Sabro split f6 fault - Heating & Cooling
3 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: Yonan Split Air Conditioning System
F6
ambient temp.
sensor of outdoor
fault
1?Check whether the resistance of sensor is normal,
otherwise replace it.
2?Check whether the sensor wire is short circuit or open
circuit, and whether the plug is well contacted, whether
there is welding off or rosin joint on the electric control
board, repair it if there is any above.
3?When the 1 and 2 are both normal, then the components
or integrated circuit is damaged, the electric control
board should be replaced.
Posted on Dec 02, 2010
gopakumarg43
  • 73635 Answers
SOURCE: Sabro split ac model U0230100A8 need code for universal remote
If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name to your device, in the "Search box at the top right of the display window" to see the set-up codes to your device, with different brand remote controls.
Posted on Aug 20, 2015
Solution for f6 code in voltas split ac
Indoor unit fan motor is defective - good luck
Read more: Voltas saplit ac not working error c ode in display f6? - F6 error code in split voltas air conditioners :: Ask Me Fast at http://www.askmefast.com/Voltas_saplit_ac_not_working_error_c_ode_in_display_f6-qna8442437.html
Jun 05, 2016 | Heating & Cooling
What is F6 problem of godrej split ac
respected sir,
I am used in godrej split ac now AC starting the time is okey but after two or three minitues showing F6 .How can solve the problem please help me.
Thanking your sir,
msmohan
May 01, 2012 | GE Heating & Cooling
How to start air conditioner in f6 mode
i need assistant , when i on my ac .after 1minute it shows f6 and off
Apr 17, 2012 | Heating & Cooling
My onida split ac shows F6 . What can I do?
onida 1 ton split ac F6 earror how problem retified
Mar 10, 2012 | Heating & Cooling
Out door is not working
Check for communication from indoor to out door.Check power in out door unit. If not, check the following.
Keep cool mode and temp setting minimum 3 degree less than room temp.
Check indoor unit return air sensor. Disconnect sensor from PCB and measure resistance. 8 kOhm at 30C and 13 kOhm at 20C if not replace air sensor
Check Indoor Pipe Sensor Disconnect from PCB and measure resistance. Pipe sensor = 5kOhm at 25C. If not replace pipe sensor.
Thanks and hope helpful?
Feb 04, 2011 | LG LS-L1210CL Mini Split Air Conditioner
Yonan Split Air Conditioning System is showing a F6 Fault. What is the fault code related to
F6
ambient temp.
sensor of outdoor
fault
Dec 01, 2010 | Heating & Cooling
Mistral Air-con split system shows F6 fault! What does it mean?
F6 INDICATION MAY MEAN THAT THERE IS A PROBLEM WITH THE BLOWER MOTOR. WHEN THE BLOWER MOTOR GETS HEATED UP (WHEN ITS WINDING BECOMES WEAK) THIS MAY HAPPEN. SO U GET UR BLOWER MOTOR AND PCB BOARD CHECKED.
Nov 23, 2009 | Heating & Cooling
Red Flashing F6 code
The fault code that you have on your washing machine is in fact Fb (fault block?) and not F6. Your machine is telling you that the water level has gone over the safety level more than 6 times, ie there is a problem with the pressure switch or a problem with a blockage or even a split hose in the air pressure system, ie the thin tube. Before you check these things, have you checked the filter at the bottom of the machine as this can cause the machine to flood if blocked, its worth a try. The pressure tube is a thin tube running from the top pressure switch to the bottom near the outlet area. This shd be free from any blockage, blow into it to see if it is free. and replace carefully. Electrics off the wall, etc,etc.
May 20, 2007 | AEG Lavamat W1050 Front Load Washer
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
