Question about Miele Washing Machines
My Miele washer W4800 is rinsing out gravel and sediment . I have a lint trap on the drain and its a fairly large amount.
    Top Expert:
  • Miele Master
  • 79,865 Answers
What does this have to do with the washer, not sure what you are asking here, please elaborate on the problem you perceive to have??
Posted on May 19, 2017
Testimonial: "Recently I noticed what I believed to be some sort of sediment coming out of the rinse water, which I assumed had to do with the recent road work thats being done in my neighborhood. I figured rock somehow got in the water line, however, after having the water company come to my house and inspect they said absolutely not. They believe there is something breaking down in the washer itself. At this point my washer is completely broken as there is so much gravel stuck in washer the barrel no longer turns. Miele claims they never heard of it and the the water company also claims they have never heard of this."
  • 2 more comments
  • yadayada
    yadayada May 19, 2017
    Gravel doesn't magically appear in the washer, it has to be coming in from the water supply. I agree the washer is not the source. When you run a bath do you see dirt in the water. And of course no one will admit anything, that really surprises you?
  • Deb Pileggi
    Deb Pileggi May 22, 2017
    So it turns out the gravel I spoke of is actually ground aluminum from a broken spider in machine. Appliance Doctor said it will cost about $13,00 to fix.
  • yadayada
    yadayada May 22, 2017
    Wow $ 1,300 to fix?
  • Deb Pileggi
    Yep, labor and parts. Needless to say, Im buying a new machine!
Where is the lint trap and how do i clean it?
If the model number is true in the blue this a top load washer there is no lint trap lint collects on the protrusions on the outer side of the basket and is washed away during the rinse drain spin cycle
Aug 28, 2014 | Whirlpool WTW8600YW 4.6 cu. ft. Cabrio...
Does anyone have the parts schematic for Miele Touchtronic W4800 drum assembly?
Attached is a IPB for the drain section - are you speaking of Item number 1? This was an issue at one time with the intake side - a piece of felt glued to the drum stopped the chaffing. 5471732e-e156-4138-ab0a-dca218299e0f.jpg
Aug 16, 2014 | Miele Washing Machines
Hey there, i got a miele w4800 front load washer that stopped working all of the sudden. The buzzer is going crazy and the drain and intake fault lights are flashing. Any ideas of how i could fix this...
You have water in the bottom pan of the machine. grab it at the back and tilt it forward. the water will run out and it will start working again, but you will probably need a concertina hose. This is the hose that connects the detergent compartment to the wash drum.
Feb 15, 2011 | Miele W 4800 Front Load Washer
LG TROMM WM3431HW(?) soaks clothes in Dry Cycle
LG says to unplug unit. Or remove power by tripping circuit breaker. Wait a minute and plug back in. Good luck.
Mar 25, 2017 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
Water leakage after cleaning lint trap
make sure that when you replace your filter that there is no obstruction in the filter thread(small stone), i have had many problems with this,if the drain light keeps comming on then check the waste pipe stand.
Apr 07, 2010 | Miele W1926A Front Load Washer
My Miele Touchtronic W1119 shows the error message Drain/Intake Fault. The intake and filters are fine. What's going on?There is no water standing in the drum. How can I reset this?
Hello Buvamo,
You may want to check the water valve and make sure it is all the way up where the intake line is.
The other area to check for water not draining is the lint trap. While the intake/drain fault is on the door will not open for the lint trap.
There is a release lever at the bottom of the machine (Orange in color) that is below and behind the trap door. Just pull down on the lever and that will open the trap door. You may want to put a towel under there as it will leak once the door is opened. inspect and clean the trap and try running cycle again
Sep 13, 2009 | Miele Touchtronic W1119 Large Capacity...
Washing machine not draining or spinning. samsung j1043.
Samsung washer drain pumps usually have a trap that may be holding a large amount of debris (buttons, pins, coins, etc) and lint packs around all of it and the water can't drain, which means the unit won't spin. A more complete model number would be required to find out if the trap is accessible by removing the front panel or not.
Apr 25, 2009 | Samsung WF203ANW Front Load Washer
Both the intake and drain lights are flashing
There are several simple solutions, one is reading the instruction manual. Check Intake: is any water entering? is it slow? This machine filters debris from the supply water so check the water intake filter. It is inside the end of the intake hose end against the home. Rinse it clean.
Drain: The same fault appears if the drain is clogged. Check if the lint trap is perfectly clean. Check the impeller (a set of fan blades) behind it spins freely. If buttons or coins get in there they can break off the fan blades and you can't drain water. Check the end of the drain hose if it drains. put it into a bucket or tub basin to observe how strong it pumps. Call Miele if these tips don't work. Be at the machine with Model and Serial number ready.
Dec 16, 2007 | Miele Touchtronic W1113 Washing Machine
Washing Machines Logo
126 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
mpservices
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
