Question about Dermabrush Advanced Cleansing System
I dropped my dermabrush and it will no longer work I checked the batteries, but it wasn't that; any suggestions?
    Top Expert:
  • Dermabrush Master
  • 78,267 Answers
All you can do is replace it.
Posted on May 19, 2017
Electric starter not working
Check battery terminals and voltage drop should not go below 11 volts when starter engaged.sounds like weak battery even new batteries could be weak if left on shelf to long fully charge on low amp charge overnight
Nov 09, 2017 | Cars & Trucks
Got a 97 Honda civic ex and it won't turn over,
It appears that the longer time to warm up is because there was no water in the radiator and running for 30 minutes would cause the motor to seize. Check it out.
Mar 22, 2013 | Cars & Trucks
My new psp will no longer read any games
just do what i did call playstation support tell them the problem and send it back for repairs my ps3 was doing the same thing it wasn,t the lens that wasn,t reading the disc it was the disc drive that wasn,t moveing check it out
May 08, 2012 | Sony PlayStation (PS) Console
Hi, I have a MTD Mastercut 96. I use it in France and I started having issues with it starting. I took it to the local repair place and they changed the battery and it worked for a few more cuts. I used...
the first thing i would check is the altenator especially if the battery was dead again PS go to harbor freaight and get a trickle charger and after every mow remove the battery and hook it to a trickle carger battery will last a lot longer
Sep 08, 2017 | Mtd Garden
I was riding my 2005 Suzuki LS650 (S40) a couple of nights ago, and my headlight went out. I purchased a new headlight bulb, and that still wasn't the problem. I then tried changing the two fuses,...
Hi, does the bike start and run, if yes, apart from lights and horn check what else works or does not work. If the bike won't start try checking the battery if OK find the starter solenoid and check the fuse on that. I had a similar problem many years ago on a Honda. turned out to be a blown rectifier/regulator. If you do cure the fault please remember to check the battery charging circuit is working properly. At idle a meter reading of around 13 volts is normal this should rise to 14/14,5 volts at 5,000 rpm. Hope this is some help.
Jun 25, 2011 | 2005 Suzuki Boulevard S40
It won't turn on at all. It won't even charge. It's only 4 months old. Wasn't dropped or exposed to water or elements. Was working fine yesterday morning, then about 4:30, it was dead. ...
How long did you let it charge, when the device is completely drained of power it may not turn on at first when you connect it. Let it charge for a little while and come back to see if it fixes it. Failing that, your probably going to have to contact apple for warranty help.
Jun 15, 2011 | Apple iPod touch
My 10"Dewalt drop saws brake no longer works. I've
when you changed brushes did you clean the armeture,should be bright an shiney,if yes then go to basics check imput power to on off switch,if yes check on n off switch is working right.check wireing while there(for broken wire ,loose wire)if all checks out ok i would look at armeture and windings.
Jun 27, 2009 | Dewalt DW703 10" Compound Miter Saw
About nikon L1 fuse on circuit board..
when you reinstall the batteries... check again that the plus and minus posts of the battery are correct
Robert
Jan 20, 2009 | Cameras
Dermabrush Advanced Cleansing System Logo
Top Dermabrush Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Dermabrush Health and Beauty Expert? Answer questions, earn points and help others
