Question about Keurig Coffee Makers & Espresso Machines
I have a keurig when the water is dripping into the cup water runs out from the bottom of the machine.
  • 60 Answers
SOURCE: The Keurig is heating up the water, yet is does
Descale, Clean out the needles with an unfolded paper clip, Take out the K cup holder and clean it out
Posted on Mar 23, 2010
SOURCE: when i put the coffee cup in the keurig....nothing
use a small needle, paper clip or pipe cleaner and run it up into the "needle" section under the lid that pierces the top of the cup. The problem is one you will have often as coffee grounds get up in there and dry between uses and clogs the hole.
Posted on Jul 09, 2010
  • 40 Answers
1. Power off machine.
2. Using a metal paperclip, insert it into left side of top needle. It must insert at least 1" deep. Insert it into slot on right side and again from back of needle.
3. Remove KCup cradle. Separate bottom from top. In the top section, insert the paperclip up into bottom needle from the bottom upwards. It will not go all the way thru and this is normal.
4. Reassemble KCup cradle and reinsert it back into coffee maker.
Posted on Oct 07, 2010
SOURCE: I received a Special Edition Keurig for Christmas.
I had a similar problem, I solved it by removing the K-Cup holder assembly, and pulling the small bottom piece off (it just pops off easily). From there you can access the "Exit Needle", which is where the coffed comes out and which is prone to getting clogged with grounds. Once you pull that bottom piece off you can run a paper clip or something up through the bottom of the needle and dislodge any clogs. This procedure was listed on page 13 of my manual and worked great!
Posted on Feb 20, 2011
heatman101
  • 43501 Answers
SOURCE: My Keurig does not brew
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
';][-0
Posted on Feb 26, 2011
Algae in keurig
Not sure about your make and model of coffee maker. But I have a drip stye and peculator type about six cup coffee maker and I use a diluted mixture of a half cup vinegar and 2cups water and run it through the machines every few weeks and follow with a couple plain water treatments.This creates a hostile environment for all critters, algae, fungus, ants, bacteria etc.
Sep 03, 2012 | Keurig Special Edition B60 Coffee Maker
Cusinart coffee pot single serve with kuerig cups switch won't turn on
The problem is often that the machine develops a leak in the hose that is right over the transformer...the water drips onto the transformer and kills that... then you have no power to run the machine.
Here is a tip that I wrote about this problem...
Keurig One Cup Coffee Brewer will not turn on
heatman101
Sep 01, 2011 | Cuisinart Keurig B50 Single Cup Coffee...
When my machine makes a cup of coffee it continues to drip water after the brew process - when you remove the K-Cup it dumps about an ounce of water.
There's a needle that punches a hole on the bottom of the K-cup. That needle is clogged. Poke it with a paper clip or a thinner wire to unclog it.
Aug 23, 2011 | Keurig Special Edition B60 Coffee Maker
Won't pump when you put the cup in just a drip tryed diffrent cups but just a drip comes out when there is no cup the water comes out and it is hot
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
May 23, 2011 | Keurig Platinum B70 Coffee Maker
I received a Special Edition Keurig for Christmas. Worked fine untill this morning. It drips very slow to make a cup of coffee. Won't even make a 2 nd. cup. There's water in it. It say's ready to brew....
Feb 12, 2011 | Keurig B66 3-Cup Coffee Maker
Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Mar 25, 2010 | Keurig B60 Coffee Maker
Unit will not brew when pod is inserted; works w/o pod however.
This may be one of two issues:
1. The pump is malfunctioning which can cause the internal reservior to not completely fill which causes issues during brewing. My unit dribbled random amounts of water instead of brewing for about a week before the pump died completely.
2. The puncture seal isn't in the right position. Open the Keurig fully so you can see the sharp puncture pin. Very Carefully push the black rubber gasket around it all the way up. Then pull it back down about 1/16". Brew a cup, if the problem continues, try sliding the gasket further down by increments of 1/32".
May 29, 2009 | Keurig Ultra In Home Single Cup Brewer...
Coffee Makers & Espresso Machines Logo
32 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Oloyede Monsuru
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
