Question about Dryers
76AW tumble dryer wont work the drum wont go round there was also a strong smell of burning coming from it,the belt is still on I have also cleaned it and it still wont work
    Top Expert:
  • Dryers Master
  • 14,512 Answers
Is motor turning or is belt slippingr
Posted on May 19, 2017
My BaByliss blow dryer smells like burnt when I turn it on and I seen like a spark is it going to work anymore
DRYER SMELLS LIKE BURNING:
Answer:First, Stop using your dryer until this problem is resolved. This is a fire hazard and could cause a fire.
Your issue is more than likely alint build up problem. The lint that comes off of your clothes as you dry them becomes trapped in the dryer itself and in the venting duct that connects from the back of the dryer to the wall.
The first thing to do is todisconnect powerby unplugging the dryer cord from the wall. Slide the dryer away from the wall slowly.Remove the hose ductthat attaches to the back of the dryer. Look inside the hose duct and if you see heavy lint build up, that is most likely your problem. If you have a shop vac vacuum or similar, use the long wand attachment tovacuum out the lintthat is in the duct. The best way to do this is to completely remove the vent duct from the wall and dryer.Vacuum the inside of the ductto clean it out. Alsovacuum in the vent hole in the wallwhere the duct attaches to the wall and remove any lint that may be blocking air flow. Put everything back together and test your dryer to see if the burning smell has been resolved.
NOTE: There may be heavy build up of lint deep in the wall. You can purchase aDryer Vent Cleaning Kitthat may make your job of cleaning the vent much easier. However, it may be best to call a Dryer Vent Cleaning Company as they have the equipment that is needed to remove all lint in the wall that could cause a fire. We know everyone wants to save money and "do it yourself" but when it comes to safety, money should not be an issue.
If the burning smell is still present, you cantake the dryer apartandtry vacuuming out any lintthat may be built up on the inside of the dryer. Do a search for your dryer model name and number onGoogleto see how your particular dryer model is disassembled. If you are not comfortable taking your dryer apart then it is advised to call an appliance repair company as your issue can cause a fire.
There are other reasons for your dryer to have a burning smell. There could be an electrical issue inside your dryer. This may mean that a certain part or electrical board is going bad or is bad. Another common reason for this issue is something is near the heating element inside the dryer and causing the burning smell. If you have an older clothes dryer, it may be possible that the components are past its life span and it is time to purchase a new dryer. If you want your dryer to be looked at by a professional, it may be time to call an appliance repair company to come out and check your dryer.
There are plenty of videos that can help you to determine what may be wrong with your dryer. There are a few videos below that may assist you with troubleshooting and disassembling your dryer.
The belt
In some dryers, a belt turns the drum. This belt can slip off, which can cause it to start melting. Because it is usually made of rubber, it will then produce a very strong, unpleasant burning odor. If your drum is not turning smoothly or properly, and you notice a bad burning smell, your belt is probably damaged.
THE MOTOR
Dryers have motors, and as they age, they can burn out just like any other motor. This causes a very strong burning smell, and your dryer will either not run at all, or it will run poorly and with a lot of noise.
Read more :http://www.ehow.com/list_7173741_causes-burning-smell-dryer.html
Causes of Burning Smell in Your Dryer eHow
Apr 22, 2016 | BaByliss Dryers
Drum not going round,burning smell when it started, when started it again it clanged really loud then stopped
belt and possible drum rollers:
http://www.partselect.com/dryer+dryer-wont-tumble+repair.htm
Mar 16, 2011 | Samsung DV218AEW Electric Dryer
I have a hotpoint VTD00 tumble dryer and it is heating up but the drum isn't spinning and smells of burning. Thanks, Annmarie
The belt is probably worn out and is slipping,the smell is from the belt slipping on the drum.
Mar 02, 2011 | Hotpoint Dryers
Tumble dryer not working
sounds like a broken belt ;it has to be un plugged from the power source . most belts can be accessed thru the panel on the back o f the dryer.
Jun 12, 2009 | Dryers
Amana ALGO230RAW will not tumble, strong smell ?burning? not sure coming from dryer
Before taking it apart, roll the drum by hand to see how freely it spins. Then take it all apart to see if the belt has failed, and vacuum out all the lint everywhere. Check the fan area, you'll have to remove its cover too. See if the rollers need heat resistant grease, and check the front glides. If it has a center bearing, check that carefully, and the shaft it rides.
Apr 27, 2009 | Amana Dryers
DRUM NOT SPINNING....and a burning smell
Motor going bad. Run windings inside are burneded up.  Start windings are ok. replace motor.
Jan 07, 2009 | Hotpoint TDC32 Electric Dryer
Dryer drum wont turn- burning rubber smell
could be a stuck gear box. burning rubber smell is coming from the belt sliding .
or the belt is just loose and can not turn the drum to spin it.
tnx 4 using fixya,
drcool
Oct 11, 2008 | Kenmore 98702 Stacked Washer/Dryer
Condensing tumble dryer not running
has the belt shredded and wrapped itself around the shaft? try to manually rotate the drum to see if the belt is free and the motor shaft moves. it sounds like the motor is stuck and the smell is the uncirculated heat at the back. let me know your results.
taking the lid off will gain access.
Feb 16, 2008 | Dryers
Drum wont turn on my creda t622cw tumble dryer
my tumble dryer drum wont go round
Nov 15, 2007 | Dryers
Dryers Logo
Top Dryers Experts
