F1 wat problem - Computers & Internet
Have protherm 100ec boiler british gas has replaced almost every part boiler will fire temp gauge rises to about 55 flame increase in strenght for about 10sec then boiler cuts out also they keep trying...
Any other symptoms? Is the fault apparent only when drawing hot water? Does the boiler re-light later? Alarm messages? F1? F3 for example?
It may well need a powerflush, but it's best to find out before spending big money with BG.....wish I could get away with charging that much for a flush!!!
FYV
Jan 27, 2013 | Protech Systems FasNSeal FSWMKE4 4" Vent...
Toshiba satellite P845-S4200 Idk wat the boot system message is bit I'm able to go to setup and etc no matter wat I always get the same message.... I can do longer vids now...
So, the problem is a boot record on your HDD. It can be deed HDD at all(hardware - must replace HDD) or just deed boot record on the HDD (software - must wipe HDD on low level and reinstal operation system as Windows).
To understand whats wrong - just download "Hiren's bootCD"(you can find it on any torrent trecker) then write it to CD or DVD and choice your CD/DVD drive as first boot device and boot from this CD - there is many utility on this CD to test your HDD.
Nov 14, 2012 | Computers & Internet
My hp laptop doesnt give any sound output..even though the drivers r workin properly..wat to do?
check that the mute is not on. the little speaker down by the clock is the place it should show. Also that the function key / sound mute button is not active. The sound mute button would be up in F1 etc
Jun 22, 2010 | Computers & Internet
Can u tell me wat e3 f1 means on my self cleaning kenmore oven
The e3 f1 code is a clock failure and you will need to replace it.
Mar 16, 2010 | Kenmore 40494 / 40495 / 40499 Electric...
Washing machine wont drain, door is locked, and cant get clothes out of machine, says F1 and F3 error. wat do i do?
sounds like a safety check is on. check the pump to make sure nothing is stuck in there. read the manual for checking pump on that Asko machine..
Oct 14, 2009 | Asko W6021 Front Load Washer
KEEPS SAYING PRESS F1 AND REBOOT AN IT WHEN I DO COMES BACK TO THE SAME SCREEN
Simple!! Get a bootable disk and reinstall your OS. The problem is with your OS. If you wat your backup remove your hard disk and put it in a working computer and backup all your files. then fix it in your computer and reinstall the OS as i said before. Rate me!!
Aug 17, 2009 | Computers & Internet
BIOS PASSWORD FORGOT WANT RESET
Link to this site for instruction of Bios password.
http://www.askvg.com/how-to-reset-remove-bypass-a-bios-or-cmos-password/
any further question don't hesitate to contack me.
thanks,
Mar 18, 2009 | Computers & Internet
Compaq Presario M200
wat do u read before this??
Nov 15, 2007 | Compaq Presario M2000 Notebook
Computers & Internet Logo
13 people viewed this question
David Payne
David Payne
