Question about Brother Office Equipment & Supplies
Brother p touch 1280 has just decided to print only Tiny and Size is set to normal. Any suggestions please.
  • 624 Answers
SOURCE: brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
Posted on Aug 02, 2007
nitinbabbar
  • 55 Answers
SOURCE: I have the same problem(Printer not printing in A3)
noramlly it happens because of 3 things
1) improper stettings of paper size,
2) dirty line sensor,(sensor with light)also called media sensor located on the right side of the catridge carriage unit,clean it from the from downside ,(from the point where light comes) with a cotton bud,
3)faulty flex cable ,connected from logic board to catridge carriage unit,
with these 3,u can definately fix it
do reply
thnx
Posted on Jan 28, 2008
SOURCE: setting custom paper size for hp 1280 in win vista
we loss the CD hp deskjet 1280 Serial No.CN65P8ZOHH want printer drivers
Posted on May 08, 2008
SOURCE: error in A3 print
I had the same problem. Didn't find the answer. I removed the HP 1280 driver and installed HP 1220 Driver. It worked. It prints all the sizes perfectly. What is in name if we get the prints on A3 size. whether it is HP 1280 or HP 1220 :)
Ajay
Posted on Sep 15, 2008
SOURCE: hp deskjet 1280 unknown a3 paper
Uninstall the HP 1280 driver and install HP 1220 driver. it will print on A3 size.
Ajay
PT 1280 suddently printing miniscule letters. Can't reset, have turned off using Shift/clear buttons, but doesn't change after settings redone.
What size tape are you using? If you have switched from half-inch to quarter-inch tape, then chances are that the printer is working correctly as the general size of the print is determined by the size of the tape. Beyond that, you can use the Text button at the top-center of the keyboard to enter the options for customizing the print such as the font used, the size (small, medium, or large), the width of the letters, and the style (such as bold, outlined, or shaded).
Jun 05, 2015 | Brother P-touch PT-1280 Label Printer
Brother PT1280 P-touch Machine User's Manual Download
You can download and print the instruction manual in PDF format from Brother PT-1280 support website by clicking this link
On the page which opens, click on the 'Download' button to download and save the manual.
Please note: Adobe PDF Reader is required to view this manual. Download the latest version of Adobe Reader. Thanks for using FixYa
A 4 THUMBS rating is appreciated for answering your FREE question.
Sep 07, 2010 | Brother P-touch PT-1280 Thermal Label...
Font size issue
Are you trying to print a two-line label?
If there are two lines of text, they are printed in size 1, regardeless the size you set.
Here is the procedure, described in the manual you can download from here:
http://welcome.solutions.brother.com/BSC/public/files/dlf/docp000113/pt1180ug01usen.pdf
Note:
• If there are two lines of text, they are printed with the SIZE1 setting applied,
regardless of the selected size setting.
• To quit the following procedure at any time without making any changes, press [BS/Clear] key.
1 Press [Function].
2 Press [<] and [>] until SIZE is displayed, and then press [Function] or [Backspace]. The current size setting appears in the display.
3 Press [<] and [>] and until the desired size setting is displayed.
4 Press [Function] (or [Backspace] ) to apply the selected size setting to the text.
Aug 06, 2009 | Brother P-Touch 1180 Label Printer
Error in A3 print
Ajay
Aug 30, 2008 | HP DeskJet 1280 InkJet Printer
Hp deskjet 1280 unknown a3 paper
Ajay
Aug 29, 2008 | HP DeskJet 1280 InkJet Printer
Printer Problem in HP-1280 Printer
go to printer folder , select properties and go to paper /quality , browse to A3, select, apply, OK
check print preview before sending your document
May 01, 2008 | HP DeskJet 1280 InkJet Printer
Setting custom paper size for hp 1280 in win vista
Apr 14, 2008 | HP DeskJet 1280 InkJet Printer
26 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
