Question about Cirrus Vacuums
I recently came into possession of a cirrus 79 and I am having a really hard time trying to push the vacuum over carpeting. Is there another adjustment that I can make?
I have pushed the lever on the left side of the machine marked 'floor' / 'carpet' but it doesn't alter the height of the machine. I'm not sure what it adjusts.
  • 6 Answers
SOURCE: Hoover Windtunnel carpet level adjustment
The suction is so great that it sucks up your carpet, then nothing works. I get my children to stand on the corners/edges of the rug so that it stays perfectly flat on the floor while I vacuum. Or, you can turn off the brush roller (set it to "hard floor" setting). Or, tip the vacuum cleaner's front up slightly while vacuuming, to reduce suction.
Posted on Nov 12, 2008
Vac Belts
  • 701 Answers
SOURCE: Bissell Pet Hair Erase does not vacuum.
It is because the belt is worn or stretched and needs to be replaced. Here are the belts you need and the manual which has instructions:
Bissell Pet Hair Eraser Belts and Manual
Posted on Dec 30, 2009
jim4984
  • 797 Answers
SOURCE: The vacuum takes super powerful muscle to push on
Two things first, turn the vacuum over and ensure the wheels turn easily. Then check that the brush turns fairly easily. You will be turning the drive motor so there will be some resistance. If there is no resistance then the drive belt is probably broken.
Let me know how you make out.
Posted on May 19, 2011
  • 5370 Answers
SOURCE: The vacuum has worked fine
The 'automatic' height adjustment consists of front wheels on a swivel mechanism that is forced up or down according to how high or low you are holding the vacuum. So, if you are holding the vacuum at a height for normal operation by it's very design it will be forced into the carpet too deeply which the belt cannot handle, thus breaking it in record time. "The only way I was able to rectify this was by shoving a piece of cardboard under the wheels at an ideal height that would still pick up dirt but not bear down onto to the carpet!"------- ------ In some cases the belt breaks and brush stops working.So inspect the belt and brush too.Sometimes its the broken belt or stuck-up brush problem causing this.--------- It's usually the belt that causes the brush to stop . What happens is, over time the belt will get hot, which causes the belt to stretch. Once the belt stretches out, it becomes too long, and will stop the brush from spinning when it feels any resistance to the brushes. This is most likely why the brush is stopping when you put it down on the carpet.---------- Getting this possibilities checked will help.Thanks.Helpmech.
Posted on Aug 20, 2011
ka4iup
  • 3960 Answers
SOURCE: Just bought a DC33. Multi-floor.It is very hard to push on the carpeting.It is fine on the wood floors.Is there any way to adjust it higher for the carpeting.It is dense carpet not high
There are no floor settings for this unit. Since the brush is spinning, it will create more resistance when running over the carpet.
https://www.dyson.com/support/dc33/dc33-multifloor/flo-dc07-gen-how-to-use-your-dyson/using-brush-control-dc33
Posted on Apr 11, 2015
Why is it such hard work to hoover the carpet with the dyson dc 33.it is really hard just pushing it across a new carpet.
Are your belts working and is your power head set too low? Try raising it up one or two clicks. A broken belt will not let your brushes spin and a spinning brush will help it go on carpets.
Aug 20, 2016 | Dyson Vacuums
My Riccar 8850 is very hard to push, even moreso on heavier pile carpet. Know any reason why? Also see my "more details" section.
adjust the setting on the vacuum head to pile or plush carpet
it is a simple lever that raises the hood to allow more air under it to make it easier to push
Oct 07, 2015 | Riccar 8850 Vacuum
Why does my Dyson DC17 now push really ******* carpet?
Have you correctly replaced the glider that covers the brush? You need to make sure that the clips are fully seated .
Aug 16, 2014 | Dyson DC17 Animal Upright Vacuum...
Why is my oreck xl 21 hard to push on carpet?
sometimes the little rubber wheels in front wear out of round and bind. Try those first (if they're the tiny ones you must buy a pack of 20 from oreck directly) and Orecks are known for being hard to push when bag begins to fill up.
May 03, 2014 | Oreck XL Ultra Bagged Upright Vacuum
Adjust height for plush carpet
The best solution is to change your method of trying to push the vacuum. The more upright the handle is on an Oreck, the harder it will be to push. The lower the angle (the closer the handle is to the carpet) the easier it will be to push. There will be a huge difference. Use a straight stiff arm that is pointed directly down towards the carpet. Use your shoulder and have a near locked elbow. The vacuum will now push easily.
Jan 12, 2014 | Oreck XL Ultra Bagged Upright Vacuum
After changing the bag on my riccar it is very hard to push'
after putting a clean bag into the vacuum cleaner, more air can get through it, so it generates more vacuum, sp it is obvious, that it will be harder to push for some time. if it wont get better, it only means you didnt gt it with a clean airbag
Apr 22, 2013 | Riccar 8955 Upright Vacuum
Dyson 33 wont push on plush carpet
I'm sorry to hear you're having difficulty using your DC33 on this particular carpet. If you haven't already contacted our Helpline, I'd encourage you to do so, as we'll be able to discuss other options which may be more suitable for your needs.
You can reach us on 0800 298 0298 (UK), or 1-866-693-9766 (US). We'll look forward to hearing from you.
Best wishes,
Jack
Dyson Online Customer Support
http://www.dyson.com
Mar 27, 2012 | Dyson DC33 Bagged Upright Vacuum
When i am vaccuming it is really hard to push how do u change that setting
Raise your height adjust, and replace your belt. This will fix 99% of the problems with vacuums being hard to push.
Your height should only be as low as it takes to get your brushes to just make contact with your carpet. Peoples' natural inclination is to slam the vacuum as low as possible to deep clean the carpet, but in reality it's restricting your airflow and is cleaning less effectively, as well as making it harder to push.
A properly designed vacuum should be easy to push any time there's a new belt on. If these two solutions don't make it any easier, make sure your wheels are spinning free on the bottom.
-R
Aug 09, 2008 | Dirt Devil Vacuums
Vacuums Logo
Top Cirrus Vacuums Experts
Are you a Cirrus Vacuum Expert? Answer questions, earn points and help others
