Current obituraries - Washing Machines
Dc voltge use
Dc stands for Direct current its a constant non varying current
the only disadvantage is it will now able to travel over a long distance
http://www.instructables.com/answers/Why-DC-current-is-not-used-in-Homes What Are the Uses of Direct Current eHow Why do we use Alternating Current AC instead of Direct Current DC in power...
Jun 17, 2015 | Miscellaneous
Harley trouble codes
There are two types of diagnostic trouble codes (DTCs), current and historic. The Check Engine Lamp will not indicate the existence of historic trouble codes.
1 Current 53 ECM flash error
2 Historic 53 ECM flash error
3 Current 54 ECM EEPROM error
4 Historic 54 ECM EEPROM error
5 Current 63 ECM serial data low
6 Current 63 ECM serial data open/high
7 Current 63 TSSM serial data low
8 Current 63 TSSM serial data open/high
9 Current 61 Loss of TSM/TSSM serial data
10 Current 14 Loss of all ECM serial data (state of health)10 24 Loss of vehicle speed10 33 Loss of vehicle inhibit motion10 43 Loss of powertrain security status
11 Current 33 System relay contacts open
12 Current 33 System relay coil high/shorted
13 Current 33 System relay coil open/low
14 Current 33 System relay contacts closed
15 Current 99 Incorrect password
16 Current 99 Missing password
17 Current 41 CKP sensor intermittent
18 Current 41 CKP sensor synch error
19 Current 11 TP sensor open/low
20 Current 11 TP sensor high
21 Current 12 MAP sensor open/low
22 Current 12 MAP sensor high
23 Current 14 ET sensor voltage low
24 Current 14 ET sensor open/high
25 Current 15 IAT sensor voltage low
26 Current 15 IAT sensor open/high
27 Current 24 Front ignition coil open/low
28 Current 25 Rear ignition coil open/low
29 Current 24 Front ignition coil high/shorted
30 Current 25 Rear ignition coil high/shorted
31 Current 24 Front cylinder combustion intermittent
32 Current 25 Rear cylinder combustion intermittent
33 Current 23 Front injector open/low
34 Current 32 Rear injector open/low
35 Current 23 Front injector high
36 Current 32 Rear injector high
37 Current 16 Battery voltage low
38 Current 16 Battery voltage high
39 Current 43 VSS sensor low
40 Current 43 VSS sensor high
41 Current N/A (no speedo code for this) Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
42 Current N/A (no speedo code for this) Check engine light high NO CHECK ENGINE LAMP AT KEY ON
43 Current 35 Tachometer low
44 Current 35 Tachometer high
45 Current 25 Rear cylinder no combustion
46 Current 24 Front cylinder no combustion
47 Current 34 Loss of idle speed control IDLE AIR CONTROL
48 Current 35 Accelerometer fault
49 Current 34 Starter output high
50 Current 25 Ignition enable output high
51 Current 21 Left turn output fault
52 Current 22 Right turn output fault
53 Current 11 Battery voltage high
54 Current 31 Alarm output low
55 Current 32 Alarm output high
56 Current 41 Ignition switch open/low
57 Historic 63 ECM serial data low
58 Historic 63 ECM serial data open/high
59 Historic 63 TSSM serial data low
60 Historic 63 TSSM serial data open/high
61 Historic 61 Loss of TSM/TSSM serial data
62 Historic 14 Loss of all ECM serial data (state of health)
63 Historic 33 System relay contacts open
64 Historic 33 System relay coil high/shorted
65 Historic 33 System relay coil open/low
66 Historic 33 System relay contacts closed
67 Historic 99 Incorrect password
68 Historic 99 Missing password
69 Historic 41 CKP sensor intermittent
70 Historic 41 CKP sensor synch error
71 Historic 11 TP sensor open/low
72 Historic 11 TP sensor high
73 Historic 12 MAP sensor open/low
74 Historic 12 MAP sensor high
75 Historic 14 ET sensor voltage low
76 Historic 14 ET sensor open/high
77 Historic 15 IAT sensor voltage low
78 Historic 15 IAT sensor open/high
79 Historic 24 Front ignition coil open/low
80 Historic 25 Rear ignition coil open/low
81 Historic 24 Front ignition coil high/shorted
82 Historic 25 Rear ignition coil high/shorted
83 Historic 24 Front cylinder combustion intermittent
84 Historic 25 Rear cylinder combustion intermittent
85 Historic 23 Front injector open/low
86 Historic 32 Rear injector open/low
