Question about Dryers
Do you have the upper drive belt routing diagram for a MTD JE130 13AF478E678
The belt isn't broken, just come off the pulleys
  • 5911 Answers
SOURCE: Need routing diagram of dryer belt on maytag dryer D7600
Go to and click on the "Repair Help" link at the top of the page. On the following page, locate the "Dryer Belt Diagrams" link under the "Special Features" section. Scroll down to Maytag. The dryer belt diagram for Maytag should be listed as diagram E. I hope this helps you.
Posted on Jan 28, 2009
  • 362 Answers
SOURCE: 1999 pontiac bonneville ssei supercharged belt routing diagram
This is the one for the supercharger.
Posted on Mar 14, 2009
  • 226 Answers
SOURCE: drive belt diagram for mtd rideon
hi;go to in your model # and make.then click on deck will be what your looking for.hope this helps.please rate this;Thank's
Posted on Jul 04, 2009
  • 667 Answers
SOURCE: 2002 Ford Escort ZX2 serpinten belt routing & tensioner pulley
go to on the lower right hand side under popular topics, click on timing belts, then on the left hand side click Parts Locator and Interchange, enter your cars info and the first page that comes up will show you a camera icon for a pic of how your belt is routed. The tensioner pulley is the one mounted on a silver arm, usually at the top. Hope this helps let me know.
Posted on Sep 22, 2009
  • 98 Answers
SOURCE: need fan belt diagram
Posted on Nov 11, 2009
if is like mine the belt goes around both spindels then come togeather and the back of the belt goes through the 2 pulleys on the front of the deck and goes up and around the motor pulley
May 21, 2017 | Mtd Garden
Pulley assembley underneath shift plate lower pulley main drive from motor upper pulley main drive to rear end : is there suppose to be a 1/4 -5/16 seperation between upper and lower part of pulley belt...
no, that is a weird clucth system, it is bad to stick and not move, remove the bolt and take it off, oil it and slide the inner piece up and down until it moves easy,they are bad for that should close both ways easy fix, just a nusince
Aug 15, 2013 | Mtd Garden
Mtd yardmachine 7 speed shift to go is my mower. it runs but want pull. does it have 2 belts or just the deck belt. the deck belt has more play than normal ..i think. as i was cutting the grass it stopped...
There are two belts, one for the deck and one for the main drive. The main drive belt can be seen on the upper pulley under the engine. Check to see if it has slipped or broken.
Aug 02, 2011 | Mtd Garden
My serpentine belt isn't going the right direction for one pully, how do i get it to go the right way?
If the belt is traveling the wrong way on one pulley, it has to be threaded wrong-you do not mention year, model or engine, if you come back on here you can get a diagram of the correct routing of the belt.
May 31, 2011 | Oldsmobile Intrigue Cars & Trucks
Drivebelt came off while on the highway (about 75 mph). Towed it home, went to replace belt and now both old belt (4 yrs old) and new belt (both 1025) are too long. Put on 1015 belt, topped off anti-freeze...
Hi, when a belt comes off, it's usually because of a bad bearing in one of the accessories or idler pulleys, or maybe your tensioner spring is broken. Remove the belt and check all pulleys for spin and play. It is also possible you lost an idler pulley and the new belt routing is not turning the water pump in the right direction. Check the routing and look for a missing idler pulley. Let me know if you are missing the routing diagram.
Feb 21, 2011 | 1988 Oldsmobile Delta 88
Belt routing diagram
SECTION 303-05: Accessory Drive 2006 Taurus Workshop Manual DESCRIPTION AND OPERATION Procedure revision date: 03/29/2005 Accessory Drive adobe.gif Printable View (137 KB) Accessory Drive Belt Routing
Item Part Number Description 1 10346 Generator pulley 2 8678 Belt idler pulley 3 3A733 Power steering pump pulley 4 8620 Drive belt 5 19D784 A/C clutch pulley 6 6B209 Drive belt tensioner pulley 7 6A312 Crankshaft pulley 8 8A528 Coolant pump pulley This vehicle is equipped with:
  • a V-ribbed serpentine accessory drive belt.
  • automatic drive belt tensioner(s).
  • a V-ribbed coolant pump belt.
New drive belts should be of the same type as originally installed.
2010&c18=modelyear&c20=n891472&c35=wsm%2caccessory%20drive%2cs6h%2c303-05%2cdescription%20and%20operation&s=1366x768&c=32&j=1.3&v=y&k=y&bw=995&bh=428&ct=lan&hp=n&[aqe] ddll111_5.jpg
Dec 31, 2010 | 2006 Ford Taurus
The diagram can be found here.
Remove the upper fan shroud and aircleaner assemblies for easy access.
To release tension on the belt turn the tensioner pulley nut clockwise and slip the belt off the alternator pulley. To refit the belt route as shown over every pulley except the alternator, once again release the tensioner and fit the belt to the alternator. See that the belt is properly seated over every pulley before restarting the engine.
Nov 11, 2010 | Isuzu VehiCROSS Cars & Trucks
Lawn Mower belt came off of pulleys
Go to this website, click on parts lookup in left hand column. Choose MTD then enter 13AN model number. Click on deck and it will show you how to route the belt. Hope this helps.
Jun 23, 2009 | Garden
Dryers Logo
Top Dryers Experts
