Question about Mitsubishi Televison & Video
How much to replace video component board got Mitsubishi tv model ws55315? Can I buy the part and what is the part number?
  • 1153 Answers
SOURCE: mitsubishi 60" projo tv model vs-60705, blanking bar
Also info at
Posted on Dec 06, 2007
  • 556 Answers
SOURCE: Mitsubishi WD62525 Dead NO Power-Won't turn on
Don't think dm board will solve your issue, might want to check power board for buldging caps.
Posted on Aug 10, 2009
  • 296 Answers
SOURCE: On Samsung main board model bn94-01708u with no video.
Hi, I think you need to replace the video card.
Thanks! mannu_rakesh
Posted on Aug 21, 2009
  • 60 Answers
SOURCE: Bad Video Board
In my opinion, if you replace the board you still have a leakage issue. These sets run around $300-$400 in my area. It may make more sense to spend the money on another used TV, or save up and purchase a new TV.
Posted on Sep 11, 2009
  • 788 Answers
SOURCE: i have mitsubishi model#WS55315 55 inch. get
Your symptom sounds like a damaged convergence IC.
There are two and large IC’s that control the convergence in a big screen set. Some of the newer sets (I think that this appies to yours)only have one. They are secured to a very large aluminum heat sink. They will have a part number stamped on them that will start with an STKXXX-XXX, like STK392-110, and they are located on the signal board (on the left as you look into the back of the set).
Along with the convergence IC’s there will also be some associated components that will need to be replaced as well. There are some resistors that are part of the convergence circuit that will be open and need to be replaced. Most likely these will appear charred in the center. If you have an Ohm Meter or a DVM, check all the resistors that are close to the IC’s and you should be looking for either ones that have opened or have changed values.
There are also two resistors on the front of the board located in the middle that are fusible link resistors, these should be checked for opens and replaced if they are found so.
If one of the convergence IC’s are found to be bad, I would replace them both, if one has gone bad the other may go soon. I usually order my parts from Andrews Electronics in California, they will have the OEM components that you will need.
Their site is
And their phone number is a 24-Hour Order Desk: (800) 274-4666
I recommend the phone order so you can talk to the person about the different types of IC’s that are available.
I would also advise that the convergence IC’s be OEM or better, just because they are cheap does not mean that they are a good deal. I have seen the cheap IC’s fail after a short time, even though they look exactly like the OEM IC’s. I think that the bottom line is that you will get what you pay for when it comes to the parts.
You can also try , I have not tried them yet, but they do carry OEM or better parts.
I hope this information allows you to resolve this issue.
If you need further assistance please comment to this post and I will try to help you further.
Posted on Oct 09, 2009
Where is the DM Board for the Mitsubishi WS-73907. I cannot find a picture of the back of where it is on this model.
the DM board is inside the TV. way inside. This is not an easy repair for the average user.
Feb 21, 2015 | Mitsubishi Televison & Video
Power surge knocked out my video board. How do I order a replacement?
if you include the make & model we may be able to help locate a board. Even better if you include board ID info including revision number. Suggestions include eBay or any of the reliable net based component vendors.
TV Boards Buying Guide
Jan 11, 2015 | Televison & Video
My mitsubishi medallion hd 1080 doesn't show content from component cable
Some of the older Mitsubishi with HD 1080 have only one component input for HD---it is marked on rear as DTV----also a model number may allow me to give another suggestion--Some of these sets (ws, wt, vs models) will on occasion lock out or disable the input/s.
Depending on model number most also have 3 hidden menus---one is the option menu----it allows with the Mitsubishi remote via a 4 digit number (by model number) to enter there and do a hard reset of the set----sets every setting back to factory original---seen it "cure" all kinds of odd problems from missing rear inputs, no sound, odd video issues---you name it.
Get me the model number and I will see if can find the code for yours--you can also try hooking first direct a 1080 blue ray or Dvd if you want to see if the input is active or not first.
