Question about Supersonic Televison & Video
Hi i'm using supersonic tv model:SLM-3203 42 plasma the sound comes out perfect but the picture goes off after 5 seconds you have switched it on please help?
The tv has two pc boards 1st is power pc board the 2nd is main pc board i'm not sure which pc board to replace could you please come to my rescue?
    Top Expert:
  • Supersonic Master
  • 76,848 Answers
Only by the book testing will determine which board is the problem.
Posted on May 19, 2017
I am getting a black screen constantly, this is the 2nd Samsung Smart TV we have had with the same problem. This TV is only 3 years old
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main digital board.
This is a common fault to all models of modern Samsung brand LCDs.
Sep 08, 2017 | Samsung Televison & Video
No picture no sound click ok goes off
can you tell use the patter in which the light blinks??
it will help us to decode the problem easily
Jul 14, 2008 | Philips 50PF9956 50 in. HD-Ready Plasma...
Hi my supersonic model slm-3203 lcd turns on but after 5 seconds to 10 seconds screen goes black but sound still works
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
May 22, 2017 | Supersonic Televison & Video
2nd try see last sentences....lg led 32ln5310 tv, sound but no picture, no backlights, nothing visible on flashlight test, what should I replace? Main board, T-Con Board, Power Supply board or Leds
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/ It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Search the site by type in the "brand name" to your device; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Feb 10, 2017 | Televison & Video
I have a samsung lnt4066 led TV with a distorted picture. I have replaced the main board, power supply and the t con board with no success. I have pictures of what the TV is doing and would like to sh
You either have a bad t-con board or the screen is bad. Check to make sure all the ribbon cables are seated fully and connected. Even replacement parts can be bad sometimes, new and used both.
Jan 09, 2015 | Samsung LNT4069F 40 in. LCD TV
Olevia 242fh-t11 Symptoms: 1st remote would not turn on tv, had to use button on tv at bottom right. Remote would work after tv warmed up. This went on for a few weeks then... 2nd after tv was turned on...
Fault with the main power supply regulator board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Nov 02, 2014 | Televison & Video
Lg 32lc7d hdmi no signal
Try another HDMI source (borrow a friend's BluRay for example} to confirm it is the TV at fault. If it still doesn't work, the TV needs a main board replacement because all the HDMI circuitry is on the main board. this usually happens after a power surge or lightning storm, and a near hit is all it takes, Sometimes, if you have a Satellite Receiver it too might be damaged on its HDMI output. So 1st try another source..IF you replace it yourself be sure to find the right board by using the TV's service # example 32LC7D-XX.XXXXXXX.. The letters where I have Xs are very important and must be matched,
Mar 30, 2014 | LG 32LC7D Television
TV shuts off after 3 seconds
If the sound is still heard then the inverter board has failed and is triping the powersupply,if no sound the powersupply has failed.
Len..
Mar 29, 2014 | Panasonic VIERA TC-P50U50 50-Inch 1080p...
Panasonic TC-P42X1 acts like it is turning on, the screen turns black, then the tv shuts itself off and back on again.
Rule out any loose contacts in power outlet, RC Jack, cables and connectors. The problem described by you calls for opening the back cover and further investigation, which should only be done by a qualified service technician.
Aug 17, 2012 | Panasonic TC-P42X1 41.6 in. Plasma HDTV
Televison & Video Logo
32 people viewed this question
Top Supersonic Televison & Video Experts
Gareth Cockram
Gareth Cockram
Jason Morris
Computer Repairing
Computer Repairing
Are you a Supersonic Televison and Video Expert? Answer questions, earn points and help others
