Question about Canon Office Equipment & Supplies
Canon ir3300 showing paper jam in 2nd tray but there is no paper jam in it if i restart the ir3300 it starts working but this days its making 2much of this problem
2 Suggested Answers
  • 38 Answers
SOURCE: Canon ir3300 showing paper jam in 2nd tray but thre is no paper jam in it
  1. Locate and dust your paper sensor eyes
  2. make sure paper size adjuster for tray 2 is locked at proper position.
  3. Examine pick up roller from tray 2, clean or replace as necessary.
Posted on Mar 12, 2015
Canon ir3300 2nd paper jam there are no paper what is the problem please
Hi, there could be a piece of paper jammed on the roller near the paper sensor. Do a roller clean, this does help, also check psychically for any paper remnants and remove. Hope this helps resolve your problem. All the best.
Mar 13, 2015 | Canon Office Equipment & Supplies
Mar 12, 2015 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
i m using canon ir3300 , showing paper jam at left side , but i checked there is no any paper, although there is showing jam. what to do.
Jul 17, 2012 | Canon 2 Ir3300 Ir3300i B/w Copier/ Network...
Why does ir3300 canon photocopier show paper jam between the lower tray and right cover yet no papers jamed and even else where, what could be this?
these also can occure if the paper from the cassette isn't picked up or if the paper pass the cassette and exits but sensor flapper has slow response.
As first step I would recommend to change the paper pick-up, feed and separation rollers in cassette.
Remove the cassette out, look inside, on inner right side you will see 3 tire rollers. Each roller has nose with plastic hinge. To remove him you need to push hinge on the nose and pull out the rooler to a side.
If they are worn out they will be smooth.
You can remove the rollers from the tray that works and put it into troubled one for test. If the paper jam doesn't occuress you are sure that you need new rollers.
If not I recommend to call service.Because, also the problem can be in paper lifting claw, broken gears,...
For service manual you can contact me on emma.servis@gmail.com
Hope that helps!
Sep 01, 2011 | Canon Office Equipment & Supplies
I have a canon imagerunner 2020I copier with a
this message is 90% from the second tray.try to close the small door of the 2nd cassette forcefully.if it does not work u can disconnect the second tray by unplugging the wire from the engine board on the back side of the machine by removing the back cover.it will be a yellow p/j in the middle of the board.u can easily trace it as it goes down to the 2nd tray.
Jul 13, 2011 | Canon ImageRunner 2020i Copier
Canon MP470 keeps saying "paper jammed"
I had the same problem for DAYS and there was no paper jammed at all. I went to the cannon site as a last ditch effort & the solution below fixed it. Just clean the rollers and the link tells you how. Good luck!
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&tabact=SupportDetailTabAct&fcategoryid=238&modelid=15403
Jan 04, 2010 | Canon PIXMA MP470 All-in-One Printer
NP6050 false paper jam at doc feeder
When you put documents in the feeder and you push start do you see 2 black arms swing out to count the number of orignals? If yes, dose the doc tray begin to go down and then jams? If yes, you can try something.... OK, turn the copier off and move the 2 paper guides of the doc tray toward the middle. You need a #2 philip's head screw driver. Remove the 2 silver screws that will be sunk in a bit on the top of the doc tray. Once you remove the screws, remove the top part of the doc tray and you will have one connector toward the front. Unplug it and replug it back in and see if that works, if so return the 2 screws and you should be OK.
Dec 12, 2008 | Canon NP 6050 Copier
35 people viewed this question
old marine
old marine
