Question about Ovens
Is 1800 273 8255 a legitimate phone number for prevention of self-destructive behavior?
Need cleaning instructions for tappan self-cleaning oven model number TEF351EWE
Before you go working too hard to get you oven to go into the self clean mode(self destruct)....check out this tip...
Self Cleaning Oven Problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!!
Jan 24, 2011 | Tappan 30IN ELEC IGNa Oven
How do I use the self cleaning feature on a GE Self Cleaning oven model VJ33VWLW-3?
heatman101
Jan 09, 2011 | Ovens
How do you turn on the self cleaning oven
heatman101
Dec 26, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Oven door will not lock for self cleaning
heatman101
Nov 29, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Self cleaning stops after about 1 hr with error code F5E5
heatman101
Nov 18, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
The circut breaker on the rear of the stove trips and must be reset every time the oven self cleanui=ing is engaged (Model # PLES399EC). How can this be fixed or prevented?
The best thing to do is not use your self cleaning feature....
Whoever invented that has caused way more problems then it solved...
It is a featured designed pruely to sell product because people are inherently lazy and because it burns up good products and then they get to sell more...
heatman101
Nov 15, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
How to use the self cleaning feature?
Hi, Before you go working too hard to get you oven to go intothe self clean mode(self destruct)....check out this tip...
heatman101
" Wish I had read this first. I never would have used the self cleaningoption. Thanks for the info!!
Nov 06, 2010 | Ovens
Need to know how to set self cleaning ge p7 self cleaning oven
heatman101
Sep 24, 2010 | GE Ovens
My wall oven wont self clean because the automatic door lock wont lock what part do i change
Hi- The automatic door lock is a safety feature designed to prevent opening of oven door during 'self-clean', or as techs call it: 'self-destruct'. A previous full-power cycle has affected or destroyed a circuit or switch. The most common failures are the door switch, affecting the operation of door motor, or the control itself. - - -Start by replacing the door switch- available locally at an app. parts store. The electronic controls can also get 'cooked', causing a variety of faults, but these controls are expensive.------ On site diagnostics is needed many times. Remember---'self-clean' destroys circuits and controls eventually--every time. Don't let the salesman fool ya... Let me know if this info helps- have more if needed.  Thanks- Ed
Mar 16, 2010 | GE Ovens
I am trying to run the self cleaning oven and keep getting a toubleshooting code of e1 f5. Not sure what this means or how to fix it/
Hello- The code you describe- E1 F5 - indicates a problem with the door switch. This little switch tends to fail during or after the 'self-clean' function is used. The switches are difficult to get to on some of these units so plan on just replacing it with a new one. This part is available locally at an appliance parts store with a complete model # from range tag. When power is re-connected, door motor should cycle back to correct position. Remember- techs call it 'self-destruct', so avoid 'self-clean'. The tried and true cleaning methods are a lot less destructive on the circuits and electronics. Let me know if this info helps- have more if needed. Thanks- Ed.
Mar 15, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
Ovens Logo
14 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
