Question about Jandy Ae2500t 115,000 Btu Heat Pump
Digital read out....fault high ref pressure.
Bought new jandy AE2000 pool heat pump in may. worked fine up til now. digital read out says ***fault*** high ref pressure. POOL filter is running fine. What can I do?
  • 78 Answers
Verify circulating pump is on and that there are no water flow restrictions to the heat pump. Make sure all necessary valves are open or in the proper positions to allow proper water flow to the heat pump. Verify filter and skimmers are clean. Check for water level in the pool. This condition may also appear if the heat pump has not been operated for an extended period. To clear the condition, cycle the heat pump, on and off, up to 3 times. If this does not correct the problem, call for service.
Posted on Apr 22, 2010
Fault low ref pressure. how do i fix this?
check to see if filters are clean if so check to see if voltage on both sides of pressure switch if not either need new pressure switch or copper line is plugged
Nov 28, 2013 | Jandy Ae2500t 115,000 Btu Heat Pump
Fault Low Flo Pressure
check pressure switch and copper tube to it
Nov 04, 2012 | Jandy Air Energy Heat Pump - 100,000 Btus
Error code High Ref Pressure on a jandy AE 3000T-R
Make sure your water filters are clean and if you have an external by-pass, make sure it is not open. High Ref Pressure is normally caused when the refrigerant is not cooled off by the pool water circulating thru the heat exchanger. If your filter pump is not circulating enough water (normally around 40gpm) in the system then you will trip the high pressure sensor. If the HP sensor trips without the compressor engaging the try replacing the sensor.
Oct 26, 2012 | Jandy Pool & Spa
Low ref pressure
check filteres if clean check pressure switch voltage both sides should be 24 volts
May 18, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Heat pump low ref pressure
ee if filters are clean then check pressure switch to see if voltage on both sides should be 24 volts ac if not pressure switch bad or copper line plugged
Apr 02, 2012 | Jandy Ae2500t 115,000 Btu Heat Pump
Jandy LX250 natural gas pool heater will not start heating. Turns on but no heat. Low Pressure Flow
if filters are clean check pressure switch see if 24 volts ac on both sides if not check copper line for clog if ok bad pressure switch you can jump just to check
Mar 27, 2012 | Jandy LAARS LX250 - PROPANE, DIGITAL...
Jandy AE.TI AE3000T .263 BOARD SHOW FAULT SHORTED H20 SENSOR
The H20 sensor is the Pressure Switch. Locate the pressure switch, remove the two leads and jump them together. If the error code goes away, you need a new switch. If not, it could be a software, or other hardware issue.
Jan 08, 2010 | Jandy Ae2500t 115,000 Btu Heat Pump
Low pressure reading on Pool Heater
I had this problem with ours last year. I replaced the water pressure switch and it began working fine. We later had a symptom that the blower would start but it would not ignite. The ignitor rod was corroded so I took it out and sanded it with some sandpaper---worked fine...until I dropped it trying to reinstall and it broke. Bought a new one and it works fine now.
Today's problem is related to the blower now.... it is always something, isn't it?!?
May 10, 2009 | Jandy Laars LX Pool Heater / 400,000 BTU /...
Fault shorted H2O sensor??
the sensor goesw into the header unscrews with two black wires
May 02, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
High Refridgerant Pressure
I was able to find the manual online which had the solution in the troubleshooting guide.
Jan 25, 2009 | Jandy Ae2500t 115,000 Btu Heat Pump
Jandy Ae2500t 115,000 Btu Heat Pump Logo
660 people viewed this question
Top Jandy Pool & Spa Experts
David Spradling
David Spradling
Craig Butler
Craig Butler
Jay Finke
Jay Finke
Are you a Jandy Pool and Spa Expert? Answer questions, earn points and help others
