Question about Ovens
What wattage is the fan element on a leisure cuisine master 100?
3 Suggested Answers
FitzOriginal
  • 842 Answers
SOURCE: what kw is my leisure
If this is the RCM10CR model with electric hob and oven than it has a maximum rating of 13.8Kw (Page 6 of the manual, a pdf of which can be found here: http://www.leisurecp.co.uk/upl/31115-RCM10CR.pdf )
If it is the dual fuel RCM10FR then it has a maximum rating of 7.7Kw (page 6 of the manual, a PDF of which can be found here: http://www.leisurecp.co.uk/upl/55403-RCM10FR.pdf )
Posted on Jul 28, 2011
  • 46460 Answers
SOURCE: I have a leisure cuisine master 100 and the clock/timer is dead and my fan oven is not working can the clock be bypassed
Not if you ever want to bake anything .and have it turn off at a set time
Posted on Dec 05, 2015
Have Ck90g232 model,electric oven has no heat,the fan still works but not the light. All other ovens and hobs are functioning,is this an element issue and will a professional have to fix the problem?
The light may just be a burned out light bulb. Remove it and take it to an appliance store to find a replacement. As far as the oven goes, elements do burn out. They are relatively inexpensive. Make sure you have turned the oven OFF before you do anything. The heating elements do pull out and you can replace them yourself. Take the information about your oven and the heating element to an appliance store for a direct replacement.
Nov 15, 2017 | Ovens Ovens
My leisure 101 fan oven is not heating up the fan is coming on but not getting hot
Probable element has failed. Replace the element after testing it of course.
May 06, 2017 | Ovens
My leisure GRB6CVK electric oven(main oven) has stop heating up. Fan and light works but no heat. Help pls. Any thoughts. Sheryl
Unplug stove and take wires off element. test for continuity on the poles. Also check wire ends.
May 24, 2014 | Ovens
What kw is my leisure cuisine master 100
Jul 28, 2011 | Ovens
Is there a high failure rate on fan elements ?
It is not unknown for fan oven elements to fail quite regularly, some brands more than others, you must make sure you are fitting an element with the correct wattage, as this can make quite a difference to it's life expectancy.
Dec 01, 2010 | Bosch HBN 7052 GB Stainless Steel Electric...
My neff fan oven keeps blowing it element is there something wrong wit it? I have a double oven and its the bottom one that keeps blowing
It is quite common for neff elements to fail, make sure you have fitted the correct wattage element to it, as there are more than 1 element that will fit it.
Nov 12, 2010 | Neff U1721 Double circotherm Electric Oven
Leisure levc66x - bang from fan oven blew tripswitch - fan operating but no heat - top oven ok - 18 month old unit
It appears that the ring element for the oven has burnt out and will need replacing.
Hope this helped.
May 13, 2010 | Ovens
No heat generated in lower oven
You are quite correct in saying that the element has failed.
As regards the wattage , it should be stamped on the fixing plate of the element, if you cannot see it there then opt for the lower wattage one, it will not make much difference to the oven ,as there is only100watt difference between the 2., and that is nothing to worry about.
Plz rate my solution to your prob.
Thanks.
Jan 03, 2009 | Neff U1721 Double circotherm Electric Oven
Ovens Logo
14 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
