Question about Panasonic Lands Phones
I have a Panasonic KX-TGA652 that the auto talk quit working on both base and remote handsets. I tried to turn it on but it did not work, it says it is on but when I pick up handset there is no tone.
  • 944 Answers
SOURCE: Hard reset of KX-TCD580 Base
Go to this link; and input "KXTCD580" in the search box - after a few disclaimer screens you get to the manual for your phone. page 29 details reset for the handset Page 32 details base unit reset Page 48/49 details cancelling handsets to the base Hope this helps, please post again if you are still having problems with your phone :)
Posted on Apr 01, 2007
SOURCE: Panasonic KX-TG2740 Cordless Phone - Can I reset handset registration
press function button on handset, scroll to initial setting, select by pressing right arrow, scroll to registration, select, select hs registration, follow directions on handset display, pressing mute on "new" base station, and ok on handset(plugged in). If you like, you can unregister with the "old" base unit first.
Posted on Jan 16, 2008
  • 106 Answers
SOURCE: handset does not work
Your handset is no longer communicating with your base. Depending on your model, the solutions can be a couple of different options. If I could view pdf files on this computer I would look it up for you. But here is the link to the manual on Unidens website-
Nonetheless, give this a try. Power down your base, and pull the battery out of your handset. Plug the battery back in the handset and set the bad handset in the base cradle, and then power up the base. Wait about 30 seconds, then give the phone a try. If it still does not work, then you need to try to "re-register" the bad handset back to the base. Look in the manual under "registration" procedures. Hope my help fixes it for you. Good Luck, CG
Posted on Feb 18, 2008
SOURCE: adding handset to Panasonic KX-TGA542M phone. ? how to ?
I ordered a new kx-tg560m handset for my kx-tg5632 base unit, but the enclosed instructions for registering it with the base unit were wrong. Fortunately, I found the old quick setup guide in my files.
If you do not have the same base unit and handset, go to the URL:
1. On the handset, press [MENU], then press [0][0]. The handset displays "Refer to manual to prepare base. Then press OK->"
2. On the base unit, press [SELECT] until the desired extension number [H1, H2, H3, or H4] is displayed on the base unit, then press and hold [CALL] until the CHARGE indicator flashes.
3. On the handset, press the [OK] softkey.
When the handset is off and sitting in the charger, the handset's extension is displayed in the upper right corner.
Posted on Nov 22, 2008
  • 514 Answers
SOURCE: Kx-tg1100 registration to anoter base
sorry, it seems that they have to come from the same model base. however, the procedure to reset handset numbers for the 1100 may work for you. there is a 15 digit number on the base unit. try to type that into the 1100 and see if that will register the 1100 to your old base.
Posted on Jan 09, 2009
I have a panasonic kx tga652 phone it says base no power on several of my hand sets
That sounds like a handset model, from any of a range of DECT Plus systems?
Panasonic phone support is horrible, but they're pretty good about keeping manuals available on their (may need to select USA) support site. Search the model number not of the handset, but the system found on the bottom of the main base unit.
There are enough versions and configurations that it's hard to guess specifics, but those series generally have the ability to power the base from a handset during power failures. There could be a need to reset something, or bad batteries or connectors in the handset in the base. Try swapping which handset is left in the base, and inspect the batteries in all handsets (sometimes removing them shows corrosion, or cleans a bad contact just from handling). Most of those use regular AAA NiMH batteries, and so they're pretty easy and cheap to replace if needed.
Jan 23, 2015 | Panasonic Lands Phones
Have a Panasonic KX-TG1061C with 3 handsets. Handsets work perfectly. None of corded base unit buttons work.
to turn off night mode
do not think night mode would cause your problem.
check dialing mode #120
When you unplugged the base unit did you pull out the ac adapter for about 30 seconds to reset the base unit ?
Jan 04, 2015 | Panasonic Lands Phones
I have a Panasonic KX-TGA652 dual handset no answering machine. The problem I have is the 1st handset "the base set", doesn't seem to work properly, the 2nd handset works 100% fine. The problem is this,...
Id try the following in this order:
  1. Try swapping batteries with another set and see if the problem follows the battery
  2. Try re-registering the handset, they could of missed one at the factory. that is done by selecting menu->initial settings->register handset
If this doesn't work, then return for warranty/exchange. Mine seem to work great right out of the box.
the poodle guy!
Sep 29, 2010 | Panasonic Lands Phones
Panasonic KX TG9331 no link to base Even standing next to the base, I cannot answer the call. Sometimes repeated pressing of the talk button lets me talk. Also, switching to speaker phone sometimes drops...
Sounds like a defective handset or base unit. Unplug the base unit from power and the telephone jack. Leave unplugged for 1 minute, this sometimes helps the phone to reset from a problem. Unplug the battery from the handset and plug back in after a minute also to help reset. Place your handset in the base unit for about 1 minute to allow the handset to link up with the base unit. If this doesn't work you may have a defective phone. Contact Panasonic support for further information if this does not work.
Aug 29, 2009 | Panasonic KX-TG9331T Cordless Phone
One handset works, the other displays
Pull the battery out of the afoul unit. Let sit for 5 min. Put battery back in unit and set it in the base unit.
Feb 28, 2009 | Panasonic KX-TG1033S Cordless Phone
Sync a new handset to kx-tg5632 phone
This works on MY panasonic; May work on yours too!
Registering a handset
The included handset and base unit are
preregistered. If for some reason the
handset is not registered to the base
unit, register the handset.
1 Handset:
{MENU} i {0}{0}{1}
2 Base unit:
Press and hold {LOCATOR/
INTERCOM} until the IN USE
indicator flashes.
LAfter the IN USE indicator starts
flashing, the rest of the procedure
must be completed within 1
3 Handset:
Press {OK}, then wait until a beep
4 {OFF}
Registering an additional handset
See page 5 for information on the
available model.
Start from step 2.
Dec 29, 2008 | Panasonic KX-TG5632 Phone
The handset is away from the range of the base. Keep the handset on the base for some time and then try again.
Aug 25, 2008 | Panasonic Hybrid IP 12 Key Add-in Mod use...
Model#kx-tg6071b when talk button is pushed, screen shows" no link to base move closer, try again". That is what appears on both handsets.
Press MENU, scroll down to INITIAL SETTINGS (press select), scroll down to REGISTRATION (press select), then select HS REGISTRATION, and follow the instructions on the handset screen. This is for the KX-TG6071B, but is similar for most Panasonic Cordless phones. That will link the handset to the base, and YOU MUST DO IT WITH EACH HANDSET.
Jun 22, 2008 | Panasonic KX-TG2313 Cordless Phone
Lands Phones Logo
Top Panasonic Lands Phones Experts
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
