Question about The Office Equipment & Supplies
How do I arrange the carrier for changing ink cartriges
    Top Expert:
  • The Master
  • 79,865 Answers
They position automatically when the lid is lifted to access them.
Posted on May 19, 2017
Not print magenta or yellow
If you use CISS system. The problem may occur CIS. To solve these follow this proces:
1. put out cartrige from cartrige carrier
2. put a plastic seringe into the hole of the cartrige and try to out the ink from inside the cartrige ( mainly magenta or yellow)
3. Then run a head clean.
If result is No Try these:
1. Put off cartrige from cartrige Carrier
2. find out 4/6 stick inside the carrer
3. put a plastic seringe one after and push air on it.
4. After that take a seringe with ink and push it gentally into the stick.
I think you will be rid from your problem.
Thank you.
Jun 02, 2013 | Dell p713w AllInOne InkJet Printer
After changing the cartridge the Black in is not working
Your printer's head mainly (black holes) may be block by dry ink. Try to clean it. To clean follow these proces:
Take black ink in a plastic seringe Then unplug black cartrige. See inside into cartrige carrier. There is a black plstic stick. Try it to insert into plastic seringe (carefull). Then push ink through black stick. ( 4/5 times) . After that you will be relive from your printer problem.
Thank you.
Sep 11, 2011 | Epson Stylus Multifunction Inkjet Printer/...
Stylus R220. Just replaced the black ink and it still won't let me print. Keeps saying REPLACE CARTRIDGE. I'm using a Mac. Supply Levels Utility is completely useless. Says Information Not...
Try to clean cartrige and cartrige carrier conector place with soft erager.Then put cartrige into cartrige holder then gentaly push top of the cartrige sothat a `cat' sound happend, then turn on printer.
I think you will relive
Thank you
Sep 06, 2011 | Epson Stylus Photo R220 InkJet Printer
I would like to replace ink holder belt in epson stylus r220 printer
It's very easy.
uncover the printer. Then look left and right site of the printer. There you find 2 lock in left and 1 lock in right side. In right side there is a spring tidely back side of the printer. then open all the parts from left side and right side. put of the plastic sensor that are sruck right to left in the back side of the printer. Then put off iron rod into the ink cartrige carrier. Then try to put off cartrige carrier from the printer ( where the carrier is parked). Then look the belt in the back of the cartrige carrier. Then replace it .
Thank you
Jun 27, 2011 | Office Equipment & Supplies
How do i change my lexmark x4650 print cartrige?
Installing/Replacing your ink cartridges:
1. Open the printer, and then press down on the cartridge carrier levers. printmastert_52.jpg
2. Remove the used print cartridge or cartridges. 3. If you are installing new print cartridges, remove the tape from the back and bottom of the color cartridge, insert the cartridge in the right carrier, and then close the color cartridge carrier lid. 4. If a black cartridge is included in the box contents, remove the tape from the back and bottom of the black cartridge, insert the cartridge in the left carrier, and then close the black cartridge carrier lid. 5. Close the printer.
Sometimes the ink cartridge carrier won't automatically move to its loading position even when the printer is on and the cover is open. Follow the steps below:
1. Unplug the printer from the power source.
2. With the cover open, hold the solid white strip that connects from the carrier assembly to the ink cartridge carrier and gently slide the cartridge carrier to the center of the printer.
3. Remove the used cartridges.
4. Load the new cartridges. Close the cover.
5. Plug the printer back to the power source.
May 15, 2011 | Lexmark X4650 InkJet Printer
Not printing correctly. Says to align cartriges. After aligning cartriges, it stills prints incorrectly no mater how many times I align cartriges.
Clean the ink cartrige and the cartrige carrier with lukewarm water or alcohol on a cotton cloth and then install the cartridge. Even if that does not work then you will have to reset the printer for which turn off the printer and then press and hold power and start buttons for 10-15sec and then release.. Then try it again.
Oct 21, 2010 | Dell 964 All-In-One InkJet Printer
How do I change the ink cartriges in my printer
1.Turn on your printer.
2.Lift the scanner base unit.(The ink cartridge carrier moves and stops at the loading position unless the printer is busy.)
3.Press down on the ink cartridge lever to raise each ink cartridge lid.
4.Remove the old ink cartridges.
5.Insert the new ink cartridges. Make sure the black or photo ink cartridge is secure in the left ink cartridge carrier, and the color ink cartridge is secure in the right ink cartridge carrier.(Make sure to take off the sticker and the transparent tape from the back and bottom of the new cartridge.)
6.Snap each lid closed.
7.Lower the scanner base unit until it is completely closed.
Enjoy printing...
Sep 14, 2010 | Dell V305w All-In-One R840635AU InkJet...
I wnt to change my ink cartriges and it tells me to lift the lid of the printer and press the on button and the cartriges will come to the centre so that i can change then but they stay at the left hand...
I just had same problem. I fixed by unplugging the printer, lift the lid and gently pull the carrier to the center by hand. I changed the cartridges and gently pushed the carrier all the way back to the left and plugged in and powered on and it was fine.
Aug 27, 2009 | Dell 924 All-in-One InkJet Printer
Narrow strip came out from my printer (dell all-in-one photo 924
It goes through the ink cartrige holders and hooks onto the frame. It's called an encoder strip.
Feb 16, 2009 | Dell 924 All-in-One InkJet Printer
Carrier jam on dell 924 printer??
I was able to fix this issue on my all-in-one 944 printer. What happened was that one of the ink cartridge lids had popped open. The hard part was that the carrier was stuck on the far left side, and I wasn't able to pull it over for easer access. However, I was able to fit a finger in and push the cartridge back down. Then when I turned the printer back on the error went away.
Hope this helps
Dec 13, 2007 | Dell 924 All-in-One InkJet Printer
16 people viewed this question
Top The Office Equipment & Supplies Experts
thetraveler
Level 1 Expert
Folusho Adeyanju
Folusho Adeyanju
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
