Blue light on set is flashing. cannot turn tv on with remote
    Top Expert:
  • Televison & ... Master
  • 33,344 Answers
Could be an open internal fuse or power supply failure
Posted on May 19, 2017
SOURCE: Polaroid tv will not turn on blue light flashes
it may be broken
Posted on Mar 07, 2011
SD Tech
  • 14553 Answers
SOURCE: Sharp rear projection tv set, view timer flases, tv will not turn on, also, remote will not turn off flashing lights.
ok, title here says Mitsubishi and you say Sharp---can you tell me the model number of your set?
Posted on Mar 18, 2012
SOURCE: set up the tv and there is a blue light flashing in the bottom left corner. i push the power button on the tv and nothing happens what should i do
That can be an indication of a bad power board or a bad main board.
There are several ways to narrow it down, but perhaps the easiest is to test all power board output voltages with a meter.
You don't even specify the model of the TV here so I can't be more specific, but you can find the general approach to testing power boards at http://blog.coppelltvrepair.com - search for "how to test" and a few articles will pop up on how to test particular power boards.
Yours won't be different in methodology, only in connectors.
Hopefully it is labeled.
Or , alternatively, you can send it over to us and we can test and, if neccessary, repair it.
Should be anywhere between $30 and $70 at least as of September 2012...prices may change , but hardly by much.
For shipping instructions follow the according link at www.coppelltvrepair.com .
Posted on Aug 26, 2012
  • 33344 Answers
SOURCE: Jvc 37 in flat screen turns on after power is turned off for ten seconds, won't turn off either by remote or buttons on tv , screen also has a blue standby light that flashes
The internal power supply is failing. The flashing blue indicator is one symptom; the erratic response is another
Posted on Mar 14, 2013
SOURCE: Turns on has flashing blue light can't change channel/av either by buttons on tv or remote
Depends on the kind of clock we talking about but in general terms put the batery into the clock and u will c the tuner kp tuning till it matches wt the one in ur hands
When turning on the tv by either remote or switch on side screen will flash blue then turn off. Have unplugged tv still won't turn on.
Search Results
    Samsung TV Keeps Shutting Down - Forums - CNET
    www.cnet.com > Forums > Samsung
    CNETWhen I turn the TV on for the first time each day it shuts itself off within 30 ... There is ablue kill switch there, but you don't want to fool with that. .... The tv will not turn offwith the remote or the side buttons on the tv. .... I replaced the lamp but the tv screen will have a momentary flash of light on the screen then it will turn on and ...
    Philips/Magnavox Tv Problems ? - Home Forums
    ths.gardenweb.com > Home Forums > Electronics
    Mar 26, 2005 - I turned the tv on then off a few tims then eventually the piture would come on. .... time, the LED will flash continuously along with the volume going up to max. ...... You can use the remote to turn the tv off and on but nothing else. ... If you press the power button over and over it stays on a blue screen but as ...
    Top 208 Complaints and Reviews about Akai ' Page 3
    www.consumeraffairs.com > Electronics > Televisions
    Rating: 1.9 - ‎37 votes
    The screen will not turn on with the remote, side switch or rocker arm. .... It will flash for a second and the blue Akai screen will display very briefly, but then .... Akai LCT3201AD TV does not turn on using either remote or power button. ... I turned itoff one night and the next time I turned it on, the green light came on, but it did ...
    Get help with audio, video, or power on Apple TV - Apple ...
    https://support.apple.com/en-us/HT200197
    Apple
Jan 28, 2016 | Televison & Video
Mar 14, 2013 | Televison & Video
I need the RCA Blue Ray rtb1203 Remote Control code for a Direct tv Remote
You don't need a code when programming a Direct TV remote. Try following these steps. The process take a few minutes but it works -
  • Turn on your Blue-Ray and put in a disk.
  • Switch the mode to which ever input the Blue-Ray is using.
  • Hold down the "mute" and "select" button at the same time until the green light begins to flash then release.
  • On the keypad enter the numbers 9-9-1 followed by Satellite, TV, VCR/DVD, Aux,
  • Press the power button or which ever function you wish to use for you Blue_Ray such as play for the VCR.
  • Point the remote at you Blue-Ray and slowly press the "channel" and "key" button together until the remote turns off. Do this slow enough so as not to pass up the right code.
  • Once the remote turns off then you have found the correct code.
  • Press and release the select key to lock that code in.
Please note that if you cycle through all the codes and your remote does not turn off and the red light flashes three times then the code you need for your Blue-Ray is not available with that remote. At that point another remote would need to be used.
Regards, Tony
Apr 23, 2011 | Audio Players & Recorders
When I turn on the TV the blue indicator light comes on but there is no display, then the blue light starts blinking.
The following steps should be able to correct the problem:
1) Unplug the TV or remove AC power from the TV
2) Count to ten and then plug in the TV
3) Locate the [Menu], [VOL-] and [Power] button on the TV’s side panel
4) Using the buttons on the TV’s Side Panel, press and hold both the [Menu] and [VOL-] buttons.
