Dcp-j315w f4 fault. cleared purge counter and tried to clean heads by blowing through ink tubes but still f4 fault. is it worth repairing?
Inky
  • 691 Answers
SOURCE: Just stopped printing black!
Hey Johnny, Your dead right. The purge tube would affect all the colours. If you are using refilled carts, try just changing the cart. Approx 10% of all refilled carts fail - so it is entirely possible you have hit on a bad one. If you are using the good stuff, I would suggest getting the cleaning kit and doing the manual clean to clear any blocked nozzles. What does the nozzle check pattern show? If there are a few lines visible, I would guess cleaning will sort it for you. Let us know how you get on...
Posted on Jun 11, 2007
SpideRaY
  • 687 Answers
SOURCE: DCP-340CW purge counter reset
n the mean time you can RESET this purge count back to zero using the MAINTENANCE 80 menu, to continue using the printer for a while until you get the new pads. But it on a tray as if they are full they may start to leak onto your desk....
1 . Press (MENU) (MONO START) then (^) OR <the up arrow> four times, the Photo Capture and Red Exclamation Lights will then flash.
2. Press (^) eight times until you see <8> then press (SET)
3. Press (^) twice until you see <0> then press (SET)
You will now be in MAINTENANCE 80.
4. Press the (MONO START) its a toggle until you see PURGE:6451 ( I guess this means you have cleaned the heads over 6,450 times their threshold level.) you will need to enter the code <2783> to RESET it.
5. Press (^) twice until you see < 2 > then press (SET)
5. Press (^) eight times until you see < 7 > then press (SET)
5. Press (^) nine times until you see < 8 > then press (SET)
5. Press (^) four times until you see < 3 > then press (SET)
The Printer will beep then reset counter will be at ZERO <0000000>
Its the PURGE that will increment by a variable amount each time you clean the print heads the amount will be between 100 and 130. When this count gets to about 64,000 the error 46 will occur. That's about 510 times you can clean the heads before the pads need cleaning.
Almost forget to EXIT the Maintenance mode enter 9 twice by using the up arrow & set key's to exit from maintenance mode in the same way as entering the 2783 code, or power down the printer.
LOL
Check me out at www.windowstipsclub.co.uk
Posted on Sep 23, 2009
gabizaica
  • 195 Answers
SOURCE: Ink Problem
try to remove the printhead and clean it with a soft cloth and alchool.
Posted on Apr 22, 2012
SOURCE: brothers dcp-j315w ink absober full
not working on mu 315W. Asume that you mean:
Hold stop/exit button
Turn on printer.
Release stop/exit
Hold on/off and hit stop/exit twice
Posted on Sep 15, 2012
SOURCE: DCP J315W unable to print 50
Try forcing a piece of thin cardboard into the paperfeed. (like a kleenex box, only the size of a piece of paper) look inside, and once your can reach it, get hold of it and pull it through. (do this with printer unplugged)You might be surprised what comes out with it. I had a little piece of paper jammed in there and the cardboard forced it out.
Posted on Apr 12, 2013
How do I fix the absorber full on brother printer DCP-J315W?
go to service mode by pressing *2864 then appear on screen mentainance press 80.then find purge,then after you find press 2783.then exit by press 99.
Aug 04, 2016 | Brother DCP-J315W Inkjet Multifunction...
What to do if it always appear in the monitor of the printer that ink absorber is near full?
Not only the absorber must be cleaned, also the counter must be reset. I know there is a program for older Epson printers to reset the counter. I found a reset procedure for a brother printer here:
How to Reset Purge Counter on Brother DCP J315W Printer
Perhaps you can fine one for yours?
Feb 21, 2015 | Brother DCP-J125
Unable init. 50 on my Brother DCP-J315w ...what should i do
Any failure to initialise, print, clean error report usually indicates the waste ink chamber is full and the purge count has maxed out. You can remove the waste ink chamber, clean and replace the pads and refit it but seriously time consuming and messy. You should try the purge count reset first (do google search) eg this one
http://ref.topictimes.com/videos/tech/how-to-reset-purge-counter-on-brother-dcp-j315w-printer-full-1NzJwuCpVOc.html
If that works, you can keep using it but should clean the waste chamber. Or save the hassle and just buy a new machine :-)
Jan 05, 2015 | Brother DCP-J315W Inkjet Multifunction...
