Question about alexa.com Computers & Internet
MYAlexa blinks at 2 second intervals when plugged in and no activity in progress. Is this normal? Hoe stop rather than unplg!?
3 Suggested Answers
ctf1800
  • 4402 Answers
SOURCE: power light blinks at one second intervals
· http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
· http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Posted on Dec 19, 2007
rickead1
  • 1998 Answers
SOURCE: On permanent press cycle, washer
hello
ok fisher and paykell im assuming due to the lights what is the model number of your machine?as to that error code its saying display to motor controller communication error primary source display module action replace display module
secondary source motor control module action replace motor control module also says if new motor control corrects the fault replace original display module and this is in there tech sheet definetly call a technician i cant see anyone having to buy two parts to figure out which is bad once these are code for 2 and 7 light just have to double check that those were the lights that you are seeing if you have any further questions message me back and please remember when our chat is concluded to rank how this opinion has helped in your appliance situation Thanks again Rick
Posted on Jan 02, 2011
Change filter signal
Hi, Dim here is how to reset/adjust Engine Service Interval (Wrench icon)
Upon selecting this item, there are two possibilities. If the Wrench icon is active, you will have the opportunity to clear it--proceed directly below. If the Wrench icon is not active, then skip over the next section to "CHANGE ENGINE SERVICE INTERVAL".RESET WRENCH ICON:
1. The display shows CLEAr and no.
2. Press and release SCROLL to alternate between no and yES.
3. Select yES if you wish to reset the wrench icon.
4. Press and hold SCROLL for 4 seconds.
5. WS appears in the display.
6. Release SCROLL.
If you selected no, you will not proceed to the next section; the display will revert to the Service Setup Menu.
CHANGE ENGINE SERVICE INTERVAL:
To get to this point, the Wrench icon must not be active or you just now reset it, as above.
1. The display now shows either CLK or km/h (or Mph).
2. The display now shows the number of hours between Wrench icon reminders. The factory setting is "0044".
3.The 2nd digit of the hours value will be blinking:
In addition, the display also shows the Oil Can icon above the word "OIL", and the "CLK" indicator is present. The presence of "CLK" indicates the interval occurs based on time (this can be altered for the Wrench icon, but not for the Oil Can icon).
Good luck and have a nice day
Jan 31, 2016 | Motorcycles
Klv32s310A sony bravia gets start on with green light and after a second turns to stand by mode blinking the red light 6 times after each 2 second interval
Hello Sagar,
green led means tv powered on and status ok.
Red blinking light almost always means defect, overcurrent or overload.
6 blinks for Sony lcd flat tv means trouble in backlight circuit, or backlight inverter (backlight illumination or lighting makes your tv screen visible).
common problems in the inverter circuit, which drives the backlight, or shorted drivers, or short-circuit transformers or open circuits.
You should find the problem in the inverter circuit, or in the power supply board or in the main board.
Also look for bad capacitors (electrolytic caps) which are bulged and swollen on top.
Decoupling plugs from printed circuit boards can help you in finding the problem board by elimination method.
If you power up the set after unplugging certain plugs on f.e. the inverter board , this could result in getting a green power led and concluding that this board is faulty.
succes,
Walter from Antwerp, Belgium.
Dec 30, 2014 | Sony Televison & Video
Stuck in wash cycle
More than likely the control panel is the problem, about $200 for the part on average. For more help and parts contact this website. Appliance Parts Lawn Mower Parts Heating Cooling Parts 365 day returns
Jun 29, 2017 | KitchenAid Washing Machines
Status light blinking
Sometimes the fan overheats. Pull the power plug out of the back for about 15 - 20 minutes. Then plug it back in. 95% of the time that will solve the blinking status light problem.
Feb 20, 2013 | NEC NP2000 Multimedia Projector
I have a sylvania dvd vcr combo and the progressive scan light is on and it wont play dvds. How can I fix this?
Try the (Goldstar and Zenith) trick - with the unit on, but no discs inserted, press and hold STOP button on the front (not the remote) for 10 seconds, then release. This should revert progressive back to normal interlace output for your TV and may also turn off the progressive LED indicator on your unit.
I mentioned 2 other brands in parentheses - because the (press and hold STOP for 10 seconds) trick works for progressive on those.
Apr 10, 2011 | Sylvania (SRDD495) DVD Player/VCR
My Tuono r factory has suddenly stopped firing on the rear cylinder ( no spark at the high tension lead ) and a large service icon has appeared on the screen. Any suggestions? Thanks, Ken
Hi, Exhaustma498 here is how to reset/adjust Engine Service Interval (Wrench icon)
6. Release SCROLL.
For more information about your issue, please visit the websites below. Good luck and have a nice day
https://www.tradebit.com/filesharing.php/search/0/2008+aprilia+tuono+1000+r
Dec 01, 2010 | 2008 Aprilia Tuono 1000 R
Power button turns green, flashes and then turns red and flashes.
While working it stops and flashes red approximately 2 seconds interval
Causes
Protection circuit is activated depending on the temperature of the surroundings
Remedy
Switch off the power supply and power on after the temperature have reduced.
While working it stops and flashes red approximately 0.5 seconds interval
Causes
1.Using speakers having less impedance than the specified.
2.If speaker core wire touch each other Protection circuit is activated
Even applying power red flashes 0.5 seconds interval
Cause
Amplifier circuit has failed
Remedy
Switch off the power and contact denon service centre
Thank You
Sep 07, 2010 | Denon AVR-789 Receiver
Hi.after washing the bike i have problems with the electrics on the dash. when the ignition is switched off all 4 indicators flash and the digital screen stays on, when switched on indicators stop flashing...
Hi, Scoobie8587 here is how to reset/adjust Engine Service Interval (Wrench icon)
6. Release SCROLL.
https://www.tradebit.com/filesharing.php/search/0/2006+aprilia+tuono+1000+r
Jun 23, 2010 | 2006 Aprilia Tuono 1000 R
Sound but no picture
hi
i think its a colour wheel problem...if there is led blink tell me how many times it will blink i will sort if there is error code and i will tell the solution
Feb 14, 2009 | Sony Televison & Video
SONY LCD GOES OFF
Try turning the tv off, then unplug the tv from the wall for at least 60secs. Plug it back in. Turn it on and see if the blinking has been reset to normal.
Jun 03, 2008 | Sony Grand WEGA KF50WE610 50" Rear...
Computers & Internet Logo
12 people viewed this question
Top alexa.com Computers & Internet Experts
David Payne
David Payne
Are you an alexa.com Computer and Internet Expert? Answer questions, earn points and help others