87 Historic 23 Front injector high
88 Historic 32 Rear injector high
89 Historic 16 Battery voltage low
90 Historic 16 Battery voltage high
91 Historic 43 VSS sensor low
92 Historic 43 VSS sensor high
93 Historic N/A Check engine light open/low NO CHECK ENGINE LAMP AT KEY ON or CHECK ENGINE LAMP ON CONTINUOUSLY
94 Historic N/A Check engine light high NO CHECK ENGINE LAMP AT KEY ON
95 Historic 35 Tachometer low
96 Historic 35 Tachometer high
97 Historic 25 Rear cylinder no combustion
98 Historic 24 Front cylinder no combustion
99 Historic 34 Loss of idle speed control
100 Historic 35 Accelerometer fault
101 Historic 34 Starter output high
102 Historic 25 Ignition enable output high
103 Historic 21 Left turn output fault
104 Historic 22 Right turn output fault
105 Historic 11 Battery voltage high
106 Historic 31 Alarm output low
107 Historic 32 Alarm output high
108 Historic 41 Ignition switch open/low
Aug 11, 2014 | 2000 Harley Davidson FLHRCI Road King...
How to fix error code 50 on EFX 5.21i?
Precor Error 50, Too Much Brake (Magnet) Current Probable Cause 1. Shorted or damaged wiring between the lower PCA and the eddy current magnet is the most common cause for this error.
2. Bad eddy current magnet.
3. Bad lower PCA.
Corrective Action
  1. Thoroughly inspect the eddy current wiring and connections ensuring that the wires are not shorted to the frame or shorted together. Repair or replace damaged wiring as necessary.
  2. Disconnect the wires from the eddy current magnet. Using an ohm meter, check for approximately 100 ohms across the eddy current magnet terminals. If the reading is considerably low, replace the eddy current magnet. Measure ohms between each eddy current magnet terminal and the frame ground. You should have no resistance between the eddy current magnet terminal and the frame ground. If resistance is present this would indicate a partial short, replace the eddy current magnet.
  3. If the eddy current magnet wiring and the eddy current magnet are both good from the above tests, replace the lower PCA.
Error 50 Too Much Brake Current on Precor Cardio Equipment
May 22, 2014 | Precor Exercise & Fitness
Precor elliptical
3. Bad lower PCA.
Corrective Action
May 22, 2014 | Exercise & Fitness
2003 harley softail will not start
Did you pull any error codes (Diagnostic Trouble Codes)?
1. Remove right side saddlebag and side cover if so equipped. Remove protective plug from data link connector. Other models will be under the seat.
2. To activate the diagnostic feature,follow these steps.
a. Create diagnostic test wire or use a female spade clip which will bridge the two terminals perfectly.
b. Install diagnostic test wire/clip across Terminals 1 and 2 on the data link connector, they are marked.
c. Turn Ignition/Light Key Switch to IGNITION and wait approximately 10 seconds (4 seconds lamp ON, 6 seconds lamp OFF) for check engine lamp to start flashing.
3. All trouble codes are sent out as a series of flashes. To retrieve the first digit of the trouble code simply observe the number of times the lamp flashes.
a. The lamp will then flash one or more times to indicate the first digit of the trouble code.
b. The length of time the lamp is illuminated and the length of time in which it is off are each about 0.5 second in duration.
4. The second digit follows:
a. Following the transmission of the first digit, there is a 1.2 second pause in which the lamp is off.
b. The lamp will then flash one or more times to indicate the second digit of the trouble code. Count the number of times the lamp flashes to retrieve the second digit.
5. If more than one trouble code is sent:
a. Following transmission of the second digit of the first code, there is a 3 second pause in which the lamp is off.
b. Once all codes have been sent, the data string is repeated. When you have recorded the same trouble code twice, it is an indication that the transmission has been restarted and that all trouble codes have been retrieved.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A "trip" consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diagnostics manual you're not going to know what they mean.
