Question about The Office Equipment & Supplies
Wooden block has a volume of x cubic feet what is the volume in cubic inches?
SOURCE: cubic feet
4' = 48"
thickness" x width" x lengh" = cubic inches
2" x 8" x 48" = 768
1 cubic foot is 144 cubic inches
768 divided by 144 = 5.3333333333------
Posted on Dec 10, 2008
  • 61 Answers
SOURCE: how many cubic feet is the Kenmoore model#110
Posted on Jan 25, 2009
  • 1230 Answers
SOURCE: How many cubic feet is this freezer
After looking over their website, which is not very helpful, it appears that it would be approximately 5.0 to 5.2 cubic feet. It seems that in most cases, the model number contains the size. Check it out at
Hope this helps.
Posted on May 19, 2009
  • 13 Answers
SOURCE: Need to know what cubic feet a 2005 Model #
Posted on Jul 31, 2009
  • 15935 Answers
SOURCE: Cubic Feet of Washer
3.2 cu ft.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Can you help me i need a pump that will produce 1 GPM thru 250' x 1/2" tubing @ 10psi
You can convert pipe size to gallons per minute of flow by calculating the cross-sectional area of the pipe and making some reasonable assumptions about pipe volume and the rate of flow. Pipe sizing is measured by the internal diameter of the pipe, not the overall outside diameter. Once determined, the overall volume can be calculated. Pipe flow is described in gallons per minute. Shorter lengths of pipe will have a greater flow than a longer length of the same diameter. This is caused by internal resistance of the pipe itself. By the same reasoning a larger diameter pipe will have a greater flow or GPM than a smaller pipe at the same pressure or flow rate. Pressure is described as pounds per square inch. The square-inch measurement is determined by the area of the pipe. The pounds are the amount of force that is placed on the liquid to push it through the enclosed space.With that background, you can estimate the flow based on the pipe size.
Find the cross-section area of the pipe. Area is equal to pi times the radius squared or a = 3.14 x r2. A two-inch diameter pipe would have a cross-section area of 3.14 x 12 or 3.14 square inches.
Understand that water has a certain pressure associated with the height of that water. One pound of water pressure, or 1 PSI, is equal to 2.31 feet of elevation in height. In other words, a 1-inch column or pipe of water that is 2.31 feet high will have a pressure of 1 PSI. The overall height -- not volume -- of the pipe corresponds to the pressure. A 6-inch diameter pipe that is 2.31 feet high will only have 1 PSI.
Find the volume of the 2-inch diameter pipe in Step 1 that has a length of 10 feet. Ten feet is equal to 120 inches. Multiply 3.14 square inches, the cross sectional area, times the length. The volume of the pipe is equal to 376.8 cubic inches of volume.
Convert cubic inches into cubic feet. One cubic foot equals 1,728 cubic inches. Divide 376.8 cubic inches by 1,728 cubic inches per cubic foot and the answer is .218 cubic feet. This means that the 2-inch diameter pipe that is 10 feet long has an internal volume of .218 cubic feet.
Calculate the amount of water that can be contained in the section of pipe at any given time. One cubic foot of water is equal to 7.48 gallons. Multiply 7.48 gallons by .218 cubic feet and the amount of water in the pipe is equal to 1.63 gallons.
Find the GPM if the flow of water is one foot per second. Multiply the one-foot per second flow by 60 seconds per minute and the flow is now 60 feet per minute. In other words the water will flow through the 10-foot pipe six full volumes for every minute. Since the piping contains 1.63 gallons per 10 feet of pipe, multiply 1.63 by six and the final GPM is equal to 9.78 GPM of water flow from the 2-inch diameter pipe.
Jan 19, 2018 | Plumbing
09 cubic feet= how much inches
9 cubic feet is 20736 cubic inches.
Oct 31, 2016 | Office Equipment & Supplies
How many feet is 210 cubic inches
Foot is a measure of length, cubic inch is a measure of volume.
If you'e asking about cubic feet, 210 cubic inches is about 0.1215 cubic feet.
Feb 21, 2015 | Office Equipment & Supplies
The width of my refrigerator is 27. Inches. What is the cubic feet
That depends on how high and how deep the refrigerator is.
For example, if the height and depth are both 27 inches then the volume is about 11.39 cubic feet. If the height is 36 inches and the depth is 27 inches then the volume is about 15.19 cubic feet.
May 25, 2014 | Refrigerators
Cubic feet calculator
What unit are the numbers in?
40 feet by 45 feet by 5 feet is 9000 cubic feet.
If the numbers are in inches then the volume is about 5.2 cubic feet.
If the numbers are in meters then the volume is about 317,832 cubic feet.
Apr 03, 2014 | Office Equipment & Supplies
Inch is a unit of length. Cubic foot is a unit of volume. There is no direct conversion between them.
If you're asking about cubic inches, 22 cubic feet is 38,016 cubic inches.
Jan 14, 2014 | Office Equipment & Supplies
Inches to cubic feet
Inch is a measure of length and cubic feet is a measure of volume. There is no conversion between them. It's just like trying to convert inches to gallons, it can't be done.
Now if you want to convert cubic inches to cubic feet, that's possible. Since there are 12 inches to a foot, there are 12-cubed or 1728 cubic inches in a cubic foot.
Jan 10, 2014 | Office Equipment & Supplies
How much is one cubit, to inches?
1 cubit [Roman] is 17.4803149606 inches
If you are referring to cubic feet to inches then you need cannot when cubic feet is a volume measurement and inches is a length measurement.
Jul 17, 2010 | Acme Automotive ACMA680CS Typhoon High...
Size of older GW Microwave
If you want to calculate the volume of an object and have the answer in cubic feet.
Volume=Length X Width X Height
With the dimensions you give
Volume=12.5in X 37in X 20in
Volume=9250 cubic inches
To convert 9250 cubic inches into cubic feet you need to understand that there are 1728 cubic inches in 1 cubic foot.
L X W X H = 12"X12"X12"=1728 cu in
You then multiply 9250cu in and (1/1728cu ft) Really you are dividing 9250 by 1728.
your answer is 5.35 cubic feet.
12 inches in 1 foot
144 square inches in 1 square foot
to convert you put the unit you want to keep on top of the dividend.
to conver to to feet ( randomly selecting 100 inches)
Example converting 100 inches to feet
100inches X ____1ft____ = (100/12) = 8.3 feet
or cubic inches to cubic feet
4000 cubic inches to cubic feet
4000cu in X ____1cu ft____ = ( 2.33 cu ft)
1728 cu in
if you notice that the units on top and bottom of the dividend cancel each other out leaving the numerator (top number) as your unit.
it also works in reverse
2.33 cu ft X ___1728 cu in____ = (4000 cu in)
1cu ft
Jun 03, 2008 | GE JE1540 Microwave Oven
Top The Office Equipment & Supplies Experts
Ian White
Level 1 Expert
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
