Question about Brother MFC Office Equipment & Supplies
How do i reset Belt End Soon Message on MFC-9325CW
SOURCE: Brother MFC 9440CN
You need to order the drum unit. It's different from the toners. You can replace it after the part comes in - you do not need a technicain to come in to do it for you. You can find the part from Amazon or Brother website.
Posted on Sep 14, 2009
  • 150 Answers
SOURCE: drum en soon MFC 7340
The drum counter counts to 15000 then says replace drum soon. Just open the front door and press options. Select yes.
Posted on Feb 04, 2010
  • 9 Answers
SOURCE: I turned on my Brother MFC-7440N and
By the sound of it, it sounds like the drum for the laser printer is just about shot. Time to get another cartdrige.
Posted on May 16, 2010
Testimonial: "thanx - I have very little knowledge and any suggestion is appreciated"
  • 137 Answers
If the unit is giveing good quality copies keep running untill the quality gose bad .Then call local dealer and let them replace the belt . Wont hurt the unit to keep using it.
Posted on Aug 12, 2010
SOURCE: How do I change the resolution on MFC 9325CW so I can send large batches of scanned files as pdf?
i suggest you Go Visit Adjust your Brother Scanner resolution Video OR
In Case You Still face Problem and Need Online Assistance Then Please Follow Us For On : Brother Printer Support
Posted on Feb 07, 2014
What are brother printers that take tn210 cartridges
Brother color machines use it:
Brother DCP Series: DCP-9010CN,
Brother HL Series: HL-3040CN, HL-3045CN, HL-3070CW, HL-3075CW,
Brother MFC Series: MFC-9010CN, MFC-9120CN, MFC-9125CN, MFC-9320CN, MFC-9320CW, MFC-9325CW
Sep 29, 2017 | Brother Office Equipment & Supplies
How to reset " replace drum" for brother MFC-7860DW
Time to really order a new drum and really replace with a new one.
Resetting the drum unit will not improve print quality. It only resets your drum and allows you to continue to print. You decide when to replace the drum unit not the manufacturer!
1.Remove the drum unit and toner cartridge. Wait 1 or 2 minutes.
2.Replace the drum unit and toner cartridge into printer.
3.The error message "Change Drum Soon/Drum end soon" will continue to appear if the drum counter was not reset when you replace the drum unit.
4.To clear this error message, you need to reset the drum counter as instructed below.
5.Make sure that the machine is turned on.
6.Press Options.
To confirm you are installing a new drum, press 1.
7.When the LCD shows Accepted, close the front cover.
8.Your drum is now reset.
Jul 30, 2014 | Brother MFC-7860DW Laser All-In-One
Drum end soon again
My MFC-7420 began to display the message "Drum end soon" so I quickly went out and purchased a new drum. But I decided not to install it until I needed to. Because what does "drum end soon" mean? I thought it would mean that the print quality would deteriorate enough that I would notice the problem. So I continued to replace toner as needed, and pushed the blue cleaning thing down the wire regularly. This went on for over 3 years until *finally* I started having regular print job production problems. I replaced the drum, and the problems were solved. So,my advice is be prepared, but don't replace the drum until you have to -- the message means very little.
Mar 18, 2014 | Brother MFC-7340 All-In-One Laser Printer
Which MFC9325CW toner is low?
Go To Below official Brother Printer Page For Your problem, Brother MFC 9325CW FAQ Troubleshooting United States Hope It's resolve all Your Printer Problem,
Still having Problem Then follow Us For Brother Printer Support
Mar 06, 2014 | Office Equipment & Supplies
What does a belt life ends soon mean, on a brother MFC 9440ch color laser printer?
Are you sure of the error message? The Brother printers that I have used have Drum Ends Soon and Change Belt messages.
The Brother MFC-9440CN has a belt that can be replaced. The Belt unit has an life expectancy of ~50000 pages. The belt unit is part BU100CL and costs a bit over $150 at office supply stores. and some other stores have the unit for under $100. is one source.
When the unit says Change Belt Unit, follow the directions from the manual's maintenance section to replace the belt unit. See page 178 (page 189 of the PDF) . You have to remove the Drum and then the Belt Unit. Then slide in the new Belt Unit and replace the Drum unit. Then close the printer and turn it on. Finally reset the counter from the Machine Info sub menu (press Menu 8 4 and select the Belt Unit and press OK. Then press 1 followed by Stop/Exit).
If you mean the Drum Unit, that is part DR-110CL and costs over $175 at the office supply stores. Order this part when the Drum End Soon message appears and replace it if the print quality deteriorates (or when you have the new drum). The Drum Life is ~17000 pages. The steps start on page 166 (182 of the PDF). You need to remove the old Drum unit. Then remove the toner cartridges from the drum. Prepare the new Drum Unit, including putting the cartridges in the new Drum. Then replace the Drum unit and reset the counter.
I hope this helps.
Jun 04, 2012 | Brother MFC-8460N Laser Printer
I recently noticed a message that said "drum end soon" on the screen portion of my printer. With that I went and replaced the drum and toner. The problem is this: The "drum end soon" message never quit...
This message would continue to appear if the drum unit counter was not reset when you installed a new drum.
To reset the drum unit counter, follow the instructions below:
  • Press Menu on the Control Panel.
  • Press the Up or Down Arrow key to select Machine Info..
  • Press OK.
  • Press the Up or Down Arrow key to select Reset Menu.
  • Press OK.
  • Press the Up or Down Arrow key to select Drum.
  • Press OK.
  • Press 1 to reset the drum unit counter.
Thank you !!
Jun 09, 2010 | Brother MFC 7840W Printer
MFC-9420CN All-In-One Laser Printer Install OPC belt message
Perhaps your OPC belt is at the end of its life and needs replacing
Apr 07, 2009 | Brother MFC-9420CN All-In-One Laser...
MFC 9420CN
As far as the OPC belt - don't replace it until you start seeing ghosts and image defects! Reset it by:
Press 1 and 7 at the same time
Press 1 to reset the life counter.
Jan 03, 2008 | Brother MFC-9420CN All-In-One Laser...
103 people viewed this question
James Cagle
James Cagle
Jim Keysor
