1st plugged it in it was flashing green. Now flashing red?
How do i plug in the dvd player
It depends on how you want to view your DVD. If you are using an HDMI cable then you will plug into the 1st available HDMI input. If you are using component cables, then you would plug into the first available component input. Match the Red, Green and Blue cables to the R,G and Blue plugs. You would also have your Right and Left Audio cables that are Red and White. If you are using a composite cable then you would connect to the 1st available composite input. Yellow cable and then your Right and Left audio cables that are Red and White.
May 10, 2012 | Televison & Video
Base unit appears to be working, but neither of the charged handsets will work. Both are showing red and beeping, but will occasionally go green for a second before going back to red and beeping.
The units aren't paired. Call Graco at 800-345-4109 to have them walk you through pairing it. I'll try to explain what they just walked me through:
-Turn off all units. Make sure nursery and 1st parent unit is plugged directly into wall.
-Hold negative volume down on 1st parent unit. Keep holding it down.
-Press on button on 1st parent unit and let go.
-When you hear a beep, let go of negative volume button on 1st parent unit and then press it again.
-When you hear the second beep, let go of the negative volume button.
-If you have done it correctly, the 1st parent unit should have one red light at the bottom and the rest of the lights should be green.
-Turn on nursery unit and the 1st parent unit should pair with it.
-Repeat the above with the 2nd parent unit.
Nov 18, 2009 | Graco Imonitor Digital Baby Monitor
My glowbouy flashes green and red...what does this mean
According to the owners manual for these swimming pool lights, this is what each colored indicator means. Hope this helps.
Solid green
The battery pack is fully charged.
Slow flashing green
The battery pack is almost fully charged.
Slow flashing yellow
The battery pack is half charged.
Medium flashing yellow
The battery pack is less than half charged.
Fast flashing yellow
The battery pack has almost no charge.
Fast flashing red
A charging error has occurred and the light should be unplugged and then plugged back in. If the Fast Flashing Red persists after several attempts, the battery condition is questionable.
Also in the trouble shooting guide, it mentions this:
Problem: Red Indicator Light Is Flashing While Charging
A red flashing indicator light when charging indicates a selftest
error condition. Unplug the product and plug it in again.
Try this several times; if the indicator light continues to flash
red, unplug the GlowBuoy and take it to an authorized service
What does it mean when there is a solid red Power light on the ATT 2wire DSL wireless router?
it means 2 things. 1st it could be the adapter because theres still power to it and 2nd is the 2wire router is already defective. if its possible for you to bring the 2wire with the adapter to any computer store or to att store and have them plug a new adapter on it . or if you have available 5volts adapter you can try to check if power will be solid green using diff adapter definitely its the adapter but if you have tried it but power will flash green or red the modem is dead. powerlight of any router should stay solid green no matter what happen.
have it checked carefully so you dont need to spend $82 for the 2wire, adapter is $10 only..
Sep 26, 2009 | 2wire (1000-400108-001) Router
Battery light green, then flashes four times red, repeats
remove the battery
clean the connecting ends of ur laptop & battery,
plug it back in & then start it...
Aug 27, 2009 | Dell Latitude D600 Notebook
When i plug in my usb charger, the light flashes red green then orange. even without my battrie
try cleaning the battery(copper bits) try charging it on your lap top, it should flash red green orange, keep unplugging and plug back in again its worked for us
Jun 24, 2009 | Samsung NV3 Digital Camera
Kyocera fS-920KX. Not printing
There are actually some certain meaning on the red light and green light showing different information to user. The summaries are:
1) Green On, Red Off = Printer Ready.
2) Green Fast-Flashing, Red Fast-Flashing = Printer warm up.
3) Green Fast-Flashing, Red Off = Printer off-line.
4) Green Slow-Flashing, Red Off = Processing Data.
5) Green Off, Red On = Cover Opened, Toner Empty or Developer Unit / Drum unit missing.
6) Green Off, Red Fast-Flashing = Paper Jam or waiting for jam reset.
7) Green Off, Red Slow-Flashing = Paper Empty or Paper tray is not inserted.
8) Green Off, Red Off = Printer power is off.
9) Green Very-Slow-Flashing, Red Off = Printer in sleep mode.
10) Green (any condition above), Red Slow-Flashing = Toner low or paper empty.
So what is your printer condition? Better know what is going on your printer so can solve the problem
YBC (/\)
Jun 01, 2009 | Kyocera FS-920 Laser Printer
Powering on
OK ... after a lot of trial and error, I got mine to work. I think it may be a really low charge or something. I had to press the power button until it was completely dark ... no flashing faint green or any colors. Then when I plugged it in, I got a solid red and left it for awhile. Then when I pressed the power button I got yellow, red and green ... the computer recognized it and then got a solid yellow.
Before when I had it plugged in, I'd get a lot of red random flashing ... and it just didn't seem to charge at all ... even after a full day.
I think the issue was that it was in this "flashing state (red when connected, very faint green when disconnected)" It wasn't easy to get it to turn off completely. Most of the presses of the power button didn't change the state at all. But if I got it just right, I could see the faint green light go off. That's when I plugged it in and got a solid red light, and eventually a good charge.
Hope this works for some others.
May 23, 2008 | LeapFrog FLY Fusion Pentop Computer
Televison & Video Logo
15 people viewed this question
Top Televison & Video Experts
