Question about John Deere Garden
Replaced ignition switch but my mower deck won't engage on my John Deere 210
Removed deck for winter put back on this spring but doesn't engage
  • John Deere Master
  • 7,515 Answers
Here's the link and I'm sure you will get the solution of your problem.
John Deere 212 214 210 200 Tractor Service Manual
Posted on Jun 08, 2017
Why won't my 2007 John Deere L130 turn over?
remove spark plug and see it it turn over .set Brake too
May 04, 2015 | John Deere Garden
I have a 190d john deere 54in deck and the blades won't engage
With the machine off, check to see if anything is jammed underneath the deck, or around belts, clean everything off. try to manual turn the blades with you hand (tractor off and key out of the ignition) if blades don't remove, take off deck belt and then try and move each blade individually, see it any bearings are seized. Check to see if any one of your safety switches were disconnected, and test out the pto switch for power.
Aug 26, 2013 | John Deere 420,1020,2010,2020,2510,2520...
Mower deck won't engage John Deere 170
sound like the lawn deck is in a jam bent blades or damaged pulleys
Aug 28, 2012 | Cars & Trucks
Jon Deere mower LX277 won't crank
Try replacing the starter solenoid. If that doesn't do it, try replacing the whole starter.
May 05, 2012 | John Deere Garden
John Deere La175 Battery doesn't charge while mowing. After I mow for an hour or so and turn tractor off, it won't start. When I put the charger on it for a second or two, it turns over and runs....
I had the same problem. My LA 175 mowere deck would not engage and I figured out that the battery was not sending the sufficient 12volts to the mower deck to run the mower. I replaced the battery and that fixed the problem only to reveal the original problem. Within 2 hours of mowing the battery again died. I replaced the voltage regulator and that didnt help. I need suggestions on where to go from here please. Anybody?
Apr 22, 2012 | Garden
John deere model LA105, deck engagement cable spring keeps breaking.
are you routing it the right way rubbing or kinked
Apr 03, 2012 | John Deere Garden
John Deere 160 Mower Deck Switch - mower deck does not engage when switch is turned on. The "dead man" engine shutoff still functions when the switch is engaged - if the switch is on and there is...
Hi, check that you have 12 volts to the pto when the switch is on. It sounds like your pto is fried as the switch is functioning correctly. Regards Phil.
Sep 20, 2011 | John Deere Garden
Have a john deere sabre turn key won't start thought battery was dead charged battery still won't start jump start with car battery it will start then . try to engage reverse with blades running it...
Some mowers have a mowing reverse safety switch. That safety will kill the mower if you try to reverse with the deck engaged. Some mowers even have an override button that has to be held while backing up. As for the battery thing, no matter how much you charge a bad battery you will not get it to start a mower if it has a bad cell or two. I would use a multimeter to check battery voltage, but the end result would still be the same, replace the battery.
I hope this gets you going again.
Aug 07, 2011 | John Deere 22HP VTwin 48" Riding Mower
Problem with John Deere L120 tractor
Park brake switch is the most likely culprit,any other would cause the tractor to not turn over in the crank position.
Jul 25, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Garden Logo
59 people viewed this question
Top John Deere Garden Experts
Phil Walker
Phil Walker
Tim Whalen
Wayne Fellows
Wayne Fellows
Are you a John Deere Garden Expert? Answer questions, earn points and help others
