Question about Garden
I have a 3510 Mahindra tractor. clutch keeps popping out when I go into reverse. unless I double pump the clutch then it stays in reverse. no problems when shifting to forward.
2 Suggested Answers
  • 5 Answers
SOURCE: I can't get the gear shift to stay in place, it pops out
sounds like your clutch is bad... usually refered to as slipping clutch, meaning that when you put the stick in gear and take your foot off the clutch it slips outta gear
Posted on Jul 02, 2009
2002 mahindra 6000 steering wheel turns infintly in both direction but no wheel movement weather tractor is on or off. Fluid reservoir is full.
either the pump is not working or the control valves are not working
have a service technician come out to diagnose the fault
May 07, 2017 | Mahindra Cars & Trucks
Need to adjust my clutch on my Mahindra 3510 tractor. When I put it in reverse it keeps kicking out of gear.
That is not a clutch problem it is a selector problem in the gearbox you need to check the reverse selector dogs and fork
Apr 25, 2017 | Mahindra Cars & Trucks
I have a 20 hp mahindra tractor with front end loader the problem I am having is it will not go up a slight hill in forward or reverse what can I do thank you
If it is a hydro or automatic it sounds like you need to check fluid levels, if manual trans you may need a clutch or clutch adjust
Dec 12, 2016 | Garden
2810 Mahindra tractor electric PTO does not work also engine does not shut off when key is turned off also fuel gauge stays on full. can this all be from the same problem?
most probably a faulty relay in the ignition circuit for the gauge and running on problems
probably a relay for the pto not being energized from the pto switch
Oct 23, 2016 | Garden
Huskee LT4200 will not go up hills unless I keep poping the brake off and on
sounds like you need a new spring on the clutch /brake pedal
May 14, 2015 | Garden
Why does reverse need double clutching to engage? This problem still exists even after changing clutch kit! I have a 2003 subaru impreza station wagon.
Your shifter is it loose when you put it in gear does it move more than a inch bushing might be worn out so it makes it hard to put it in reverse how your clutch pedal do you have to mush play in it might have air in the clutch hydrolic need bleeding
Apr 10, 2015 | 2003 Subaru Impreza
Jul 01, 2009 | LG enV VX9900 Cellular Phone
Garden Logo
16 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
