Question about Vacuums
Why does my spin scrub 50 dump the water out of tank vry fas or why sitting still
4 Suggested Answers
reddevil6
  • 1673 Answers
SOURCE: Will not dispense water or solution
On the bottom of the tank is a valve, push it in and see if water comes out Where the tank sits, there is a black round seal, is it in the proper place? The rod in the handle hits just under that seal, with the tank off, you can see if the rod is movin up and down when you depress the trigger. The resevior asm. may be bad, that is what the tank sits on.
Posted on Mar 11, 2008
  • 742 Answers
SOURCE: Hoover steam vac spin scrub only leaks clean water
Leak in the pressure line
Posted on Oct 28, 2014
SOURCE: my hoover spin scrub has no suction wont pick up water why?
No suction means somewhere in the intake side of the system you have either a blockage or an air leak.
Posted on Jan 21, 2015
How do I hook up the upholstery attachment on a Hoover Spin Scrub 50?
To connect the upholstery tool, first remove the clean water tank by pressing down on the handle and pulling the tank forward. Remove the hose from the storage rack. Press down on the handle release lever and lower the handle to the ground. Unlatch the back part of dirty water tank and remove the lid. Pull the dirty water tank's front panel up about an inch and rotate the panel to parallel with the floor. Replace the panel with the converter and slide it halfway down until it is firmly in place. Pull the collar on the connecting tube towards the tube so that the black tabs are fully extended. Open the door on the hood labeled Stair/Upholstery cleaning connection and press the round solution tube onto the round projection. Press the collar firmly to ensure that the tube is connected. Replace the tank in a hinge-like manner and place the lid under the tabs on the front of the tank. Rotate the lid down onto the tank.
Now slide the upholstery tool on the connector of the hose until the tab locks into place.
The manual for the Spin Scrub 50 is available on the Hoover product page: http://hoover.com/products/details/fh50044/steamvac-spin-scrub-50-carpet-washer-with-tools/ . The direct link to the manual is http://hoover.com/file/1195/ . The directions are on page 14-15.
I hope this helps.
Oct 19, 2015 | Hoover Vacuums
My hoover spin scrub has no suction wont pick up water why?
Jan 21, 2015 | Hoover Brand New SteamVac Spin Scrub...
Why it won't pick up water?
Make sure the switch is on the setting you are using, I.E. spin scrub. If this isn't the problem you may have a bad turbine blade, if the scrubber brushes aren't turning that is your problem. $45, a screw driver and general mech. abillities will fix it. http://www.vacpartswarehouse.com
Jul 21, 2014 | Hoover Spin Scrub 50 Deep Cleaner
I have a hoover steam vac spin scrub that won't pick up the dirty water heeelllllllppppppppppppp please
The most common reason for lack of pick up is that the lid is not fully seated on the dirty water tank. Be sure to hook the two tabs on the front of the lid, and then snap the rear latch into place. Another reason is that the duct on the front of the dirty water tank is missing. The duct may have been removed to install the hose, and was not put back in place. It is a square plastic piece, about the size of a slice of sandwich bread, which slides into the front of the tank. A far less common reason for no pick-up is that the seal that the tank sits on has fallen off the motor cover suction tube. You will see a round tube on the bottom of the dirty water tank. This sits on top of a large rubber seal on the motor cover when the tank is in place. Be sure the seal has not fallen down into the hood.
Jun 15, 2011 | Hoover SteamVac F5914-900 SpinScrub...
I have a Hoover SteamVac Spin Scrub that won't pick up the water. Could you please give me some info on how I might fix it. Thanks!
My Hoover steamvac w/spin scrub F5914-900 will not **** up water. I can not find my manual. How can I fix it?
Assure the ring gasket is in place under the hood. A round rubber gasket must be in place on the round tube under the hood where the recovery tank sits to connect the vacuum from the motor to the round tube on the bottom of the tank.
Aug 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Leaking Hoover Scrub Spin Carpet Cleaner
A picture would be nice. Be advised that broken plastic is hard to repair.
Aug 05, 2017 | Hoover F5906-900 Upright Steam Vacuum
Mar 10, 2008 | Hoover SteamVac F5914-900 SpinScrub...
Vacuums Logo
11 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
