the length of the 1 inch belt on the delta 1 inch belt/5 inch disk
You did not post enough information because there are more than one model anyhow most are 1" x 30" others are 1" x 42"
Dec 16, 2014 | Delta Tools & Hardware - Others
What size belt does it use
You did not mention a model number, but the is probably the width of the belt and the 6 is probably the diamter of the disc.
The sanding belt size is probably a 4" wide by 36" long, but it may be 4 x 24" long. Put a string around the rollers, and then stretch the string out straight. Measure it and that is the belt length.
You can find either size belt at sites like and
Jan 25, 2011 | Delta Machinery 4x6 Belt/Disc Sander
I have and OLD bench 1
The local hardware store has brushes in all different sizes in a box, next to the switches, fuses, plugs, cords, tool type stuff. They are standard sizes, should be able to find them no problem. Hope this helps.
May 25, 2010 | Campbell Hausfeld Tools & Hardware -...
My delta sander stalls while sanding on the belt.
Mine was underpowered from the get go. I have since sold it. Keeping it well lubricated does help though.
Jan 23, 2010 | Delta Machinery 4x6 Belt/Disc Sander
User Manual for Delta 31-460 Sander
I'm not sure if this is the correct way to post a response, but I have a manual for Delta 31-460 sander. Let me know if you still need one.
Jul 20, 2009 | Tools & Hardware - Others
Changing the sanding pads
You use a 1/2 inch socket wrench to remove the nut at the top of the spindle shaft, slide the old sanding sleeve off and the new one on.  Replace the nut.  You may also have to insert a different size table insert if you are changing the sleeve size.
Instruction manual is available free at:,sa350k.pdf
May 30, 2009 | Delta SA350K Shopmaster Boss 1/4...
Tools & Hardware - Others Logo
80 people viewed this question
Top Delta Tools & Hardware - Others Experts
Andrew Taylor
Andrew Taylor
John Trevino
Are you a Delta Tool and Hardware - Other Expert? Answer questions, earn points and help others
