Question about Kitchen Ranges
After pressing micro switch to turn on lights, it drops out after a minute.
Adding more to my question of interior lights not turning off I hav also tried another fuse, relay removed centre light & tested circuit of switch from off to doors changes circuit from doors to on doesn't...
sorry hav'nt seen your last posts so don't know if you have already been told this, but most modern vehicle's now the interior lights can stay on for at least 2 minutes , hope this is not being patronising , not meant to be
Feb 23, 2015 | Cars & Trucks
Microwave oven will not start but the light stays on even when door is open.
One of the micro switches in the door is stuck ( faulty ) there are normally 3 switches so after removing the lid open and close the door and you will see the door latches pressing in the button of the micro switch and one of them would indicate that one of the switches is not in line with the latch to press the button in or one of the micro switches has melted inside cosign the switch to release normally open or normally closed, you need a multimeter to test the switches in that case
Oct 07, 2013 | GE Spacemaker JVM1640SJ Microwave Oven
The heater light light comes on when first low circulation cycle is pressed but turn off when you press again but only for 20 minutes
It is supposed to. When the heater reaches the temperature you set, it goes off and the indicator light goes off too telling you the heater is off. Soon the temperature drops again and the heater, and the indicator light, comes back on.----This is the working procedure.------ The pressure switch, float switch all needs to be inspected.------- Also what is the exact brand and model of your heater.This will help, to get exact cause of the problem. --------- Keep updated, thanks.Helpmech.
Aug 13, 2011 | Pool & Spa
Won't turn on - I hit the power button on my Velocity Cruz micro reader to make it 'sleep', but not it won't come back on at all ... what can I do to make it turn on?
Usually when you have what i would call a power lock out. you must remove the battery and wait a few minutes and put it back in, and it usually fires up. Most electronics have these problems. If you are 100% sure the unit is charged with a green light, or no light at all, and you pressing of the top button does not turn it on then remove the back, it is very easy. You can lift it up with your fingernail. If new and faint of heart, under warranty, and all, then make that phone call. Otherwise, you must attempt to remove the connects to the big grey squared battery for a moment, which is said to be easy to do and the battery easy to replace. Look for instruction on the removal on YouTube, or other sites. However, I am more than sure this will solve the problem, unless it has been in liquid, a power surge, dropped, or in excessive heat or cold, or touched by some with "bad karma" for electronics (just kidding). hope this helps.
Jan 02, 2011 | Velocity Micro Cruz Reader R101 Tablet PC
First green light light blinking continiously when switch on,no respond when press any remote control button's,indoor cannot start at all
dear sir
i think its an micro controlling unit problem for solve this problem please make air conditioner,s main supply switch turn off and after two minutes again turn on for reset of micro controller system . i hope after that it will work .
hope answer the question
thank you
please vote!
Oct 02, 2010 | Heating & Cooling
Samsung microwave -the electrical panel runs, the
it sounds like it one of your micro-switches inside that control the power to the doors, if one of the switches is bad, it would cut the power , the panenl will light, the turn table will work, the fan will turn on , but you will not get any heat at all, micro-switches run depending onthe unit from 5-10 bucks, when you open the unit you will see the one that is bad, is usually bent or the connector might be burn or melt, good luck..!
Nov 14, 2009 | Samsung MU3250W Microwave Oven
Wont start (door lock light not on) & stops 10 min into cycle
Sounds like the door micro switch is out. You can check this by opening the door & pressing in switch lever with your finger should feel a clicking almost like popping a knuckle on your finger no clicking switch is bad. If switch is bad you will need to have it replaced. You could bypass switch but with all electrical parts it could be dangerous if you do not know what your doing. Switch $2.00 to $13.00 Labor is where they get you.
Mar 08, 2009 | Washing Machines
Self-cleaning error message f90
F90 Maximum oven door unlock time exceeded.
F91 Maximum oven door unlock attempts exceeded.
F92 Maximum oven door open time exceeded.
F93 Maximum oven door lock time exceeded.
F94 Maximum oven door lock attempts exceeded.
1. (F90, 91, 92, 93 & 94) Check the wiring between EOC & Lock Motor Micro Switch.
2. (F90, 91, 92, 93 & 94) Replace the Motor Door Latch assembly if necessary.
3. (F90, 91, 92, 93 & 94) Check for binding of the Latch Cam, Lock Motor Rod & Lock Motor Cam.
4. (F90, 91, 92, 93 & 94) Check to see if Lock Motor Coil is open. If open, replace Lock Motor Assembly.
5. (F90, 91, 92, 93 & 94) Lock Motor continuously runs - if Micro Switch is open, replace Lock Motor Assembly.
6. (F92, 93 & 94) Check oven door Light Switch - if open, replace Switch.
7. If all situations above do not solve problem, replace EOC.
F90 is a door lock code, Try this...
unplug the range.
wait 1 minute.
turn the range back on,
then while holding in on the oven door.
start another self clean.
wait 2 minutes.
then cancel the self clean.
do not release the door until the door lock light goes out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Dec 30, 2008 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Red light comes on but cursor does not move
Normal 0 Turn the mouse over and find the small rest/connect button on the bottom of the mouse and press it. This should connect the mouse to the receiver and work properly. If not, try pressing the receiver button and then press the button on the mouse. This should be done whenever you change batteries or glitch. Hope this helps you. Bud
Nov 20, 2008 | Micro Innovations PD905P
Kitchen Ranges Logo
29 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
