Question about John Deere Garden
Jd 400 power loss after 15 min run time - John Deere Garden
  • John Deere Master
  • 7,515 Answers
Visit the on-line store, know as reliable-store, they have the repair manuals. I'm sure you will get the solution of your problem.
Best Manuals
Posted on Jun 08, 2017
4 Suggested Answers
SOURCE: loss of RPM
My 89 cherokee did the same thing and it was the crank sensor.
Posted on Oct 04, 2008
SOURCE: when i drive at above
Looks like you need to replace the fuel pump & the spark plugs as well
Posted on Oct 12, 2010
dttech
  • 4803 Answers
SOURCE: loss of power
Loss of power after running for a while can be caused by anything from a partially clogged catalytic converter to engine overheating due to a faulty engine cooling system. Lots of other things can cause it as well.
Posted on Mar 18, 2012
Loss of power in drive of my jd f935
These units run a hydraulic style transmission. The loss of drive could be as simple as low oil level. There is a check plug on top of the transmission, oil level should be within 1" of the fill hole. The probable loss of drive is from wear. This would require a new transmission. Repairing these style transmissions is expensive.
May 05, 2015 | Garden
I have JD 935 that runs fine for 10 mins then idles down. Never fully quits running. Changed fuel filters, lines, pump...
check for the cooling fins around the head and block are not blocked with grass clippings/ dirt/dust as it may be tending to overheat and boiling off the fuel in the mixture
Sep 16, 2014 | Cars & Trucks
1989 Chrysler Lebaron 2.5 Turbo Running slugglish
hallo
check if you have a spark when engine dies. if not, check the rpm sensor or ignition coil. both have the simptoms like you describe.
marko
Oct 08, 2009 | 1989 Chrysler LeBaron
I NEED INJECTOR PUMP SCHEMATIC FOR JD 400 PUMP
I'm getting hydralic fluid in my engine oil. I was told that it's coming from my power steering unit. It's a JD 400 tractor/backhoe. Would this be correct?
Jun 04, 2009 | John Deere 420,1020,2010,2020,2510,2520...
Loss of RPM
You might want to replace the crank sensor on the bell housing.
Sep 10, 2008 | 1998 Jeep Cherokee
Garden Logo
23 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Matt Olenzek
Matt Olenzek
Are you a John Deere Garden Expert? Answer questions, earn points and help others
