Question about Samsung Refrigerators
Ice maker removeal
I have a Samsung four door French refrig that is not making ice but I have water coming thourgh the line not sure what I need to do
  • 1122 Answers
SOURCE: Ice maker not getting water
PULL THE TUBE BEHIND THE ICEMAKER OUT AND SEE INSIDE IF IT IS FROZEN,IF NOT ALL THAT'S WRONG IS THE WATER INLET VALVE ON LOWER BACK OF FRIG.IS BAD,YOU HAVE A WATER DISPENSER HOSE ON ONE SIDE AND A ICEMAKER HOSE ON THE OTHER,THE ICE MAKER SIDE OF THE VALVE IS BAD,THANKS-MIKE
Posted on May 29, 2008
  • 52 Answers
SOURCE: Ice maker won't make ice. Jenn-Air French Door Refrigerator JFC-2089HPY
You don't do it from the back. You probably don't want to defrost the whole freezer, so just warm the supply tube with a hair dryer. When the water melts and starts running out, it will then be loose enough to pull free from the aluminum tube it is covering. Remove the aluminum tube, too, and make sure there is no ice all the back to where the water enters (this will be from the white plastic piece on the back).
Now..... why did it freeze? Most likely, there is a restricted airflow to the back of the unit, which is need to keep that aluminum supply tube just warm enough to assure all the water flow OUT of it into the icemaker, and doesn't freeze up on contact. Make sure your coils and the airspace under the fridge are completely clean (vacuuum them well) and it should cure the problem.
Posted on Jul 17, 2008
SOURCE: HOOK UP OF ICE MAKER TO THE WATER LINE
The ice maker is not making any ice, or water or crush ice. The wheel that crushes the ice will not spin. Please help
Posted on Aug 19, 2008
SOURCE: Maytag refrig (french door) water and ice on door stopped.
1) Electric Water valve check up.
2) Water/Ice dispenser control check up
3) frozen plastic pipe inside door or/and chilled water container frozen
4) old water filter (clogged)
Posted on Dec 07, 2008
arikrom
  • 528 Answers
SOURCE: kenmore refrig model #106-56232400 ice maker
the ice maker unit prob' bad and if you sure it is on and the flag is not stoping it from runing you might need a new unit but there are other tests you can do before..
call me 843.789.4824
Im in Charleston S.C but will happy to help you
www.911servicetoday.com
Posted on Dec 30, 2009
No water coming from water line to refrigator
There is a water solenoid at the water inlet in the back of the refrigerator that is operated by the ice maker unit. It is separate from the water dispenser. Make sure the wires at the ice maker are fully seated and not pinched at the door hinge. If the wiring looks good, then the solenoid needs to be replaced.
Feb 20, 2016 | Kenmore Sears Refrigerator Replacement Ice...
Samsung refrig, side by side, won't eject ice. How do I turn off the left hand light to quit ice?
How to Repair a Refrigerator Ice Maker ' HomeTips
www.hometips.com/repair-fix/freezer-ice-maker.html
If your ice maker doesn't make ice, check out these expert do-it-yourself ice maker repair ... W. Branner Side by side GE fridge, stopped dispensing ice both cubed and crushed. ... But now that it's cleared the motor won't run to dispense any ice (water .... Our Samsung French door ice maker is not working & is making noise.
Jan 01, 2016 | Samsung Refrigerators
Ice maker making clicking noises even though water and ice working
Hi orangebomber, I want to help you with your problem, but I need more information from you. Can you please add details in the comment box?
Feb 03, 2014 | Samsung RFG297AARS (285 cu ft) Bottom...
I don know how to turn on the ice maker of a french four door refrigerator
water line hooked up,open door to ice maker check to see ice maker metal arm where cubes fall down from is in the down position,,when its in the up position it stops making ice,no water coming inalso u can change water filter in fridge this way too,it will not let water in until arm is back down
Aug 07, 2013 | Whirlpool Whirpool 26 cu. ft. French Door...
LSC27926ST REFRIG/freezer. Ice maker is leaking water that freezes on items in freezer, ice is messed up and had to unclog ice maker. Still a logjam of ice around ice maker. has been churning out ice...
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn't take much to eventually block the fill tube.
Sep 10, 2011 | LG LFX25960ST Stainless Steel French Door...
I have a french door refrig with two ice makers. I cubes seem to be wet in door when crushing ice. Also in bottom ice maker the cubes are stuck together in tray in one clump. I lowered temp to -4 but it...
You need to check the door seal. If you place a $bill in the door it should have resistance all the way around as you pull the bill through. It may just be that the doors need adjustment.. If you are able to maintain -4, the ice maker heaters may not be working properly. Also, you want to check the water valve to make sure that you are getting cold water to the icemakers as hot water coming into the fridge can also cause this. If this is the problem, you can use a longer coiled line for the water inlet valve.
Sep 01, 2011 | Samsung Refrigerators
I have a samsung rfg297aars refrig. I believe the water is leaking from the ice maker into the cube tray and running out and freezing in the cube dispenser and it is freezing the cubes together and...
you need to check the flapper in the door where the ice comes out,, if you take the ice bin out look down in the hole where the ice comes out,, if it is not sealing good it will let warm air come up the chute and melt the ice,, if it is sealing good,, then you need to check and see if the water fill tube( the one that goes into the icemake) is not froze up or has asomething blocking it
Jan 19, 2011 | Samsung RFG297AARS (285 cu ft) Bottom...
Ice maker does not make ice.
The water tube to the icemaker inside the refrig may be frozen up. Thaw out with your hair dryer. To make sure the tube is clear. Shut of the water to the refrig, disconnect the inlet water line to the icemaker. Insert a flexable through the connector fitting, I used a zip tie. The flexable item should go all the way to the icemaker
Solution #2 Replace the "water inlet valve" at bottom back right of refrig. Easy To Do.
Jun 06, 2010 | LG LMX25981ST Stainless Steel Bottom...
My LG french door ice maker won't make ice.
THE WATER LINE POSSABLY FROZE YOU MAY NEED TO REMOVE YOUR FOOD AND UNPLUG IT OVERNIGHT WITH THE DOORS OPEN.MAKE SURE TO WATCH FOR WATER ON THE FLOOR.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
May 15, 2010 | Refrigerators
Maytag refrig (french door) water and ice on door stopped working at the same time.
Dec 07, 2008 | Maytag (MFI2568AEW) Bottom Freezer French...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
