Question about Husqvarna Garden
What to do if my husqvarna RZ5424 stalls after 10 minutes with the blades engaged? It has all new filters, New fuel pump, and new plugs.
  • Husqvarna Master
  • 645 Answers
This could be a tank vent problem. Loosen the fuel cap and run the mower, if it stops stalling the tank vent is clogged or bad. If this makes no changes, you may have a blockage in the fuel lines or filter.
Posted on Nov 28, 2017
  • 1055 Answers
SOURCE: 1998 GMC Sierra- runs rough then stalls when
had this problem on my neighbors 98 chevy truck with the same engine !!
it turnd out too be the fuel pressure regulator,you have too pull the upper intake too replace it!!
Posted on Jun 06, 2009
  • 84 Answers
SOURCE: have a craftsman model :917.273621,
try the coil. the coil will produce the spark for the spark plug seeing as there is no battery, try replacing it with another of the same power.
Posted on Jun 24, 2009
  • 508 Answers
SOURCE: 4000 onan will start and run 5 to 10 minutes and
check oil sensor and oil level check tank for sediment and lines and crb for sediment also coil maybe going bad!!! :)
Posted on Jul 02, 2009
  • 218 Answers
SOURCE: Engine stalls after 45 minutes? name is Keith...i would suspect either the fuel cap isnt venting..or if you have a fuel pump..that it is bad..i hope this will help..if not please write back
Posted on Jul 09, 2009
  • 496 Answers
SOURCE: Motor backfires
It sounds like your engine is firing out of time.
Here is a link to the manual for your engine. It does contain some good info and I hope it will help you to solve this problem.
Best of luck!
Posted on Aug 31, 2009
My mower starts and then shuts off after 5 to 10 min or so, I'm thinking its a fuel problem. I replaced the fuel pump, added a new fuel and air filter. Still having a problem. need help!
Check the function of the fuel shut off solinoid in the bottom of the float bowl, this can be done by removing the unit fronm the base of the carb ( there will be fuel spill from the bowl once the solinoid has been removed, now switch the ignition on, the centre pin should retract into its housing.
Jul 19, 2017 | Husqvarna Garden
Husqvarna lgt24k54 keeps turning off
Interesting! Try seeing if it will run without the fuel tank cap on. There is normally a small hole to let air in as fuel is used, if this gets blocked the fuel will stop running from the tank. You probably won't be able to clean it well enough so a replacement cap shouldn't be too expensive.
Jul 17, 2013 | Husqvarna LGT24K54 54" 24HP Kawasaki Lawn...
Stalls slowing down
Air filter plugged - Clean air filter
Tank vent faulty - Clean or replace tank vent if necessary
Leak in fuel line between tank and fuel pump - Seal or renew connections and fuel line
Pump diaphragm damaged or fatigued - Fit new pump diaphragm
Main jet bores or ports blocked - Clean bores and ports
Fuel pickup body dirty - Fit new pickup body
Fuel strainers dirty - Clean fuel strainers
May 01, 2013 | Husqvarna Garden
Why is my husqvarna zero turn leaving a strip of uncut grass on the left side of the deck
I have a 2014 HUSQVARNA RZ5424 that I just changed the blades on for the first time now 2017. I got new gator blades because of all the good reviews on them. They are about as good as a screen door on a submarine at 300 feet deep. There the same length as the original blades but leaves two rows of uncut grass about a inch wide regardless of how you try to cut it. Only 240 hours on mower, deck clean ,spindles kept greased . Went back to new Husquvarna blades like the ones made for it. PROBLEM SOLVED. HAPPY HAPPY HAPPY. REL.
Mar 24, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Husqvarna RZ5424 deck wont engage
This is an electro magnetic clutch, it is non servisable, if you have a 12volt supply to the clutch with the pto button pulled out, and it still does not work i fear it is a new clutch required.
Mar 01, 2013 | Husqvarna Rz5424 Zero Turn Lawn Mower...
Husqvarna 24hp 54"yard tractor
Hi. Begin by checking your blades, if they are dull they must be sharpened or that alone will bog down the engine. Also time for a new air filter. Happy mowing. J.
Aug 01, 2010 | Husqvarna 24HP 54" Yard Tractor ()
95 grand am. it starts up for 15 minutes then it stalls. and the more it runs the more it stalls. we think its the fuel pump.
You are thinking right.
Try the Fuel Filter first and see if that helps or fixes it.
If not then go ahead and replace the Fuel Filter.
Most Fuel Pump Warraties require a new Fuel Filter.
The Fuel Pump failure is obvious when the engine warms-up (fuel pump is working longer). The longer the Bad Fuel Pump works the more likely it is to stop working. Waiting allows the Fuel Pump to cool down and allows it to engage again.
Let me know if this helped or if you have additional questions or information. Feel free to contact me at!
Jan 20, 2010 | 1995 Pontiac Grand Am
Husqvarna YTH2348 engine stall issue 23hp B&S. Full charge on the battery 12.7vdc. New fuel filter. 13.5 - 14vdc at full throttle. Cranked right up cut grass 20 minutes +/- begins to sputter as if...
Mine was doing the same thing. Just loosen the gas cap. If its on too tight the engine will stall because the air cant get into the fuel cell to replace the abscent fuel.
Sep 26, 2009 | Husqvarna Lawn Tractor 48" Deck, 23 Hp,...
Jul 08, 2009 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
46 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
