My chart access has been disabled, how do I restore?
What can you do to fix a disabled ipad2?
If your iPad has become disabled permanently, your only choice will be to reset the iPad in iTunes and restore from a backup. This may seem like punishment, but it is actually for your own protection. If someone stole your iPad and tried to unlock it, the iPad would become permanently disabled, thus keeping the person from getting access to your iPad's data.
How to Restore the iPad From iTunes
Remember to restore the iPad from the same computer you used to sync. If you are using iOS 5.0 and have iCloud set up to backup your iPad, you can also restore from the cloud. Even without restoring from a backup, you can go to the app store and install any app you have previously purchased for free.
Hope this helps a bit.
Jul 30, 2014 | Apple iPad (16 GB) WiFi Tablet PC
No audio on speakers or headset. Both worked fine a few days ago. Activity is visible on mixer for speakers or headset (symbol bottom right), when music program is chosen. Relevant data: PC Vaio...
The error states file access denied.
It seems your login is not able to access that specified file
due to permission constraint.
  • Firstly disable UAC.
  • If you have mcaffee installed or norton, disable access protection.
  • If you created a system restore point with the True Crypt image mounted, you won't be able to restore back to that point. It needs to be unmounted before creating the restore point.
  • If you use Panda Internet Security you need to uninstall it completely in order to be able to restore to a previous point.
Before trying the above solutions you can try the following that exploit a bug on windows:
  1. turn off System Restore,
  2. Shutdown,
  3. Power Up,
  4. enable System Restore and
  5. try to Restore.
Best of luck.
Feb 13, 2014 | Computers & Internet
9c93a00208
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data.
Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so.
However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled.
To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player.
Launch iTunes if it does not automatically open.
Select your iPod touch under the devices list, and click the "Summary" tab in iTunes.
Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes.
Click "Restore" when prompted, after the back up saves. After restoring, click "Ok."
Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen.
Click the "Continue" button to restore your iPod touch.
iOS: Forgotten passcode or device disabled after entering wrong passcode
http://support.apple.com/kb/ht1212
iTunes: Restoring iOS software
http://support.apple.com/kb/HT1414
Jun 10, 2013 | Apple iPod touch
Forgot my ipod pascode lock
If you own an iPod touch, you have the option to set a password, which Apple calls a passcode, to protect your data. Anyone who attempts to access your iPod, after unlocking it or turning it on, will require the passcode to do so. However, if you forget your passcode or incorrectly enter it, you will eventually see an alert that your iPod touch has become disabled. To unlock your iPod touch after forgetting the passcode, and still access your content, you must connect it to the computer with which you last synced it.
Connect your iPod touch to the computer with which you last synced the music player. Launch iTunes if it does not automatically open. Select your iPod touch under the devices list, and click the "Summary" tab in iTunes. Click "Restore" and, when prompted, click the "Back Up" button to save a back up of your iPod touch in iTunes. Click "Restore" when prompted, after the back up saves. After restoring, click "Ok." Choose the most recent back up from the drop down list on the "Set Up Your iPod" screen. Click the "Continue" button to restore your iPod touch.
http://support.apple.com/kb/ht1212 iTunes: Restoring iOS software http://support.apple.com/kb/HT1414
Apr 08, 2013 | Apple iPod touch
How to enable disable ipod touch
I take it that it has been disabled due to failure to insert the correct passcode.
You will need to restore your device using the computer which you last synced it. This allows you to reset your passcode and resync the data from the device (or restore from a backup).
If you do not have access to that computer if you restore on a different computer you'll be able to unlock the device for use and remove the passcode, but the data will be wiped. Hope this helps.
Nov 24, 2011 | Apple iPod touch
I cant access my facebook..but i can access other web site..just the www.facebook.com cant access....even i type in https://www.facebook.com also can access inside...who can help me?
Do you access in your company, it could be disabled by your administrator. Try restoring your internet option to its default settings. Scanned your pc for possible infection of malwares.
Sep 17, 2011 | Facebook Social Network
How do I undo a reformat on an HP? My HP was reformatted and I need to return it to the previous state. Already tried system restore, but prompt said there is no point to restore to. Is there a way to...
Troubleshooting
Accessing Computer Setup
The information and settings in Computer Setup are accessed
from the File, Security, Tools, and Advanced menus.