21 Current 12 MAP sensoropen/low
22 Current 12 MAP sensorhigh
25 Current 15 IAT sensorvoltage low
26 Current 15 IAT sensoropen/high
27 Current 24 Front ignition coilopen/low
29 Current 24 Front ignition coilhigh/shorted
30 Current 25 Rear ignition coilhigh/shorted
56 Current 41 Ignition switchopen/low
74 Historic 12 MAP sensorhigh
77 Historic 15 IAT sensorvoltage low
78 Historic 15 IAT sensoropen/high
79 Historic 24 Front ignition coilopen/low
80 Historic 25 Rear ignition coilopen/low
81 Historic 24 Front ignition coilhigh/shorted
82 Historic 25 Rear ignition coilhigh/shorted
Dec 28, 2013 | 2003 Harley Davidson FXST Softail Standard
Precor brake error 50
3. Bad lower PCA.
Corrective Action
Nov 26, 2013 | Exercise & Fitness
Write the differences between alternating current (AC) and direct current (DC).
I will try, but understand, though we can harness electricity for power, there are still mysteries surrounding the existence and interaction of electric charge.
Alternating current is an electric current that reverses direction at regular intervals. All household current is alternating current. That is how it is generated through power lines, our electric grid, from the source like hydroelectric dams through power lines and into our homes.
Direct current is electric current going only one way in a wire or circuit. Automobiles run on direct current. Science says the flow of electrons in direct current only travels one way. Alternators in cars start out producing alternating current, but with an electric device called a diode, the current is changed to direct current. A diode will only let current pass through it in one direction, but stops current flow in a reverse direction. Before the invention or discovery of alternators, cars used a belt driven generator to produce direct current. Alternators proved superior in generating electricity, however, so were adopted by auto makers.
Now purists will add something more: by convention we say that current flows from the positive battery terminal, through the wire circuits, through an electric motor, and then to ground and thus back to the negative terminal of the battery. So from positive to negative, right? Well, electricity is a negative charged electron flow through a wire, so purists say the current flow is actually from the negative battery terminal through the wire circuits and back to the positive battery terminal. It is confusing, so by convention we say (DC) current flow is from positive to ground, or negative.
Well, there you go. Is it crystal clear, or whut??? Lol.
Nov 08, 2013 | Cars & Trucks
Retrieve codes for 2003 road king
2. To activate the diagnostic feature, proceed as follows:
a. Create diagnostic test wire or use a female spade clip.
b. Install diagnostic test wire across Terminals 1 and 2 on the data link connector.
IMPORTANT NOTE ..If diagnostic test wire is installed across Pins 1 and 2 on connector in lieu of a Scanalyzer, the ECM is placed in a diagnostic test mode and the engine will start. The test wire must be removed from the data connector and the ignition switch turned OFF or the check engine lamp will continue to flash codes. A historic trouble code resides in the memory of the ECM until the code is cleared by use of the Scanalyzer or a total of 50 trips has elapsed. A "trip" consists of a start and run cycle, the run cycle lasting at least 30 seconds. After the 50 trip retention period, the trouble code is automatically erased from memory (that is, assuming no subsequent faults of the same type are detected in that period). The numbers after the 'historic' or 'current' is the speedo code number, but without the electrical diognostics manual you're peeing into the wind.
10 43 Loss of power train security status
Apr 11, 2013 | 2003 Harley Davidson FLHRCI Road King...
Trying to set correct time n date on deuce watch
On the back of the watch, press the "A" button. Then the top half of the LCD will flash the current "month" setting. Press the "M" button to change the month by 1 month. Press the "M" button until you have the current month.
Then press the "A" button again to change to the watches current date settings. The bottom half of the LCD will flash the current "date" that the watch has been set to. Press the "M" button until you have the current date.
After that, press the "A" button again to select the current hour. Press "M" to select the hour, and when you have the current hour, press the "A" button one more time to select the current minute. Press "M" until you get to the current minute. Once you have the current minute set, press the "A" button again to finalize everything, and your finished!
Dec 19, 2010 | Watches
I have an Error message 50 coming up when iturn on my eliptical
3. Bad lower PCA.
Corrective Action
Jun 27, 2009 | Precor EFX 546i Elliptical Version 4
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
