To fix Er 24. Bo monitor is not working . Shows Er 24 . How do I fix it
  • GI Consulting May 19, 2017
    Hi James , I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
    Is your computer's monitor not working? What brand and model of computer and monitor and approximately how old?
What does Er 4 mean on my cvs blood pressure machine
YOU did NOT SPECIFY your MODEL NUMBER but tonight ~ Christmas Eve ~ YOU got LUCKY! I found this and it may help you... but
"LCD shows "Er 4"
Pneumatic system leak
or cuff is too loose during inflation
And this:
LCD shows "Er 0"
Pressure system is instable before measurement
Be still and measure again
LCD shows "Er 1"
Systolic pressure detect fail
LCD shows Er2 Diastolic pressure detect fail
LCD shows "Er 3"
Pneumatic system is
blocked or cuff is too
tight during inflation
Place the cuff correctly
and try again
LCD shows "Er 4"
or cuff is too loose du-
ring inflation
LCD shows "Er 5"
Measure again after 5
minutes. If the moni-
tor is still abnormal,
please contact the
local distributor / ma-
LCD shows "Er 6"
Over 3 minutes while
pressure above 15
LCD shows "Er7"
EEPROM accessing er-
LCD twinkling
check error
LCD shows "Er 9"
MCU self-verity error
LCD shows "Er A"
Span error
LCD shows "Er b"
EEPROM Backup-error
Dec 21, 2017 | Health & Beauty
No signal going to monitor
1-Check out your video card to make sure it is properly seated in mo bo. 2- If video is from on board chip then add a video card to see if that works - if so your mo bo video is done.
Sep 15, 2017 | The Computers & Internet
What is Er 24? My Bp monitor is Bp 652. It does not function. Shows Er 24. How to fix it?
It means you need to buy a new monitor. There is nothing you can do to fix this at home.
May 19, 2017 | Computers & Internet
Electrolux dishwasher DF code after an er 01 code. how to fix at home
Hello Shirley - Typically error code ER01 indicates that a water leak is detected under the tub. Unit will possibly need a hydraulic kit. Try unplugging the unit or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. Could the error code DF possibly be PF? If so, PF means power failure and you should be able to start a cycle. If the error code continues to display on dishwasher then I suggest contacting a professional to accurately diagnose and repair it.
Sep 30, 2012 | Electrolux EIDW6305GB 24 in. Built-in...
I Am Using An Asus eee pc 1001px . hours it just fell from my hands and when powered on , the screen is cracked . i tried connecting it 2 another monitor . but itz not bootin up !. it shows " Select...
Check and secure the hard drive to make sure that the jolt did not mess up the connection to the mo bo. Then go into the bios to make sure that the drive is being recognized. If not recognized then you will get no boot up and it is possible it may have been damaged via the drop.
To confirm hard drive condition remove it and plug it into any desk top computer and see if it is recognized. If so perhaps the mo bo got damaged.
Aug 27, 2017 | ASUS Eee PC 1000H Laptop
Same problem pool heater shows hayward pool heater bo error
BO means that you have bypassed operations. ie automation. if no automation is present then press and hold the Down arrow and Mode button for 3 seconds.
Aug 01, 2009 | Hayward H Series Pool & Spa Heater 400k...
Monitor ACER 24" stop display after few seconds
This is not a Fix to the Problem, If you read some of the other "fixes" that relate to this you will see that it is a more serious problem and one that Acer should Do the Honorable Thing and have a Recall.
I actually went in side on three of the Same Monitors and one that was a 21 inch and found the problem is "HEAT"
You can see where a Board actually shows Browning on the Circuitry I am Going to try to order a new board P/N:AS08B360411.
I will update as soon as work is completed.
Apr 10, 2009 | Acer X241Wsd Monitor
Possilbe to reset monitor?
This document pertains to MX50, MX70, MX75 and MX90 CRT monitors.
NOTE: To reset the monitor to factory settings:
  1. Turn off the monitor by pressing the POWER button.
  2. Press and hold the plus (+) button and then
  3. Whith the Plus (+) button pressed, press the power button to turn on the monitor.
  4. Release both buttons.
Jan 01, 2009 | HP Pavilion MX70 17" CRT Monitor
C5707 transistor
There is a guy on ebay that sell these, that is your best solution
Dec 06, 2007 | Dell E173FP 17" LCD Monitor
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