1. Open Computer Setup by turning on or restarting the
computer. Press f10 while the F10 = Based Setup message is
displayed in the lower-left corner of the screen.
To change the language, press f2.
To view navigation information, press f1.
To return to the Computer Setup menu, press esc.
2. Select the File, Security, Tools, or Advanced menu.
3. To exit Computer Setup, choose one of the following:
To exit without saving any changes, use the arrow keys to
select File > Ignore changes and exit, and then follow
the instructions on the screen.
To exit and save all the settings you have entered, use the
arrow keys to select File > Save changes and exit, and
then follow the instructions on the screen.
Your preferences are set when you exit Computer Setup and take
effect when the computer restarts.
Computer Setup Defaults
To return all settings in Computer Setup to the values that were
set at the factory:
2. Use the arrow keys to select File > Restore defaults.
3. Select the Restore Defaults check box.
2–2
Maintenance and Service Guide
Troubleshooting
4. To confirm the restoration, press f10.
5. Select File > Save changes and exit, and then follow the
When the computer restarts, the factory settings are restored, and
any identification information you have entered is saved.
Selecting from the File Menu
Table 2-1
File Menu
Select
To Do This
System Information ¦
View identification information about the
computer and any battery packs in the system.
View specification information about the
processor, memory and cache size, video
revision, keyboard controller version, and
system ROM.
Save to floppy Save system configuration settings to a diskette.
Restore to floppy Restore system configuration settings from a
diskette.
Restore defaults Replace configuration settings in Computer Setup
with factory default settings. (Identification
information is retained.)
Ignore changes and exit Cancel changes entered during the current
session. Then exit and restart the computer.
Save changes and exit Save changes entered during the current session.
Then exit and restart the computer. The changes
you save are in effect when the computer restarts.
2–3
Troubleshooting
Selecting from the Security Menu
Table 2-2
Security Menu
Select To Do This
Administrator password Enter, change, or delete an HP Administrator
password.
Power-on password Enter, change, or delete a power-on password.
Password options ¦
Enable/Disable stringent security.
Enable/Disable required password on restart.
DriveLock passwords Enable/disable DriveLock; change a DriveLock
user or master password.
DriveLock Settings are accessible only
when you enter Computer Setup by turning
on (not restarting) the computer.
Smart Card Security Enable/disable power-on support for smart cards.
This feature is supported by select smart
card readers only.
Embedded Security ¦
Enable/Disable the embedded security chip.
Restore embedded security chip to factory
settings.
Enable/Disable power-on authentication
support.
Enable/Disable automatic DriveLock.
Reset power-on authentication credential.
Embedded Security settings are accessible
only if the computer is equipped with an
Device security Enable/Disable devices in the system.
Enable NIC for inclusion in MultiBoot.
System IDs Enter user-defined identification values.
2–4 Maintenance and Service Guide
Troubleshooting
Selecting from the Tools Menu
Table 2-3
Tools Menu
Select To Do This
HDD Self Test options Run a quick or comprehensive self-test on any
hard drive in the system.
Battery Information View information about any battery packs in the
computer.
Jan 01, 2010 | HP Pavilion dv4000 Notebook
I did a configuration on my computer to try and get more space, it took my sound off and now it says no sound device found. Not sure what to do to get my volume back??
your computer has a restore function. click on start and look for restore in the menu. restore the computer back to a date before you "adjusted" it.
Sep 16, 2009 | Gateway MT3705 Notebook
Disable 3g
To disable 3G,
dial 5476278#*# on the dialpad as a phone number. Scroll to "Modem Setting” >"Band Setting" > "GSM Only" > "OK". Okey! It’s Done. LG Phone Problem and solution
To restore 3G, follow the same steps, and select "Automatic". This setting will remain in effect until you change it. Cycling the power does not reset this.
May 02, 2009 | LG Incite Cell Phone
Unable to access restore-point feature
Try booting into safe mode and accessing it from there.
To get into safe mode, press F8 when you turn on your computer and keep pressing it until the menu appears from which you can select safe mode.
Jun 22, 2008 | Computers & Internet
Computers & Internet Logo
29 people viewed this question
David Payne
David Payne
