Question about Plumbing
Is it possible to get the section with the sprayer head. I'm afraid the end section I have was damaged. It is a 5ltr sprayer I have.
Volvo c70 windshield sprayer not working
Try disconnecting the tubes from the spray head (under the hood). The press spray button, if nothing comes out, you have a bad pump. It liquid is pumped, then you need to clean or replace the spray heads - they are clogged or damaged
Sep 04, 2014 | 2009 Volvo C70
My water pipe to my kitchen two-handle faucet, after it thawed out all I get is a small steam on hot & cold side. How do I fix this?
Could be a sediment clog in the sprayer head. Remove sprayer head from flex line and clean out the end that attaches to the water flex line.
Mar 16, 2014 | Price Pfister Side Spray With Hose and...
Windshield washer not spraying
dont follow the lines ,first try this .umplug the line from the head sprayers,make sure you have fluid in the reservoir turn on the washer motor you'll see the fluid ,that means the head sprayersare pluged clean them plug back the line hose and enjoy good luck.
Feb 11, 2014 | 2007 Chevrolet Chevrolet Impala LS
I have changed the radiator on subaru impreza 1996 filling it up with water aand it pouring out the exhaust why
And did you change the radiator because of an engine overheating problem? If that's the case, and you got everything connected back up right, I'm afraid you may have serious engine damage, a blown head gasket at least, and possibly further damage. Have it checked by a shop. Good luck.
Jun 22, 2012 | Subaru Impreza WRX STi Cars & Trucks
I have used Roundup weed killer in the past, and am satisfied. But I no longer have the instructions about how much product to mix per gallon (or quart) of water. I use small amounts, like a quart sprayer....
I have a 5ltr can of Roundup and the dilution ratio for general week killing is 1 part Roundup to 4 parts water. I use this ratio all the time and it workes a treat.
Mar 10, 2011 | Garden
New Kingston Faucet has continual leak (when it is used) from the sprayer... where the spray handle connects to the hose.
unfortunately this is a common problem with sprayer heads, check the rubber gasket for any defects and also check the gasket seat on the sprayer end and the supply line end for any debris or defect. sometimes the only way is to replace the sprayer itself.
Dec 07, 2010 | Kingston Brass Chatham Satin Nickel...
Hi, just bought a sink spray head, put it on and water is coming out the base of sprayer, what did I do wrong?
If it's from the fitting where the sprayer head is attached to the hose check to see if there is a rubber washer. If the leak is not from the lack of a washer or damaged washer. Uninstall and take back for a replacement. There is nothing wrong with what you did. It should not be leaking.
Apr 08, 2010 | Danco CORP A0089221 KITCHEN SPRAY HEAD AND...
Not much pressure on fimco 15 gallon sprayer - purchased new 2.1 gpm motor - it sprays but not a lot comes out - seems not much pressure - Thanks.
Is it possible that the pick-up tube inside the sprayer is clogged up, or the hose it damaged? Maybe dirt in the spray handle/wand?
Oct 26, 2009 | Fimco Trailer Sprayer, 15 Gallon, 2.1 GPM,...
Sprayer leaking from inside handle mechanism
although it is possible that the spray head has gone bad, it is more likely that the diverter mechanism inside the kitchen faucet needs replaced. When this part is defective, it allows full pressure from the faucet to go to sprayer head even though the sprayer is not triggered. The sprayer is not designed to handle full pressure when it is not spraying.
Jun 05, 2009 | Price Pfister Marielle Kitchen Faucet with...
Plumbing Logo
23 people viewed this question
Top Plumbing Experts
Paul Carew
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
