Question about Cell Phones
Emergency brake stuck on.
You did not specify make and year of vehicle. Most cars use a cable system under the car connecting to the brake lever or pedal inside the car to the emergency brake system on the back wheels. The most common problem is a seized cable somewhere under the car (corrosion, damage, etc.) - if this is the case, you will have to either have the cable replaced or try to loosen it.
Jun 26, 2015 | Cars & Trucks
What does ice mean and how do you use 911
Adding ICE ("In Case of Emergency") to your phone is a clever means by which emergency personnel can locate your next of kin when something goes wrong. This simple idea was developed by a British paramedic, Bob Brotchie, who recognized the need for speed when emergency personnel are trying to locate next of kin during disaster situations. Here is the simple way to keep your loved ones informed. 1.Open your cell phone's address book.
2. Program ICE - "In Case of Emergency" - with the name of your emergency contact into your speed dial. For example:
  • - ICE Bob
  • - ICE Mom
  • - ICE Mrs Crabby
  • 3. Let other family members and friends know. Alert family members that you have done this and encourage them to do so as well. This will help speed up responses from emergency personnel when they have to decide who to call in case of your injury.
  • To call 911, you dial 911 on your phone
Sep 27, 2014 | Kyocera Contact - Prepaid Phone Paylo by...
Emergency calls
Hi Ivan
Please see the following extract from Wikipedia re: your query.
From Wikipedia, the free encyclopedia
112 (emergency telephone number) 112 is the common emergency telephone number that can be dialed free of charge from any fixed or mobile telephone in order to reach emergency services (ambulance, fire and rescue, police) in numerous European Countries, including all member states of the European Union, as well as several other countries in the world. In some countries other numbers previously used also continue to be available; e.g. 999 and 112 both function in the UK. In the United States, some carriers, including AT&T, will map the number 112 to its emergency number 9-1-1.
Aug 14, 2014 | Samsung GT-S5300 Galaxy Pocket
Im guessing since this is an in dash dvd player your trying to bypass the emergency brake so it will work with the vehicle in drive. If this is the case all you have to do is take the wire that goes to the emergency brake and ground it somewhere.
Mar 04, 2013 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
"Several incorrect passwords have been
Probably a re-set will do. The re-set button is under or near the battery. You might need a paper clip end to re-set it. If that fails, see your provider.
Dec 12, 2010 | Cell Phones
My iphone is locked i can only make emergency calls please help
Have you purchased from new? Was it a second hand unit or passed down?
If a phone has been reported to a uk network as lost or stolen it will be placed on a barring list that is used by all uk networks!
If this is the case it will only allow emergency calls only as the network your using is barring it.
If you call your network they have access to the shared data base and can check within a few minutes for you. You will need the IMEI number from the iphone which you can find on the SIM tray in small print, or if you can access the phones number pad dial *#06# this will display the phones IMEI on the screen (this should work on any mobile phone).
Another solution maybe that your SIM card has been disconnected? Have you tried your SIM in another phone to check?
Hope that helps?
Mar 19, 2010 | Apple iPhone 3G Black Smartphone
Glofiish X600
power button (not the reset button) and the right soft key. Do not release right soft key until you get prompted for a "yes" or "no"
Dec 21, 2008 | Computers & Internet
Coputer bois issues
Pull the battery, and try on ac only.
is the hard drive spinning,
re-seat the memory ,
find the reset button its a very small hole somewhere on the case.
looks like the kind you see on cd rom emergency ejects.
Apr 12, 2008 | HP Pavilion dv6000z Notebook
Glofiish X600
I believed someone had entered too much inccorect passwords so it totally locked. You probably try a Hard Reset to bring the unit back to default setting but you may loose some data in it. To perform hard reset just hold the power button and reset button with your stylus at the same time and push.
Feb 27, 2008 | Eten Glofiish X500 GPS Pocket PC
PlatinumPAS ? preboot authentication services verify please insert a valid smartcard
Under the keyboard have a switch. Set the key number 3 in "ON". that's all folks.....
Feb 27, 2008 | Acer TravelMate 613TXV Notebook
Cell Phones Logo
24 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