5) While holding those buttons, press and release the [Power] button one time and count to 3 before releasing the [Menu] and [VOL-] buttons.
6) The TV’s lower left Blue Power LED will come ON.
7) Wait 30 seconds. Confirm that the blue LED on the Lower Left of the TV (not the iPod dock for iPod models) has remained ON during this time.
8) Press the [Mute] button on the TV remote twice
9) Unplug the TV or remove AC power
10) Count to ten and plug the TV in
11) The TV power should automatically come ON and the blue power LED with be ON
12) Wait 40 seconds and the TV picture should appear
13) You can now continue using your TV.
14) If the picture does not appear, power on the TV manually:
· If the LED begins flashing, unplug and power ON a second time.
· If the LED begins flashing again, power ON the TV without unplugging
If the LED begins flashing again, contact us directly by phone to obtain a local authorized service center for you.
If the TV does power on, please reply back with the software version number for us to research this issue. Please follow these steps to obtain the software version number:
1) Press the [Menu] button on the remote control.
2) Using the arrow keys in the center of the remote, scroll over to the "settings" menu and select the [OK] button on the remote
3) Scroll down to "system info" and select [OK] button on the remote
Dec 19, 2009 | JVC Televison & Video
Tv2 light does not come on
hi hammonhph! I will be more than glad to assist you in this concern. Lets program the remote for tv2, lets make sure that the battery's are brand new, please go to the front panel of the receiver, make sure that u have the remote2 with, turn on the the tv1, you got picture, on the front panel of the receiver, you got 1 green and the blue light is off.. push the power button on the front panel of the receiver once to turn off the green light, once its off the tv will show a black, blue or snowy screen, push the up button on the fron panel of the receiver until it shows the system information screen, look for the primary and secondary remote address, primary and secondary remote address should show a number on the white box ex.. 1 and 1 on the green box, secondary is ex 2 on the white box and 2 on the blue box, how to reporgram the remote to the receiver.. press and hold the sat button and wait until all lights lit up, once it all lit up, release it and press any number from (1 to 15) but for this ex is press 9, then press the pound button (#) that is under number 9, once you press the pound button the sat button will flash 3 times and then press the record button once, record button is under the cancel button or view tv button, once you are done check the secondary remote address, it should be 9 on the white box and 2 on the blue box, save the settings by using the remote 1, selct done on the screen and it will go back again to black, blue or snowy screen, press the sat button once on the remote 2 and the big red power button, the blue light should turn on, just in case the blue light dont turn on, press the power button on the front panel of the receiver for 10sec to reset the receiver, it will acquire the sat signal and go to a progress, and it will download the programming guide, check if blue light is not on, press the big red power button on the remote2 to turn on the blue light and it should work. if just incase the blue light dont turn on, the remote is bad and you need to call 1-800-333-3474 for the replacement of the remote..please feel free to get in touch if you have any query..
Jul 06, 2009 | DISH Network 322 DTV Receiver
One of our TV's was being accessed by someone in the neiborhood. I found in the manual how to change the remote code. After doing this the TV is locked on one channel. I did reboot. The remote is working...
Hi! I will be more than glad to assist you in this concern. Lets Isolate the problem, press 1st the sat button once on the remote that is giving you a problem. the sat button should light up and check if you could pull up the guide or can change the channels. if there is still no response, bring with you the remote conrtol that is giving you a problem on tv1, turn on the tv and it should show a picture, go to the fron tpanel of the receiver and press the power button once to turn off the green light, once its off, the tv will go into a black or snowy screen, press the up button on the front panel of the receiver until it shows the system information. look for the primary and secondary remote address, ex, primary remote address is 1 on the white box and 1 on the green box, secondary remote address is 2 on the white box and 2 on the blue box, how to reprogram the remote, press and hold the sat button on the remote that is giving you a problem and wait until all lights lit up, once it lit up release it and press any number from 1 to 15, but lets choose 9, then press the pound button (#) that is under number 9, once you press pound button, the sat button should flash 3 times, then after it flash, press the record button, that is under the cancel or view tv button., you will notice that the secondary remote address was change from 2 to 9. to save the setting, get the remote1, select done on the screen and it will show a black or snowy screen. to check the remote 2 if it works, press the sat button once and the the big red power butto, the blue light should turn on if there is no blue light but there is, the blue light will turn off, then before you go to the tv2 location make sure that blue light is on and then check on the tv2 location if you could change the channels now. just incase that the problem is still there, check the remote antena on the back of the receiver, make sure that its on the upright position to broadcast the uhf signal properly.. that should fix the problem. if just incase the problem still exist, call 1800-333-3474 ask for a replacement of the remote..pls feel free to get in touch..if you have any query
Jul 04, 2009 | DISH Network 322 DTV Receiver
I want to reset my TV
well when the blue light is on and ur tv is on standby, just use the channel changing button, simple!
Dec 06, 2007 | Televison & Video
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
Electro Med Services...
