Weird noise and not draining at end of cycle - Washing Machines
3 Suggested Answers
SOURCE: Water does not drain from machine at end of cycle
it sounds like the out flow is blocked some where on the front of your machine normally down the bottom there is a door open it behind should be a tap/plug type of thing turn it but put something underneath to catch the water this takes time when done take the plug out all the way have a look at the fan behind it will probably be blocked
Posted on Aug 21, 2009
SOURCE: Neff dishwasher makes grinding noise from underneath after draining towards end of cycle, any ideas please?
pump is probably about to fail
Posted on Jan 04, 2015
I bought a new drain pump, installed it and still getting the OE message. I have checked the hoses. Took off the drain hose from the drum and checked all three outlets on it. Put it all back together and...
The valve also needs to open for the water to drain instead of recirculating the water. Is the water circulating during the wash or rinse cycle? If yes, check the diverter valve. Follow the drain hose to the valve - check for lose wire, if it getting current, remove wires, check conductivity. etc. It may have 120 Volts, so be careful. Do at your own risk.
Nov 23, 2013 | LG TROMM WM2688H 4.0 cu.ft. Front Loading...
I have a Maytag Quiet Series 200. In the beginning of the cycle, it makes a weird 'whirrrring' noise that goes away right after the first wash cycle. It's getting water. It's very noticable and I worry...
I have a quiet series 300 and it does that, too. I think it just balances the load before washing and is normal. I found this in the manual:
Normal Sounds
Your new washer may make sounds your old one didn
Sep 05, 2010 | Washing Machines
My Whirlpool washing machine AWM6100 is weird. it washes no problems but when it comes time to drain there is an awful noise any idea? it does drain and spin its just the noise
you may have something stuck in the drain pump that is rubbing or grinding on the impellar wheel
check for any obstruction in the drain pump and the hoses that led in and out of the drain pump.if you do not find anything then you may need to replace the drain pump. as long as this noise only happens in the drain cycle.
Feb 09, 2010 | Whirlpool AWM6100 Front Load Washer
Washer does spin and it makes a weird noise
Not familiar with model but must cases its the drain pump blocked. water needs lowered before spin cycle works. Lay drain hose out the door to empty. Drain pump is down bottom beside where this hose comes out. Undo the filter bung there and clean out
Dec 13, 2009 | Kenmore 24032\24036 Top Load Washer
Washer won't spin, but making funny noise and water drains
You have a broke motor coupling broken between the motor and transmission the part is not expencive but a little hard to explain how to put it in.
Mar 29, 2009 | Whirlpool Washing Machines
Loud noise, then not so loud, but now electrical burning smell and little draining
the smell is your clutch and the lack of draining is a clogged washer drain protector. see these at www.repairclinic.com drain protector is part 541811 and clutch is 2670. go there enter model number and scroll down to the red 100 click it and look for these part numbers.
Mar 02, 2009 | Whirlpool LSR5132PQ Top Load Washer
Washing Machines Logo
18 people viewed this question
Top Washing Machines Experts
