Question about Furniture
Can you fix a Transtherm wine cooler Manor Prestige. It is not cooling. Is there a dealer in Phoenix?
  • 473 Answers
SOURCE: wine cooler doesn't cool properly
Few things to check here. If the compressor is not running then the problem may be a bad thermostat or the compressor start device (ptc starter). Most common would be the thermostat on wine coolers. Also need to check if the fan is running. If everything is running then you have a sealed system problem. If the fan is the only thing that is not running that will cause a no cool situation.
Posted on Oct 07, 2007
  • 172 Answers
SOURCE: Danby Silhouette Wine cooler won't
Hi sooner84,
I really like the Danby wine coolers, they are usually nice products. As far as your problem, I would first try to find out where the main problem area is. To do that first make sure that your compressor is running. If the compressor is running and it is not cooling then you may have a freon charge issue. Thats not to say that you can just put some more freon in and it is fixed, You would have a leak in your sealed system and you would most likely still have warranty coverage for that. Most Danby products carry a 5 year sealed system warranty. That would include your compressor.
If the compressor is not running then you would know that you have a compressor issue. Either the relay overload on the compressor would need to be replaced or the compressor itself was bad. You can buy relay kits for about $30.00 and intall them easily with very little experiance.
Next if the compressor is doing its thing and trying to cool you could have a fan not blowing air properly. either a condenser or evaporator fan may have stopped. If you find one not working then chances are you just need a fan. If the fans are blowing and the compressor is working then you would just have a defrost problem. In that case you would just need to defrost then check for bad parts, either a defrost heater, defrost thermostat or a defrost timer. Most of the Danby products have a defrost control board, that board willl contorl the defrost, the temperature, and the fans. If the board was cheap I would say just put one on and see if it fixed the problem, but they are around $145.00.
The most important thing for you would be to make sure you are not going to do something that would void your warranty. Free service is always the best. Good luck to you and send some wine my way, I make lots of different types. from grapes, strawberrys, muskedyne, etc....
Posted on May 02, 2008
  • 1314 Answers
SOURCE: my cooler cannot cool
pull it out and lay hands on the compressor and see if its running if not replace the thermostat
Posted on Jun 03, 2008
SOURCE: Cuisinart Wine Cooler
If you call (Cuisinart’s service center (800) 726-0190), they will send you a brand new unit for $10.00.
Happy Holidays,
AC Freeborn
Posted on Dec 02, 2008
  • 3 Answers
SOURCE: Noisy Wine Fridge
The problem is likely with one of the two fans. A new fan is available from Danby (1-800-263-2629). My noisy fan is the condensor fan located at the bottom rear of the device. After removing the cooler from under the cabinet, the source of the noise was obvious. You will need to tell them whether it is the upper fan or lower fan. Leave the cooler upright for a few hours before you plug it in so that you do not damage the condenser. Price for the fan from Danby is $20.15 including shipping. Users Manual is available at -Ron
Posted on Apr 13, 2009
Not cooling issues in cooling devices has, generally, four causes
lost refrigerant
compresor damaged
thermostat issues
Fan issues
First I would check if the fan is working. If that is the cause, they are cheap and is a DIY job
For other issues, would suggest to have it diagnosed by a repair facility
May 19, 2017 | Furniture
Repair door gasket seal
try there for parts enter model
Apr 27, 2014 | Transtherm Furniture
Ice on the back wall; temperature went from 58 degrees to 34 degrees; had to shut off regrigerator
Wine cabinets work off of cycle defrost, so in order to built frost your temperature sensors are not working properly. I would look for corrosion on or in connections to be the fault or problem. Sensors report information to control unit and thats there only job. Its the control unit that dictates function. Look for corrosion to be the problem, clean connection and seal with RTV when connection a corrected.
Good Luck
Sep 10, 2011 | Transtherm Ermitage Wine Cooler
My Transtherm Castle wine cabinet has accumulated ice in the lower chilling compartment, I need to know what is involved in thawing/defrosting the cabinet.
Check the thermostat setting; it may be set too high. If lowering the setting does not solve the problem, replace the thermostat.
P.S. The thermostat is what controls the temperature.
Dec 23, 2010 | Transtherm Castel Wine Cooler
Icing up on back wall
I have the same model and the same thing just started with mine! Did you find the solution?
It's now 2017, and I should've post the resolution a long time ago. I've had ice form on the back of my unit several times over the last years and the problem has always been because one or more bottles were touching the interior back wall. Any kind of contact with the walls will cause the ice to build-up. Check your bottles and pull them forward a bit to ensure they are not touching the back wall.
Nov 17, 2010 | Transtherm Ermitage Wine Cooler
thats because 42 degrees is the optimum temperature for wine to be at. unlike other beverages wine coolers only go to 42 degrees.
Jan 21, 2009 | Transtherm CR212104 Wine Cooler
Furniture Logo
Top Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Furniture Expert? Answer questions, earn points and help others