How do i troubleshoot dcp-j315 showing machine error 46?
try 1 then 2
1. reset counters of ink absorber or flushing boxes (press the menu key on the touch panel and the black start (mono start) key on the control panel. next press the scan key four times. displays
"maintenance". press the 8 and 0 keys in this order in the initial stage of the maintenance mode. (for
models without numerical keypad, enter 8 and 0 using the up and down arrow keys, and ok .)
press the black start (mono start) key several times until the purge (or flushing) count appears on the lcd.
press the 2, 7, 8, and 3 keys in this order to reset the purge (or flushing) count. and ok keys.)
press the stop/exit key to return to the initial stage of the maintenance mode.
2. the ink absorber or flushing boxes are full. replace them
Oct 01, 2014 | Brother DCP-J315W Inkjet Multifunction...
How to reset counter in brother dcp6690cw
Sir/Madam
It's Very easy to reset counter in brother Printer,I suggest You watch YouTube video For Your Brother Printer Problem,I Hope You resolve and get all Brother Printer Help after watching this video URL Link below:
Or
In case You still need Help I suggest You Follow Us On:
Brother Printer Support
Nov 13, 2012 | Brother Ink for Dcp-6690cw and Lc-1100
How to do the clean unable 50 in brother DCP-165C
Hi Good day!! try this method
- Machine off
- Switch on the machine while holding down the "menu"button until all the leds are flashing on/off. Now you are in "maintenance" mode.
- press 80
- press the "mono start" button several times until you see "purge: xxxx"
- press "2783" in order to reset the purge counter. You will see: "purge:0000"
- press "99" to exit the maintenance mode
Now you are able to print again, but actually your ink absorber box is now full with ink. Ink flooding can happen if you don't replace this ink box!
Don't forget to vote thanks!!!!
Oct 27, 2010 | Brother DCP 165C Compact Color Inkjet...
DCP-110c is showing machine error 46. I have followed instructions as per cene765 solution #1 withput success. I get as far as 'maintenance 80 display. Pressed 'mono start' many times but still displays...
Many thanks - I fixed the error 46 by following the helful solution provided below.
mydcp110c
Rank: Apprentice
Rating: 86%, 8 votes
Hello!
Here is the "Unable to Clean" (code 46) solution:
The machine counts all purge (cleaning) operations in order to prevent the internal ink absorber box from overflowing with purged ink. An “initial purge”, for example, advances the purge counter by 187 + 420 = 607. When the purge counter approaches 6400, an internal "Machine Error 46" is generated. Further purge operations are prohibited, and therefore the printer becomes unuseable.
When an internal Machine Error 46 is generated, the user will see an “Unable to Clean” external message and will be unable to use the printer. The “Unable to Clean” external message can relate to many different internal error codes however.
The user can establish the internal Machine Error Code as follows: pull the mains cable out of the machine (power off), hold down the Menu/Set key, re-insert the mains cable into the machine (power on). The internal Machine Error Code will be displayed.
If there is a Machine Error 46, it is necessary to dismantle the printer, replace the ink absorber box (or possibly break the ink absorber box open and clean its absorbent sponges under a tap), re-assemble the printer and reset the purge counter to zero.
Solution no. 1. (DCP-110C):
The proper reset code sequence to reset DCP printers without numeric keypad should be as follows:
1. press buttons Set, Menu, Mono Start one by one, followed by up arrow key four times.this should all be done as short a time as possible, around 3 seconds.
2. enter maintenance mode 80 by pressing the up/down arrow key and set key to select numbers 8 and 0
3. press up arrow key several times to get to the Purge item
4. enter 2, 7, 8 and 3 using arrow/set keys to reset the counter
5. press Stop/Exit key to go to root of maintenance mode
6. enter 9,9 to exit maintenance mode
Dec 11, 2009 | Brother DCP-110C All-In-One InkJet Printer
LOL
May 04, 2009 | Brother DCP-340CW All-In-One InkJet...
Clean unable 46 : what does it mean ?
IT means you  need to reset the purge counter in order to that .
For MFC - 240c
1.Enter mainatanace mode by pressing menu button at time of switch on. and leve the menu button when fax/scan/copy/photocapture button start blinking
2.press *, 8 & 0 and drag the this submenu by pressing mono button to get "purge" eg (purge:9624)
3.Press the 2, 7, 8, and 3 keys in this order to reset the purge count to zero.
4.Press the Stop/Exit . OFF the printer .and turn it on.
Jan 13, 2008 | Brother DCP 130C All-In-One InkJet Printer
k24674
jasbo
jasbo