Apr 14, 2012 | Televison & Video
Mitsubishi WS55315 rear-projection has gone dark
Yes, they have other than convergence circuit problems----very few issues or troubles.
You should test the shops by asking if they have the 4 digit code number for this model for the OPTION MENU---set has 3 hidden menus and OPTION menu will allow a hard reset of entire set---the other two menus are adjustment and convergence menus.
If some shop has no idea what the option menu is----pass them.
Mar 24, 2012 | Mitsubishi WS-65315 65" Rear Projection...
Mitsubishi 65 inch rear projector TV with remote. Model WS65807. HD ready, but not HD. Has failed circuit board, part number 930B866001. This board regulates audio and video. Part no longer available...
Short answer: No.
The board and install will cost you more than an LCD/LED flat screen TV.
Sorry for the bad news, but you will save space and electricity with the new TV.
Next problem: Trashing the projection TV.
Oct 25, 2017 | Mitsubishi WS-65807 65" Rear Projection...
RF connector broke from board....looks like part number is 1519592K, but nothing appears when I enter that part do I get new board?
You can't buy the RF connector parts from a TV component supplier as they are already soldered to the main board. A friend who can solder PCBs or a TV repair shop should be able to re-solder the original for you. If it's damaged, a TV repair shop might also be able to find another that will fit as they are fairly standard components. This will be far cheaper than buying a new main board and it's probably going to be difficult to get one.
I had a look for a new main board, but the TV is fairly old and I couldn't find one or a part number. It's easier to find components by part number rather than by TV model, so your best bet is to find the part number on the main board and try searching for that on Google or similar.
If you want to post back with the model number, I don't mind having a search for a replacement main board, but my advice would be to get the existing repaired, if possible.
Hope this helps.
Nov 23, 2010 | RCA MM36110 36" TV
Boe in blue dynamic convergence curcuitry. Swapped deflection yoke on two tubes but problem still remains. Unplugged convergence plug on yoke and bow disappeared but unable to adjust dynamic convergence....
what's the number of the board where you unplugged the conv yoke, should start with 930_ that is the board you need. Try the with the part number or type in the brand and model when you have the number on the board, and they display price and availability.
Jan 15, 2010 | Mitsubishi VS-45609 TV
How do i change from 480i to 1080i on my mitsubishi ws55315
You can't. Depending on what the output device is sending and what input you are using ion the back, it chooses for you.
ie - if you have a DVD player sending out 480 the TV will only allow different versions of 480.
Oct 21, 2009 | Mitsubishi WS-55315 55" Rear Projection...
Mother Board Failure Where do you get a replacement.
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board ... - eBay
  1. Cached
US$59.99 - ‎In stock Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. ' eBay!
Dell Main Board 01004-2960 for W3202mh W3706mh ' eBay > ... > TV Boards, Parts & Components
  1. Cached
Used condition; • Returns accepted - 60 days money back or item exchange. Model: W3202MH,W3706MH. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. Type: Main Video Board Motherboard Unit. See details.
W3202mh W3706mh ' TV Repair Parts & Components Online Get the best deals on Part in our clearance section in addition to deals on motherboard board, board video motherboard, main video motherboard, main unit, un.
Dell TV Main Board ' eBay > ... > TV Boards, Parts & Components > Dell TV Main Board
  1. Cached
Dell 32" W3202MH,W3706MH 01004-2960 Main Video Board Motherboard Unit. Model: W3202MH,W3706MH. Type: Main Video Board Motherboard Unit. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV. C $74.81.
DELL 37" W3706MC 01004-3190 Main Video Board Motherboard Unit > ... > TV, Video & Audio Parts > TV Boards, Parts & Components
  1. Cached
SKU: 01004-3190. Brand: DELL; Condition: Used; Notes: Please be sure that the BOARD Part Number and picture on your motherboard is EXACTLY as shown above. Do not match by TV Model. There are possibly several different boards for each model TV. This board has been pulled from a working cracked screen TV.
Mar 04, 2018 | Dell W3706MH 37 in. LCD HDTV
Televison & Video Logo
12 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
