Question about Vacuums
How to remove fan motor/fan housing on Eureka 4D Boss
Brush motor and belt not involved in noise from machine.
  • Ed Goolsby
    Ed Goolsby May 19, 2017
    Please note that this is an upright vacuum cleaner.
SOURCE: Problem getting belt around motor shaft... Eureka The BOSS
make sure the vacuum is in the upright (locked position) - when you lower the handle, this puts tention on the belt. If it is in the upright and locked position, there is plenty of clearance (unless you have the wrong belt.
Posted on Apr 08, 2008
susho
  • 18 Answers
SOURCE: Roller brush will not turn on Eureka "The Boss Power Plus" 12 amp
Depending on the model there will be a couple of screws on the top plastic cover. The cover lifts off and the belt is then serviceable. On some models you will need to remove some parts on the bottom too to get the roller out.
In any case just look for screws that hold the covers on and explore a bit. You can't break anything.
Posted on Jul 31, 2009
SOURCE: vaccum wont work
There is also a reset button on the side at the bottom. Good luck.
Posted on Nov 03, 2009
SOURCE: My eureka 5902 4D bagless uprights roller brush
The same thing happened to me about a year ago with this very model.
The issue on mine was a small, copper-colored metal wheel that attaches to the end of the brush roller. You'll need to remove the top cover (there are several screws).
Once it's off, you should see the belt, the beater brush, and the metal gear. The gear didn't fit correctly - so the motor just spins without moving the brush. I ended up going to the store and buying superglue that withstands high tempuratures, then gluing the gear to the motor's shaft... and hammering the thing into place before the glue 'set' too much. ...Not fun, but it's working and has been ever after. I can take photos of the thing if need be.
Posted on Jan 03, 2010
falspet
  • 438 Answers
SOURCE: screeching noise from eureka bagless the boss 4d
replace beater bar belt, check and insure beater bare rotates freely with belt removed.
Posted on May 19, 2012
Screeching noise from eureka bagless the boss 4d
May 19, 2012 | Eureka 5849A Boss Bagless Upright Cyclonic...
The belt on my used Eureka Boss 5857 upright slips off the end of the motor shaft every time the vacuum is used. When I turn the brush roll slowly by hand, the belt walks toward the end of the shaft. It...
The brush roller could be worn and in need of replacement. Some Eureka uprights have a wire guide that prevents the belt from slipping off the motor shaft.
Apr 02, 2011 | Eureka 5856BVZ Boss Bagless Upright...
What is the cause of the loud noise in my vaccum it's a eureka boss bagless
If it's a rattling type noise, its possibly something in the fan assembly, including a broken off piece of the fan.
It could also be something loose near the roller brush, including a piece of the belt.
Nov 18, 2010 | Eureka 5856BVZ Boss Bagless Upright...
My eureka 5902 4D bagless uprights roller brush stopped spinning. The belt is ok. This model has a sliding switch for roller speed. The brush should spin when you release the handle via the foot release....
Dec 23, 2009 | Eureka Smartvac 4870 Bagged Upright Vacuum
Jul 30, 2009 | Eureka Boss SuperLite Bagless Upright...
The boss keeps shutting off
take the brush roller completely out of the vacuum then plug it in .you should be able to hold on to the ends of the brush roller and turn the brush freely if not the brushroller is froze.try taking the ends off the brush roller an see if you have carpet strands or hair built up around the spindles
Mar 22, 2009 | Eureka 5893AVZ Bagless Upright Cyclonic...
How do i replace the fan blade assembly which are broken in my ureka model the boss thank you lorne
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=540001
Generic problem for all Vacuums
Posted by lmurray1 on Apr 23, 2008
How do i replace the fan blade assembly which are broken in my eureka model the boss
thank you
lorne
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure.
There are 2 different models of the boss by Eureka – there is a standard old style upright that the belt that the belt would unscrew from the bottom of the motor and you would have to remove the top of the vacuum cover to remove the main motor and gasket assm, and then the fan has a reverse thread on the plastic fan and you would unscrew the fan after removing the belt pulley. Then you would screw on the new fan, belt pulley, replace the gasket and re-install the motor. If you have a new style with a side mount motor you would remove the top cover, the motor would be in there sideways, un-screw the motor, remove the silver tape around the fan housing and un-screw the fan housing – same as above un-screw the fan from the motor, there is a nut on the end of the fan holding that on – (remember, the fan has a reverse thread) re-install the fan. Then the fan housing, replace the silver tape, and then screw down the motor and replace the top cover, then you can test. As always free to contact your local vacuum dealer in your area in the yellow pages or contact your Eureka factory manufacturer listed below:
http://www.eureka.com Customer Service Phone Number
1-800-282-2886 Hours of Operation
Monday thru Friday 8:00 am to 7:30 pm CST
Saturday and Sunday 10:00 am to 6:30 pm CST
Thanks, Don – The Vac Man
Go Ahead. Use Us.
Apr 23, 2008 | Vacuums
Vacuum doesn't go into carpet mode
If the model number is 5892AVZ, either the brush roll is bad or the brush roll motor isn't coming on to drive the brush roll. There is a circuit breaker, make sure it didn't trip, reset it if it has.
Jan 31, 2008 | Eureka 5892AVZ Bagless Upright Cyclonic...
Vaccum wont work
Oct 14, 2007 | Vacuums
Eureka 5849A Boss bagless upright
remove belt to brush roll and see if noise persists. if it stops, you probably need a brush roll. at least doing this will narrow down the fault area
Mar 26, 2007 | Eureka 5849A Boss Bagless Upright Cyclonic...
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
