Question about Panasonic Lands Phones
Hi, how can I forward the phone call on Panasonic Kx-T7633 to my cell.
SOURCE: Call forwarding on Panasonic Kx-T7633
I have a KX-T7633 and I want to be able to forward calls to my mobile after approx 3 to 4 rings when not answered
many thanks
Fintan
Posted on Dec 01, 2008
cnavarro
  • 2460 Answers
SOURCE: PANASONIC KX-TDA-50 PHONE SYSTEM WITH
From the main phone, press PROG **1234 and dial 004. Press ENTER 2 times (watch out, it moves on the display) and you will be looking at 101 : OPERATOR if it's still unprogrammed. Keep pressing NEXT until you get to the one you want to change and use a combination of the keypad and the AUTO ANS button to spell out the new name. The STORE button saves it, the right arrow and clear button step back and forth on the line you're entering.
You can pick up the handset and drop it back into the cradle when you're done to exit.
Carl
Posted on Jan 21, 2009
SOURCE: cannot get the correct time set on the phone.
Try this....
For Panasonic system (especially for KX-T7633), you have to make changes from extension 101.
1. leave handset in the cradle then press "program".
2. Dial *# then "SP-PHONE" button until you see something like time set something something
3. manually input correct date then time then press "auto dial/store" button.
4. pick up the handset then hang up to save.
Posted on Aug 24, 2009
ybchuan
  • 201 Answers
SOURCE: Hi, How do you change the time on a Panasonic
There are several way that may adjust the Panasonic phone clock, please try the following suggestion method:
Method 1:
1) Press PROG soft button, follow by HOLD button.
2) LCD show direct the time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press END or HOLD to end the setting.
Method 2:
1) Press PROG soft button, follow by HOLD button, follow by # button.
2) LCD show time adjust, key in the correct time, let's say 8.15am, so key in 815 and press STORE.
3) Press again # button to select between AM and PM mode.
4) Press again STORE to save the setting.
5) Press END or HOLD to end the setting.
Method 3:
1) Press PROG button, follow by key * * 1 2 3 4.
2) Press key 0 0 0 to display the day/time setting.
3) Press |> or SP-PHONE button if u wish to change the date.
4) Press |> or SP-PHONE button to change the time.
5) Press CLEAR or TRANSFER button to change current hour entry.
6) Press |> or FWD/DND button to change current minutes entry.
7) Press |> or FWD/DND button again and AUTO ANS button to change between AM or PM.
8) Press STORE to save the setting.
9) Press END or HOLD to end the setting.
Hope these help.
YBC (/\)
Posted on Oct 19, 2009
ybchuan
  • 201 Answers
SOURCE: Headset set up on a KX-T7633
First make sure that your headset is really compatible with the Panasonic phone. After plug in the headset to phone then u need to enable the headset mode. To do this:
1) Press PROG.
2) Press program no. 61 (headset mode) and then press ENTER or STORE.
3) Press selection no. 0=OFF, 1=ON headset mode and then press ENTER or STORE again.
4) Press EXIT or PROG.
YBC (/\)
I have a Panasonic KX-TA624 I would like to forward calls to a mobile phone is tis possible
as long as you have COS 'class of service' rights you can dial -
*7102 9 (phone number) #
this will forward all your calls
to cancel - dial *7100
Mar 15, 2011 | Panasonic KX-T7633 Corded Phone
How do i divert the Panasonic KX-T7633 to a mobile?
Dial *7105 then 9 then number to dial then #
call forward external needs to be enabled on your system
Nov 12, 2010 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T7633. trying to send calls to voicemail when user is on the phone. if a user is on the phone and someone calls, the calls wont go to voice mail
From your phone did you dial the *7105 command for call forward busy/no answer? You need to add the voice mail box to the rest of the command followed by #.
Mar 12, 2010 | Panasonic KX-T7633 Corded Phone
Answer machine
Panasonic KX7633 is a Key telephone set, it doesnot have answering machine function. whereas you may divert your calls toan analog extn.by call forwarding.
Jul 06, 2009 | Panasonic KX-T7633 Corded Phone
many thanks
Fintan
Nov 19, 2008 | Panasonic KX-T7633 Corded Phone
Panasonic KX-T633?
If it were my choice, I'd set up an ICD number and forward that to an outside number. Something like pick 400 or 600 plus your extension like 605 (they tend to be defined by default), and go into the group fwd command to dial your cell numbers.
Any call placed from anywhere, either VM, internal, or transfer will go out on another line and dial your cell...assuming you put the fwd number in both places.
Carl
Aug 20, 2008 | Panasonic KX-T7633 Corded Phone
CORDED PANASONIC KX-T7633
I cannot forward calls to other phones when another incoming call is ringing In. All the other extensions light up as busy. How do you do this ??????
Apr 23, 2008 | Panasonic KX-T7633 Corded Phone
How to forward calls using KX-T7633 ?
press 'program' - at the top of the phone
enter 50
press ' enter'/ auto dial store
enter 4
enter the extension you wish to transfer call to
press auto dial store
to take call forward off
press program
enter 50
press 'enter' auto dial store
press 0
press auto dial/ store
this should work!
Sep 03, 2007 | Panasonic KX-T7633 Corded Phone
Lands Phones Logo
63 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
