Question about The Computers & Internet
My ever start 1200a did not work out of the box also I charged it for 24 hours
Kohler cv15s
Your battery may bad. Unhook it,check voltage, charge it 24 hours. Check voltage, should about 12 volts. Let set 24 hours, check voltage , if not 12 volts, no good.
Aug 20, 2013 | Craftsman Garden
I purchased a Schumacher 1200A battery charger a few months ago and just last night tried to charge my 2007 Infiniti G35 battery. The vehicle gets limited use and when I went to start a week ago the engine...
I don't think you did anything wrong. I think your battery is tired and can't take a charge deep enough as it used to. As batteries get older and after repeated discharge and recharge during normal operation, they start losing their ability to hold charge as deep as when new. This is gradual and after a couple of years they drop to 50% and less. I think your attempt was "gallant" and you did everything correct, but it sounds that battery has flatlined on you and "Doc, the patient is gone"
Jan 05, 2011 | Schumacher & Fast Charge Starter Charger
Old or New battery not charging...or so it seems (Discovery 4XXX)
the charger is not charging its not putting any thing out into the batterys the charger clock is working but your not getting any charge from it
Mar 21, 2010 | iRobot Roomba 4210 Bagless Robotic Vacuum
Nokia 6300 Switching off
Purchasing a new phone is easy and everyone is always in a hurry to use new phone but never go through the manual properly. You did the same you didn't put the battery on charge for 24 hours. Now to check your phone take another charged battery for nokia put it inside your phone and start it. It will deffinetly work. In order to revive your dead battery keep your battery on charge while the phone is switched off for minimum 24 hours. If it gets revived its ok or else purchase a new one.
Jul 25, 2009 | Nokia 6300 Cellular Phone
Did you let it fully charge before you started using it? Most companies will tell you with any electrical things you need to fully charge before using. To fully charge it can take any where from 4 to 24 hours. So place it on the charger for a full 24 hours then see how it works. Then if it still doesn't work it may be defected.
~~~Good Luck~~~
May 22, 2009 | Wahl 2 Speed Hand Held All Body Massager...
I am charging the Garmin Edge 305 for 24 hrs or for at least over night, yet the Edge 305 will show 2 to 3 bars of charges and will last maximum 1 hour of riding time. What to do?
Discharge completely device then charge again for 8 hours.
If not working, then attempt Soft reset :
Hold mode and lap/reset for 10 seconds then release.
Start the device then by long press on start. DEvice should start and charge then
Mar 16, 2009 | Garmin Edge 305 GPS Receiver
Charging new battery
usually 8 hours.
for first charge.
on a brand new battery
Jan 29, 2009 | IBM ThinkPad T41 Notebook
New eco drive watch not working
Here's what I do. PULL OUT STEM (for some reason this has helped me charge stubborn watches). With stem pulled out set your watch under a UV lamp or other strong light. May take 24-48 hours under lamp to fully charge.
Dec 06, 2008 | Citizen Eco-Drive Silhouette EW869452D...
Computers & Internet Logo
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
