Question about Vizio Televison & Video
My Vizio VP322HDTV10A volume fades in and out. I have already completed the "hard re-start" recommended by the manufacturer. Is there any thing else I can do short of junking the TV?
    Top Expert:
  • Vizio Master
  • 80,407 Answers
No nothing else.
Posted on May 19, 2017
My 37 in Vizio TV sound keep fading out. Won't stay set on volumes I set it on
check to see if the volume button on the set is jammed against the frame
Feb 27, 2015 | Vizio Televison & Video
Just bought E420VL 42" LCD
Go into menu, sound set-up, and switch SRS to off. It's a vizio thing they came up with to act like "Smart Sound" where commercials won't be louder. It is total BS and does not work, it makes your normal sound fluctuate. Worked on all 3 of my Vizios. Hope it helps you.
Dec 13, 2010 | Vizio Televison & Video
The tv is 2 years old. it would turn off after turning on by itself. this happened for 2 days. it would stay on afetr you turned it on a couple times. then the next day wouldnt turn on at all
Had the same issue with my Vizio Plasma VP322HDTV10A. At power up it would turn on and off a number of times before it would stay on. In thinking it might be the power cord, I pulled it out and replaced it with a spare I had and it would not power up what so ever. I opened up the case and traced the the internal power coord to it's source and this lead to the main power supply board. I found three capacitors on this board with buldges on them (which the tops of the capacitors should be flat). I found a web side (SHOPJIMMY.COM) which had the parts I needed to repair the TV myself. the following is how much it cost to replace the needed parts
LG EAY42539401 Power Supply
sj-EAY42539401
$ 67.16
Vizio VP322HDTV10A Cable Kit
$ 29.36
LOC: DA
Subtotal
$ 96.52
Also Included Photos of the board with the failed capacitors
Nov 28, 2010 | Vizio VW32L 32 in. LCD HDTV
Vizio tv seems to have trouble with volume certain ch fox and ch 8 need to increase volume a lot also goes black loses sound g Have dishnetWork does true sound have to be off
It would be our pleasure in assisting you with that. We would recommend using our Volume Leveling feature which is available on our ViP222k, ViP612, ViP722k, and ViP922 receivers. Volume Leveling keeps the volume levels consistent between programming and commercials and prevents drastic volume level changes when watching television between HD and SD channels. Start by pressing the "Menu" button then pressing 6 for "System Setup" then 7 for "Audio Output". Select "Enable" below "Volume Leveling" then select "Done" to save these settings. If you're using a ViP922 receiver from the main menu select "Settings", select "Audio Output", and then enable Volume Leveling. This should help with the volume fluctuation issue you have been having. Thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Oct 25, 2010 | Vizio L37 Television
My vizio vp322hdtv10a, when prompted to turn on, turns on then off, turns on then off. This will go on for 3 minutes if I hold the power button until the unit will finally remain on. It started out minor,...
Vizio has been plagued with problems because of cheap capacitors they used in their TV's. The culprit is CAPXON capacitors. As they go bad you will see a bulge on the top of the capacitors, once they totally fail your TV will not turn on at all. When you have time, open the back and inspect the capacitors, looking for the ones that have a bulge. You will need to replace these things, they cost about 50 cents each from places like Mouser electronics. Look for low impedance and same dimensions and capacitor value as the ones that are warping.
After having and fixing the same problem I will not buy vizio again. I would have preferred to just replace the whole power supply on mine, but I found out that you can't get boards unless you want to pay 100++ for used boards. So I just replaced the capacitors that were warping for about 1.50 plus 5.00 for S/H.
When you buy replacement caps, look for caps that are made in USA or Japan.
Aug 09, 2010 | Vizio VP322 32 in. Plasma TV
My vizio vp322hdtv10A just quit working
2008?. Well anyway, Do you have a power light, if flashing... panel needs replacing...if no light...power board needs replacing
Jan 14, 2018 | Vizio L32 32 in. LCD HDTV
I have a Vizio 37 inch lcd tv. It works fine from
Hi msyaros
In order to have data`s specific to model , i would need the model# written on the back of the tv set.
Be waiting for your reply
Jan 31, 2010 | Vizio VX20L 20 in. LCD TV
My vizio vp322hdtv10a wont turn on any more the vizio light at the bottom isnt lit up . when i would try to turn it on it go off and on and make a clicking sound after half dozen times it would stay on but...
Soon after you do this for about, oh id say 2 months... depending on use... you will no longer get the problem. The TV will not turn on at all. I have the same problem with my TV and I'm taking it apart right now, and am going to see if its just the capacitor that no longer works, or if its the whole board that is fried. If you still get the orange/white vizio emblem, DO NOT UNPLUG FROM WALL. Unplugging from wall will completely drain the system and you will no longer be able to plug it back in after a while. We had the clicking thing for about 2 months before the tv died.
Oct 25, 2009 | Vizio VP322 32 in. Plasma TV
Televison & Video Logo
73 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
