. my problem is not sliding the unit in the wall, but removing the back cover where it reads FEDDERS. I tried unscrewing the back of the sleeve so I can push out the FEEDERS cover but I couldn't
  • 4 Answers
SOURCE: frigidaire air conditioner
remove cover .It might have two screws on the side or just pops off. Pull unit out from cover. if it does't move remove screws in back of unit near condensor
Posted on Dec 29, 2007
SOURCE: u61 on panasonic dmr es15
For U61 errors:
Turn unit off
flip down front a/v input panel
simultaneously press the channel up and stop buttons for at least 10 seconds.
Posted on Jun 03, 2008
  • 374 Answers
SOURCE: How to remove old Mueller (1951) wall mount faucet
Faucets are installed from behind the wall and there fore you will need to either cut the sheetrock on the opposing side or cut part of the tile out on the front to gain access to the valve. It is better if you come in from behind as you can build an access panel if you ever need to gain access again.
Thanks for using Fix Ya.
Posted on Nov 09, 2008
  • 114 Answers
SOURCE: I cannot remove the back cover of Nokia 6600
I loved my Nokia slide, but whenever I needed to get the back off I ended up going back to the shop, every time!! It just would not come off. The boys in there couldn't get it off without a struggle either. Design glitch they called it. Perhaps it eases in time, but its the same old story you just cannot force it at all. I have another phone now - same problem!!
Posted on Apr 27, 2009
SOURCE: I have ordered a Kenmore 75085 thru-the-wall ac
The unit arrived ahead of schedule. My solution was to open the box. Yes, the Kenmore 75085 does include an installation sleeve.
Posted on Jun 04, 2009
How do I take the unit out of the sleeve to clean it?
remove front cover,unplug from wall and slide out of case.
Aug 07, 2015 | Kenmore Heating & Cooling
Have old fedders a/c and heater. Seems to rub on something when using and makes noise. Need to remove front or back cover to see what is making noise. Can't find anyway to remove either cover. ...
All depends how old. The 70's and 80's models slid out of the case. If this is what you have, take the front off and slide the unit out of the case. If it had screws to take out, they would be around the bottom of the unit.
May 28, 2011 | Fedders A6X05F2D Air Conditioner
Where are the drain ports on a Fedders A3XO5F2E-A My unit is leaking water on the floor even though it is tilted down. ...
The drain holes are in the back corners of the pan...and they will plug with dirt...to get to them you will need to slide the unit out of the chassis if it is that type or pull the whole unit out so you can take the cover off and open the holes...
Then you will be back in business again..
Air Conditioner Trouble - Review the Possibilities
heatman101
Sep 15, 2010 | Fedders AEY12F7F Wall/Window Air...
We need to remove the drives side head rest to install a seat cover, but we cannot figure out how to remove the head rest. How do you remove the driver's side head rest?
Head Restraints Removal
  1. Unscrew front seat head rest guide rod retainers (610A18) .
  1. Pull up on front seat back head restraint (611A08) . Compress foam in area of front seat head rest guide rod sleeves (610A16) .
  1. Remove front seat back head restraint positioning springs. Pull front seat back head restraint up and out.
Installation
  1. Slide front seat head rest guide rod retainers onto front seat back head restraint posts.
  1. Compress foam in front seat head rest guide rod sleeve area. Install positioning springs on front seat head rest guide rod sleeves .
  1. Insert front seat back head restraint posts (notches on posts facing rearward) into front seat head rest guide rod sleeves and push down to engage positioning spring.
  1. NOTE: Front seat back head restraint must operate smoothly throughout its range of travel, must remain in any fixed position, and must not be freely removable from the seat back. If any of these conditions are not met, check for proper installation of positioning spring onto front seat head rest guide rod sleeve .
    Tighten front seat head rest guide rod retainers onto front seat head rest guide rod sleeves .
  1. Adjust front seat back head restraint by applying hand pressure, either up or down, to center area of front seat back head restraint .
Aug 21, 2010 | 1998 Ford Taurus
Need to remove through wall fedder air conditioner
If it has a sleeve, just remove the front cover and give a little yank on the unit and it will start sliding out of the sleeve. Unplug the unit first, and the unit will slide all of the way out of the sleeve and you can just set it on the floor or wherever.
Jul 06, 2010 | Heating & Cooling
I have a 27 inch wall sleeve can a 26 inch friedrich unifit work?or do I need a 27 inch unit
the a/c units keep getting smaller, when unit replacement is slightly smaller , the extra space can be filled with a piece of plywood or rigid foam insulation with a thin layer of plywood, any edges seen from inside can be covered with trim, make sure the wood covers entire bottom layer of sleeve to properly support. or just find the larger unit if you can. hope this helps.
Apr 23, 2010 | Fedders A6U14W7B U Chassis...
Can Fedders Model #ABQ10F2A be put in the wall sleeve rather than on the window?
Yes, provided the outside portion of the a/c reaches through the waoo adequately to allow for the transferrance of heat to the outside.
Regards, --W/D--
Jul 29, 2009 | Fedders Heating & Cooling
Thru the wall pac unit
Yes, typically all through the wall type a/c's are in a sleeve. The sleeve is installed to the building and the a/c slides into the sleeve. Sometimes the a/c wil be fastened or attached to the sleeve, sometimes it will not and it will slide right out. Just be careful, they are very heavy and awkward.
Jun 19, 2008 | Heating & Cooling
Frigidaire air conditioner
Dec 20, 2007 | Frigidaire FAC124 wall/Window Air...
Heating & Cooling Logo
16 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
